I would like to analyze the process of deformation of an object of elastic material when it is subjected to a squeezing force using a tetrahedral mesh that I have defined. I would like to know why the code I wrote didn’t work. I hope someone can solve my problem. Using dolfinx version 0.8.0 libraries
from scipy.spatial import Delaunay, ConvexHull
import dolfinx.mesh
import dolfinx.io
import basix
import open3d as o3d
import dolfinx.fem.petsc
def read_point_cloud(filename):
points = np.loadtxt(filename, delimiter=" ")
points = points[:, 0:3]
return points
def create_tetrahedral_mesh(points, simplices):
tetrahedra = simplices
element = basix.ufl.element("CG", 'tetrahedron', 1, shape=(3,))
mesh_tetrahedral = dolfinx.mesh.create_mesh(MPI.COMM_WORLD, tetrahedra,points, element)
return mesh_tetrahedral
def tetrahedron_edge_lengths(vertices):
edges = [
np.linalg.norm(vertices[i] - vertices[j])
for i in range(4) for j in range(i + 1, 4)
return edges
def dense_point(points):
pcd = o3d.geometry.PointCloud()
pcd.points = o3d.utility.Vector3dVector(points)
sparse_pcd = pcd
points = np.asarray(sparse_pcd.points)
hull = ConvexHull(points)
mesh = o3d.geometry.TriangleMesh.create_from_point_cloud_alpha_shape(sparse_pcd, 0.03)
mesh.compute_vertex_normals()
voxel_size = 0.006
voxel_grid = o3d.geometry.VoxelGrid.create_from_triangle_mesh_within_bounds(
mesh, voxel_size, mesh.get_min_bound(), mesh.get_max_bound())
def is_point_in_hull(point, hull):
return np.all(np.dot(hull.equations[:, :-1], point) + hull.equations[:, -1] <= 1e-12)
dense_points = []
for voxel in voxel_grid.get_voxels():
voxel_center = voxel.grid_index * voxel_grid.voxel_size + voxel_grid.origin
if is_point_in_hull(voxel_center, hull):
dense_points.append(voxel_center)
dense_pcd = o3d.geometry.PointCloud()
dense_pcd.points = o3d.utility.Vector3dVector(np.array(dense_points))
merged_pcd = sparse_pcd + dense_pcd
points = np.asarray(merged_pcd.points)
return points
def exclud_tetrahedron(points, length_threshold):
tri = Delaunay(points)
used_points_indices = set()
filtered_simplices = []
for simplex in tri.simplices:
edge_lengths = tetrahedron_edge_lengths(points[simplex])
if all(length < length_threshold for length in edge_lengths):
filtered_simplices.append(simplex)
used_points_indices.update(simplex)
return filtered_simplices, used_points_indices
return ufl.sym(ufl.grad(u))
def sigma(u):
return lmbda * ufl.tr(epsilon(u)) * ufl.Identity(3) + 2 * mu * epsilon(u)
def boundary(x):
return np.isclose(x[2], 0)
# return np.full(x.shape[0], np.isclose(x[:, 2], 0))
def normalize_point_cloud(points):
centroid = np.mean(points, axis=0)
normalized_points = points - centroid
return normalized_points
if __name__ == "__main__":
points = read_point_cloud("/home/jiao/chen_test/code/2f347d95d4a2dae3e762cf5917cef4ef.txt")
points = dense_point(points)
one = Delaunay(points).simplices
# print(type(one))
simplices, used_points_indices = exclud_tetrahedron(points, 0.05)
filtered_dense_points_all = points[list(used_points_indices)]
simplices_dense, used_points_indices_dense = exclud_tetrahedron(filtered_dense_points_all, 0.05)
finally_simplices = np.array(simplices_dense)
tetrahedral_mesh = create_tetrahedral_mesh(filtered_dense_points_all, finally_simplices)
tetrahedral_mesh_deformed = create_tetrahedral_mesh(filtered_dense_points_all, finally_simplices)
E = 1000
nu = 0.3
mu = E / (2 * (1 + nu))
lmbda = E * nu / ((1 + nu) * (1 - 2 * nu))
V = dolfinx.fem.functionspace(tetrahedral_mesh, ("CG", 1 ,(tetrahedral_mesh.geometry.dim,)))
u_bc = dolfinx.fem.Function(V)
u_bc.interpolate(lambda x: np.zeros((3, x.shape[1])))
bc = dolfinx.fem.dirichletbc(u_bc, dolfinx.fem.locate_dofs_geometrical(V, boundary))
u = ufl.TrialFunction(V)
L = ufl.inner(dolfinx.fem.Constant(tetrahedral_mesh, np.array([0.0, 0.0, -10000.0], dtype=np.float64)), v) * ufl.dx
problem = dolfinx.fem.petsc.LinearProblem(a, L, bcs=[bc])
u = problem.solve()
u_values = u.x.array
with dolfinx.io.VTKFile(MPI.COMM_WORLD, "original_mesh1.vtk", "w") as vtkfile:
vtkfile.write_mesh(tetrahedral_mesh)
original_coords = tetrahedral_mesh.geometry.x.copy()
deformed_coords = original_coords + u.vector.array.reshape(-1, 3)
tetrahedral_mesh_deformed.geometry.x[:] = deformed_coords
with dolfinx.io.VTKFile(MPI.COMM_WORLD, "deformed_mesh1.vtk", "w") as vtkfile:
vtkfile.write_mesh(tetrahedral_mesh_deformed)
