I am trying to refine a 3D mesh by checking which edges are within a sphere with some user defined center coordinates and radius. This code is based on an earlier code using MeshFunction:
For some reason the code crashes when I try refining the mesh unifomly twice before the local refinement (num_refinements is set to 2), and using VaraView to view the local refinement does not appear to show the refinement happening in the right cells. Am I using the function location_to_mark() correctly within mesh.locate_entities()? Is the function finding all the edges in the volume of the mesh? Are the x variables the 2 nodes of each edge?
Thank you,
Alex
The code is shown below:
from dolfinx import mesh, io
import basix
# Simple cube mesh
points = np.array([[0.0, 0.0, 0.0],
[0.0, 1.0, 0.0],
[0.0, 1.0, 1.0],
[0.0, 0.0, 1.0],
[1.0, 0.0, 0.0],
[1.0, 1.0, 0.0],
[1.0, 1.0, 1.0],
[1.0, 0.0, 1.0]])
cells = np.array([[0, 1, 3, 4],
[7, 3, 4 ,6],
[1, 2, 3, 6],
[3, 1, 6, 4],
[5, 1, 6, 4]])
finiteElement = basix.ufl.element("Lagrange", "tetrahedron", 1, shape=(3, ))
domain = mesh.create_mesh(MPI.COMM_WORLD, cells, points, finiteElement)
num_refinements = 2
for n in np.arange(num_refinements):
domain.topology.create_entities(1)
domain = mesh.refine(domain)
domain.topology.create_connectivity(fdim, fdim+1)
s_c = np.array([0.0, 0.0, 0.0])
refine_radius = 1.0
def location_to_mark(x):
return np.sqrt((x[0] - s_c[0])**2 + (x[1] - s_c[1])**2 + (x[2] - s_c[2])**2) < (refine_radius + 1.0e-6)
marked_edges = mesh.locate_entities(domain, fdim, location_to_mark)
domain = mesh.refine(domain, marked_edges)
xdmf_vec= io.XDMFFile(domain.comm, 'mesh.xdmf', "w")
xdmf_vec.write_mesh(domain)
xdmf_vec.close()
