Linear Elasticity Tutorial w/ Quadratic Tetrahedrals
Hey,
Quick one. Just need some guidance editing the Linear Elasticity Tutorial for Second Order Tetrahedrals.
I have edited the setup as follows:
domain = mesh.create_box(
        MPI.COMM_WORLD,
        [np.array([0, 0, 0]), np.array([L, W, W])],
        [20, 6, 6],
        cell_type=mesh.CellType.tetrahedron
V = fem.VectorFunctionSpace(domain, ("Lagrange", 2))
But am encountering this error:
RuntimeError: Degree of output Function must be same as mesh degree. Maybe the Function needs to be interpolated?
Referring to XDMF File export:
  with io.XDMFFile(domain.comm, "deformation.xdmf", "w") as xdmf:
      xdmf.write_mesh(domain)
      uh.name = "Deformation"
      xdmf.write_function(uh)
Besides this the code is identical to that in the tutorial.
Thank you in advance.
Use dolfinx.io.VTXWriter instead of xdmffile if you are not using isoparametric elements.
