Hi guys,
So I’m trying to locally refine a 2D mesh in the neighborhood of an interior point. The only method I’ve seen thus far is to apply the ‘refine’ method iteratively and thus create successively finer meshes.
If I need a mesh which is very fine in the neighborhood of some point, the above approach is not only ham-fisted, it may simply be too computationally expensive.
Is there a better way?
You can generate your mesh using gmsh. In gmsh you start with points, then lines, then surfaces (for 2D). When you define a point, you write something like;
lc = 1e-2
gmsh.model.geo.addPoint(0, 0, 0, lc, 1)
where lc is characteristic length of that point. You should define a small lc for the point you define, which is near the refinement region.
For more information, play with this tutorial.
Hi @zaccandels,
you can also pass a MeshFunction to refine which indicates whether a given cell should be refined or not. This then needs to local refinement and you just need to write some code for a heuristic that refines close to your interior point.
Here is an example of what this could like, but I decided to refine all triangles that interest the vertical lines x = 2.5 and x = 3.5.
refine_cell = MeshFunction("bool", mesh, mesh.topology().dim())
for c in cells(mesh):
vertices_x = sorted(c.get_vertex_coordinates()[::2])
if (vertices_x[0] < 2.5 < vertices_x[1]) or (vertices_x[0] < 3.5 < vertices_x[1]):
refine_cell[c] = True
refine_cell[c] = False
mesh = refine(mesh, refine_cell)
