Conversion from MatrixCSR to PETSc matrix
I am trying to write a Python script to solve a particular heat equation. The issue at the moment seems to be that the PETSc solver seems to require a PETSc matrix, whereas the fem.assemble_matrix function produces a MatrixCSR object (see code below). How would I convert this to be in the correct form for the solution to be found? Any other comments or input would be appreciated!
from dolfinx.fem import (Function, FunctionSpace, dirichletbc, locate_dofs_geometrical, Constant, form, assemble_vector, assemble_matrix)
from dolfinx import mesh, fem
import pyvista as pv
def visualiseMesh(msh):
    Provides a 2D rendering file (.xdmf) to show the mesh structure.
      Has to be mesh object from the dolfinx library.
    print("Plotting mesh...")
    with XDMFFile(msh.comm, "mesh.xdmf", "w") as xdmf:
        xdmf.write_mesh(msh)
    # Plot the mesh using Matplotlib
    topology, cell_types = dolfinx.plot.create_vtk_mesh(msh)
    grid = pv.UnstructuredGrid(topology, cell_types, msh.geometry.x)
     # Plot the mesh using PyVista
    plotter = pv.Plotter()
    plotter.show()
def findHeatSolution(length, width, rho_param, c_p_param, k_param ):
    print("""
        Starting simulation
    print("Generating mesh...\n")
    # Creating the mesh (assuming a rectangular substrate for now)
    msh = mesh.create_rectangle(
        comm=MPI.COMM_WORLD,
        points=((0.0,0.0), (length, width)),
        n = (32, 16),
        cell_type=mesh.CellType.triangle,
    # visualiseMesh(msh)
    # Defining the function space V
    V = fem.FunctionSpace(msh, ("Lagrange", 1))
    # Defining trial and test functions u and v
    T_n = Function(V) # Temperature at previous time step
    u = ufl.TrialFunction(V) # u is the temperature at the current timestep (what we are trying to solve)
    n = ufl.FacetNormal(msh)
    delta_t = 0.1
    # Defining the localised heat source power dissipation (uW) and coordinates
    # STILL NEED TO DYNAMICALLY READ IN POWER DISSIPATED AND COORDINATES OF RESISTOR
    print("Defining the localised heat source power dissipation and coordinates... \n")
    P1, P2, P3 = 420, 250, 500
    x1, y1 = -50.0, 0.0
    x2, y2 = 0.0, 0.0
    x3, y3 = 50.0, 0.0
    def localized_heat_source(x, power1=P1, power2=P2, power3=P3, radius=0.05):
        return (
        power1 * np.exp(-((x[0] - x1) ** 2 + (x[1] - y1) ** 2) / (2 * radius ** 2))
        + power2 * np.exp(-((x[0] - x2) ** 2 + (x[1] - y2) ** 2) / (2 * radius ** 2))
        + power3 * np.exp(-((x[0] - x3) ** 2 + (x[1] - y3) ** 2) / (2 * radius ** 2))
   # Define the heat source as a Function in the FunctionSpace
    Q = Function(V)
    Q.interpolate(localized_heat_source)
    # Define the bilinear form (should contain unknowns u and v)
    a = (rho_param * c_p_param / delta_t) * u * v * ufl.dx + k_param * ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx - k_param * ufl.dot(ufl.grad(u), n) * v * ufl.ds
    # Define the linear form (including contributions from known T_n and Q)
    L = (rho_param * c_p_param / delta_t) * T_n * v * ufl.dx + Q * v * ufl.dx
    # Apply boundary conditions (e.g., Dirichlet with T=0 on all boundaries)
    boundary_conditions = [dirichletbc(PETSc.ScalarType(0.0), locate_dofs_geometrical(V, lambda x: np.full(x.shape[1], True)), V)]
    # Time-stepping parameters
    num_steps = 50  # Number of time steps
    time = 0.0
    with XDMFFile(MPI.COMM_WORLD, "heat_solution.xdmf", "w") as file:
        file.write_mesh(msh)
        # Set the function to be written initially
        file.write_function(T_n, time)
        # Assemble the system matrix (A)
        A = fem.create_matrix(form(a))
        fem.assemble_matrix(A, form(a), bcs=boundary_conditions)
        # Create a solver
        solver = PETSc.KSP().create(msh.comm)
        solver.setOperators(A.petsc)  # Use the PETSc matrix
        for step in range(num_steps):
            time += delta_t
            print(f"Time step {step + 1}/{num_steps}, Time: {time:.2f}")
            # Assemble the right-hand side vector (b)
            b = fem.create_vector(form(L))
            fem.assemble_vector(b, form(L))
            fem.apply_lifting(b, [form(a)], bcs=[boundary_conditions])
            fem.set_bc(b, boundary_conditions)
            # Create the solution vector
            T_new = Function(V)
            solver.solve(b, T_new.vector)
            T_new.x.scatter_forward()
            # Update T_n for the next time step
            T_n.x.array[:] = T_new.x.array[:]
            # Save the current solution
            file.write_function(T_new, time)
    print("""
        Simulation complete
Why not just use
from dolfinx.fem.petsc import assemble_vector, assemble_matrix instead as you will then get them in PETSc matrix and vector format
This seemed to have solved the problem I was having. At least I think it did…
My simulation is still not running so I’m not sure if this change had allowed the simulation to work, but it did seem to fix the error I was getting at those lines. Thanks!
I would then suggest opening a separate post for any future issue with a minimal reproducible example:)
