Dear all,
I want to calculate the electromagnetic wave number of an infinite long conductor of 1.5 mm radius with finite conductivity in the frequency range of 0-100KHz. The mesh size around the conductor is small compared with the wavelength. Can anyone give some suggestions on how to solve such problem?
Dear all,
I calculated the propagation wave number of the electromagnetic wave problem at the frequency of 80000 Hz, but got an inaccurate solution 0.0017806972731223838-0.001756968505041909j and the accurate one should be 0.0016463654919279397-0.0017340090317261698j. However, the code can give the correct result at 2MHz frequency. I don’t know if it’s caused by the large mesh size range which span 5 order of magnitude. The code is here:
import pygmsh
import gmsh, meshio
from slepc4py import SLEPc
from ufl import curl, dx, FiniteElement, grad, inner, Measure, TestFunctions, TrialFunctions
from dolfinx import Constant, Function, FunctionSpace, geometry, cpp, DirichletBC
#from dolfinx.fem import locate_dofs_topological, DofMapRestriction, assemble_matrix
from dolfinx.fem import locate_dofs_topological, assemble_matrix
from scipy.constants import c, epsilon_0
out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
if prune_z:
out_mesh.prune_z_0()
return out_mesh
with pygmsh.geo.Geometry() as geom:
core_r = 0.0015
max_r = 1900
inner_lcar = 0.00007
outer_lcar = 40.1
theta = np.pi / 10
p0 = [0, 0]
p1 = [core_r, 0]
p2 = [core_r * np.cos(theta), core_r * np.sin(theta)]
p3 = [max_r * np.cos(theta), max_r * np.sin(theta)]
p4 = [max_r, 0]
point_coords = [p0, p1, p2, p3, p4]
lcars = [inner_lcar, inner_lcar, inner_lcar, outer_lcar, outer_lcar]
points = []
for p, lcar in zip(point_coords, lcars):
points.append(geom.add_point([p[0], p[1]], lcar))
line1 = geom.add_line(points[0], points[1])
inner_arc = geom.add_circle_arc(points[1], points[0], points[2])
line2 = geom.add_line(points[2], points[0])
inner_loop_curves = [line1, inner_arc, line2]
line3 = geom.add_line(points[2], points[3])
outer_arc = geom.add_circle_arc(points[3], points[0], points[4])
line4 = geom.add_line(points[4], points[1])
outer_loop_curves = [inner_arc, line3, outer_arc, line4]
inner_curve_loop = geom.add_curve_loop(inner_loop_curves)
outer_curve_loop = geom.add_curve_loop(outer_loop_curves)
inner_surface = geom.add_plane_surface(inner_curve_loop)
outer_surface = geom.add_plane_surface(outer_curve_loop)
geom.add_physical(outer_arc, 'Dirichlet')
geom.add_physical(inner_surface, 'Conductor')
geom.add_physical(outer_surface, 'Air')
mesh = geom.generate_mesh(2)
gmsh.write("mesh.msh")
msh = meshio.read("mesh.msh")
# Create and save one file for the mesh, and one file for the facets
meshio.write("mt.xdmf", line_mesh)
with XDMFFile(MPI.COMM_WORLD, "mesh.xdmf", "r") as xdmf_infile:
mesh = xdmf_infile.read_mesh(name="Grid")
mesh.topology.create_connectivity(mesh.topology.dim, mesh.topology.dim)
mvc_subdomain = xdmf_infile.read_meshtags(mesh, "Grid")
with XDMFFile(MPI.COMM_WORLD, "mt.xdmf", "r") as xdmf_infile:
mvc_boundaries = xdmf_infile.read_meshtags(mesh, "Grid")
V = FiniteElement('N1curl', mesh.ufl_cell(), 2)
Q = FiniteElement('P', mesh.ufl_cell(), 3)
W = FunctionSpace(mesh, V*Q)
u, p = TrialFunctions(W)
v, q = TestFunctions(W)
omega = 8e4 #frequency
sigma_core = 8678
sigma_corona = 5e-6
k0_sqr = (omega/c)**2
print(k0_sqr)
S = FunctionSpace(mesh, ('DG', 0))
e_r = Function(S)
x = S.tabulate_dof_coordinates()
print(np.unique(mvc_subdomain.values))
for i in range(x.shape[0]):
if mvc_subdomain.values[i] == 3:
e_r.vector.setValueLocal(i, 1-1j*sigma_core/(omega*epsilon_0))
e_r.vector.setValueLocal(i, 1)
theta_sqr = k0_sqr * 1.1
print(theta_sqr)
theta_sqr = -4e-7-7e-6j
#print(theta_sqr)
a = 1/theta_sqr*(inner(curl(u), curl(v)) - k0_sqr*e_r*inner(u, v))*dx
b = inner(grad(p), v)*dx + inner(u, v)*dx + inner(grad(p), grad(q))*dx + inner(u, grad(q))*dx - k0_sqr*e_r*inner(p, q)*dx
c = b + a
electric_wall = Function(W)
with electric_wall.vector.localForm() as bc_local:
bc_local.set(0)
print(mvc_boundaries.values)
bndry_facets = np.where(mvc_boundaries.values == 1)[0]
bdofs = locate_dofs_topological(W, 1, bndry_facets)
bc = DirichletBC(electric_wall, bdofs)
#B = assemble_matrix(b, bcs=[], restriction=(restriction_W_Gamma, restriction_W_Gamma))
B = assemble_matrix(b, [bc])
B.assemble()
#C = assemble_matrix(c, bcs=[], restriction=(restriction_W_Gamma, restriction_W_Gamma))
C = assemble_matrix(c, [bc])
C.assemble()
eps = SLEPc.EPS()
eps.create()
eps.setOperators(B, C)
eps.setDimensions(100)
eps.solve()
n = eps.getConverged()
print(n)
xr, xi = B.getVecs()
for j in range(n):
lam = eps.getEigenpair(j, xr, xi)
if (((1-1/lam)*theta_sqr)**0.5).real > 0.0002 and abs((((1-1/lam)*theta_sqr)**0.5).imag) < 1:
print(lam)
print(((1-1/lam)*theta_sqr)**0.5, 'wave number')
x_r = Function(W)
xr.copy(x_r.vector)
x_i = Function(W)
xi.copy(x_i.vector)
xt_r, xz_r = x_r.split()
xt_i, xz_i = x_i.split()
with XDMFFile(MPI.COMM_WORLD, "Et_r.xdmf", 'w',
encoding=XDMFFile.Encoding.HDF5) as file:
file.write_mesh(mesh)
file.write_function(xt_r)
with XDMFFile(MPI.COMM_WORLD, "Ez_r.xdmf", 'w',
file.write_function(xz_r)
with XDMFFile(MPI.COMM_WORLD, "Et_i.xdmf", 'w',
file.write_function(xt_i)
with XDMFFile(MPI.COMM_WORLD, "Ez_i.xdmf", 'w',
file.write_function(xz_i)
break
Your help is appreciated.
