I am trying to solve a non-linear poisson’s equation using Newton-Rapson Method
Explicitly -del((K0 + K1(norm(grad(u))**2)).del(u)) = f, where let f(u) = K0 + K1(norm(grad(u))**2
The textbook has an example in which f(u) is a function of u and is (1+u)**m.
I am trying to manually do the newton raphson loop instead of using the non linear variational in fenics.
Accordinly, I have linearized the equation and i am getting,
Accordinly I have done the code as,
K0 = 200
K1 = K0/10
Nx = 10
Ny = 10
# u = np.zeros(Nx, Ny)
mesh = UnitSquareMesh(Nx, Ny) # mesh
V = FunctionSpace(mesh, 'Lagrange', 1) # function space
# define top boundary
def top(x, on_boundary):
return on_boundary and near(x[1], 1)
def bottom(x, on_boundary):
return on_boundary and near(x[1], 0)
def left(x, on_boundary):
def right(x, on_boundary):
return on_boundary and near(x[0], 1)
# Define boundary condition
g = Constant(0.0)
# Top boundary (index 3) is fixed
bc1 = DirichletBC(V, g, top)
bc2 = DirichletBC(V, g, bottom)
bc3 = DirichletBC(V, g, left)
bc4 = DirichletBC(V, g, right)
bcs = [bc1, bc2, bc3, bc4]
# Define Variational problem
f = Constant(-6.0)
a = inner(nabla_grad(u), nabla_grad(v))*dx
L = f*v*dx
# Compute solution
A, b = assemble_system(a, L, bcs)
u_k = Function(V)
U_k = u_k.vector()
solve(A, U_k, b)
# Till here, the code involves getting an initial u from a linear poisson equation. Now, to
# do the Newton raphson,
Gamma_0_du = DirichletBC(V, Constant(0), left)
Gamma_1_du = DirichletBC(V, Constant(0), right)
Gamma_2_du = DirichletBC(V, Constant(0), top)
Gamma_3_du = DirichletBC(V, Constant(0), bottom)
bcs_du = [Gamma_0_du, Gamma_1_du, Gamma_2_du, Gamma_3_du]
def q(u):
return (K0 + K1*dot(grad(u),grad(u))**2)
# def Dq(u):
# return m*(1+u)**(m-1)
du = TrialFunction(V) # u = u_k + omega*du
#right = inner((K0 + 2*K1* dot(grad(u_k),grad(du)))*nabla_grad(u_k), nabla_grad(v))*dx
a = inner( q(u_k)*nabla_grad(du), nabla_grad(v))*dx + inner((K0 + 2*K1* dot(grad(u_k),grad(du)))*nabla_grad(u_k), nabla_grad(v))*dx
L = - inner(q(u_k)*nabla_grad(u_k), nabla_grad(v))*dx
du = Function(V)
u = Function(V) # u = u_k + omega*du
omega = 1.0 # relaxation parameter
eps = 1.0
tol = 1.0E-5
iter = 0
maxiter = 25
while eps > tol and iter < maxiter:
iter += 1
A, b = assemble_system(a, L, bcs_du)
solve(A, du.vector(), b)
eps = np.linalg.norm(du.vector().array(), ord=np.Inf)
print("Norm:", eps)
u.vector()[:] = u_k.vector() + omega*du.vector()
u_k.assign(u)
I am getting error as
ArityMismatch Traceback (most recent call last)
Cell In[4], line 29
27 while eps > tol and iter < maxiter:
28 iter += 1
—> 29 A, b = assemble_system(a, L, bcs_du)
30 solve(A, du.vector(), b)
31 eps = np.linalg.norm(du.vector().array(), ord=np.Inf)
ArityMismatch: Adding expressions with non-matching form arguments () vs (‘v_1’,).
Can you please help me with this problem, and see where I am going wrong
Also in addition, with respect to the example given in textbook,
du = Function(V)
eps = 1.0
tol = 1.0E-5
iter = 0
maxiter = 25
iter += 1
eps = numpy.linalg.norm(du.vector().array(), ord=numpy.Inf)
print ’Norm:’, eps
u_k.assign(u)
It pops an error ‘dolfin.cpp.la.PETScVector’ object has no attribute ‘array’. How to deal with this?
