I’m trying to solve the NS equation and get the following error:
" Failed to successfully call PETSc function ‘KSPSolve’. PETSc error code is: 77, Petsc has generated inconsistent data"
this is the MWC:
import dolfinx.fem.petsc
import pyvista
from dolfinx import fem
import dolfinx.plot as dplt
from dolfinx.fem import (Constant, VectorFunctionSpace, Function, FunctionSpace, assemble_scalar,
dirichletbc, form, locate_dofs_topological,extract_function_spaces)
from dolfinx.fem.petsc import LinearProblem, NonlinearProblem
from dolfinx.mesh import create_unit_square, locate_entities, meshtags, create_rectangle, CellType, Mesh
from ufl import (VectorElement,FiniteElement,FacetNormal, Measure, SpatialCoordinate, TestFunction, TrialFunction, TrialFunctions, TestFunctions,
div, dot, dx, grad, inner, lhs, rhs, MixedElement, nabla_grad, split)
def vel_in(x):
val = -4*x[0]*x[0] + 4*x[0]
return np.stack((np.zeros(x.shape[1]), -val*np.ones(x.shape[1])))
mesh = create_rectangle(comm=MPI.COMM_WORLD,
points=((0.0, 0.0), (1.0, 3.0)), n=(25, 75),
cell_type=CellType.triangle)
ds = Measure("ds", domain=mesh)
fdim = mesh.topology.dim - 1
P2 = VectorElement("Lagrange", mesh.ufl_cell(), 2)
TH = MixedElement([P2, P1])
#TH = P2*P1
W = FunctionSpace(mesh, TH)
V, V_to_W = W.sub(0).collapse()
Q, Q_to_W = W.sub(1).collapse()
# parabolic inlet
u_in = Function(V)
u_in.interpolate(vel_in)
where = locate_entities(mesh, fdim,marker=lambda t: np.isclose(t[1], 3.0))
dofs = locate_dofs_topological(V, fdim, where)
bc0 = dirichletbc(u_in, dofs)
# noslip
noslip = Constant(mesh,(0.0,0.0))
where = locate_entities(mesh, fdim,marker=lambda t: np.isclose(t[0], 0.0))
bc1 = dirichletbc(noslip, dofs, V)
# noslip
where = locate_entities(mesh, fdim,marker=lambda t: np.isclose(t[0], 1.0))
bc2 = dirichletbc(noslip, dofs, V)
#outflow
outf = Constant(mesh,(0.0))
where = locate_entities(mesh, fdim,marker=lambda t: np.isclose(t[1], 0.0))
dofs = locate_dofs_topological(Q, fdim, where)
bc3 = dirichletbc(outf, dofs, Q)
bcs = [bc0,bc1,bc2,bc3]
up = Function(W)
u, p = split(up)
(v, q) = TestFunctions(W)
f = Constant(mesh, (ScalarType(0), ScalarType(0)))
g = Constant(mesh, (ScalarType(0)))
Re = Constant(mesh,ScalarType(10.0))
F= (1/Re)*inner(grad(u), grad(v)) * dx + inner(dot(u, nabla_grad(u)),v) * dx \
- inner(div(v),p) * dx - inner(div(u),q) * dx + inner(f, v) * dx + inner(g,q) * ds
problem = NonlinearProblem(F, up, bcs)
solver.rtol = 1e-6
ksp = solver.krylov_solver
opts = PETSc.Options()
opts[f"{option_prefix}ksp_type"] = "fgmres"
opts[f"{option_prefix}pc_type"] = "fieldsplit"
opts[f"{option_prefix}pc_fieldsplit_type"] = "schur"
# Set the direct solver types for each block
opts[f"{option_prefix}pc_fieldsplit_0_ksp_type"] = "preonly"
opts[f"{option_prefix}pc_fieldsplit_0_pc_type"] = "lu" # or "mumps", "superlu"
opts[f"{option_prefix}pc_fieldsplit_1_ksp_type"] = "preonly"
opts[f"{option_prefix}pc_fieldsplit_1_pc_type"] = "jacobi" # or "ilu"
ksp.setFromOptions()
r = solver.solve(up)
print(f"Num iterations: {r[0]}")
