Laplace on 3d sphere/ellipsoid - exterior problem
I’m working on solving the Laplace equation on a sphere with simple Dirichlet (constant) and Neumann(0) boundary conditions. Analytically the second boundary condition is a constant potential at infinity, I didnt know how to enforce this condition so I tried to use the 1/r decay of the potential at large distances from the sphere.
Currently, I use two coincide spheres: an inner sphere with the correct boundary conditions and a larger sphere (with a 1:10 radii ratio) to simulate the 1/r decay. While this approach works for various tests I performed, I’m unsure if it’s correct and efficient solution, also different geometries like an ellipsoid might need a different approach.
Has anyone dealt with a similar setup or knows of a more optimized method to handle the 1/r decay (/ constant at infinity)?
I’d appreciate any insights!
import dolfinx.io.gmshio
from dolfinx import fem, io, plot, mesh
from dolfinx.fem import dirichletbc, locate_dofs_geometrical, FunctionSpace, Constant
from ufl import TrialFunction, TestFunction, grad, inner, ds, dx
import pyvista
from dolfinx.plot import vtk_mesh as create_vtk_mesh
from utils import *
shell_volume_tag = 1
inner_boundary_tag = 2
outer_boundary_tag = 3
REFINEMENT_RADIUS = 0.1
def generate_spherical_shell_mesh(a, R, inner_mesh_size, outer_mesh_size):
    return msh, cell_tags, facet_tags
# Mesh parameters
a = 1.0  # Cell radius
R = 10.0  # Outer boundary radius
inner_mesh_size = 0.05  # Refined mesh near receptor
outer_mesh_size = 1.0
phi_0 = 1.0
gmsh.model.add("spherical_shell")
# Create the inner sphere (volume)
inner_sphere = gmsh.model.occ.addSphere(0, 0, 0, a)
gmsh.model.occ.synchronize()
# Create the outer sphere (volume)
outer_sphere = gmsh.model.occ.addSphere(0, 0, 0, R)
# Create the spherical shell by cutting the inner sphere from the outer sphere
shell = gmsh.model.occ.cut([(3, outer_sphere)], [(3, inner_sphere)])
# Get the volume tag of the spherical shell
shell_volume = shell[0][0][1]
# Get the surfaces of the spherical shell
shell_surfaces = gmsh.model.occ.getEntities(dim=2)
# Add physical groups
gmsh.model.addPhysicalGroup(3, [shell_volume], tag=shell_volume_tag)  # Spherical shell volume
gmsh.model.setPhysicalName(3, 1, "ShellVolume")
gmsh.model.addPhysicalGroup(2, [inner_sphere], tag=inner_boundary_tag)  # Inner boundary
gmsh.model.setPhysicalName(2, 1, "InnerBoundary")
gmsh.model.addPhysicalGroup(2, [outer_sphere], tag=outer_boundary_tag)  # Outer boundary
gmsh.model.setPhysicalName(2, 2, "OuterBoundary")
# Set mesh sizes on the surfaces
gmsh.model.mesh.setSize(gmsh.model.getBoundary([(2, inner_sphere)], recursive=True),inner_mesh_size)
gmsh.model.mesh.setSize(gmsh.model.getBoundary([(2, outer_sphere)], recursive=True),outer_mesh_size)
# Mesh generation
gmsh.model.mesh.generate(3)
# Convert to DOLFINx mesh
msh, cell_tags, facet_tags = io.gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=3)
gmsh.finalize()
V = fem.functionspace(msh, ('CG', 2))
# Define measures with facet_tags
inner_tag = inner_boundary_tag
outer_tag = outer_boundary_tag
ds = ufl.Measure("ds", domain=msh, subdomain_data=facet_tags)
dx = ufl.dx(domain=msh)
# Locate dofs on the tagged surface using geometrical condition
inner_dofs = fem.locate_dofs_topological(V, 2, facet_tags.find(inner_boundary_tag))
outer_dofs = fem.locate_dofs_topological(V, 2, facet_tags.find(outer_boundary_tag))
# Define Dirichlet BC on inner sphere
bc_inner = fem.dirichletbc(value=phi_0, dofs=inner_dofs, V=V)
# Define Neumann condition (zero flux) on the inner boundary
# Neumann conditions with zero flux should be naturally handled, but we include it explicitly for clarity
g_N = Constant(msh, 0.0)
# Define the variational forms
a_form = inner(grad(u), grad(v)) * dx + (1 / R) * u * v * ds(outer_tag)
L_form = g_N * v * ds(inner_tag) + Constant(msh, 0.0) * v * dx
# Set up and solve the linear problem
problem = LinearProblem(
    a_form,
    L_form,
    bcs=[bc_inner],
    petsc_options={
        "ksp_type": "cg",
        "pc_type": "hypre",
        "ksp_rtol": 1e-9,
        "ksp_max_it": 1000,
        "ksp_monitor": None
uh = problem.solve()
# flux calculation
n = ufl.FacetNormal(msh)
flux_form_inner = inner(grad(uh), n) * ds(inner_tag)
total_flux_inside = fem.assemble_scalar(fem.form(flux_form_inner))
MPI.COMM_WORLD.barrier()
# Compute the analytical flux for comparison
flux_inner_exact = 4 * np.pi * phi_0 * a
print(f"Numerical flux over the inner sphere: {total_flux_inside:.6f}")
print(f"Analytical flux over the inner sphere: {flux_inner_exact:.6f}")
the results looks good:
Numerical flux over the inner sphere: 12.507325
Analytical flux over the inner sphere: 12.566371
This sounds like the kind of problem that the boundary element method (BEM) might be better for, as BEM can naturally handle infinite domains.
Taking a look at the Bempp tutorials might be a good place to start.
