I am trying to solve a 3D electromagnetic wave propagation problem in which the incident wave is excited from a port boundary at the top (z=fov_z/2) and the same is absorbed by another port boundary at the bottom (z=-fov_z/2). I cannot figure my way on the following:
- How to define nxE=0 boundary condition where I want? I mean, how do we code that only the dofs corresponding to the tangential components of the field to be zero and not the normal?
- An error message I cannot crack when I run the code.
Thanks in advance for the help. Below is my MWE which I am running on dolfinx 0.6.0:
import dolfinx, mpi4py, gmsh, ufl, petsc4py
from dolfinx.io import gmshio
import typing
#%% Input parameters
fov_x, fov_y, fov_z = 1, 1, 2 # in um
t_film = 0.1 # film thickness
dpml = 0.1 # thickness of pmls
port_bnd = (6, 5) # incident and transmitted port
wlen = 1 # in um
U0 = 1 # incident amplitude
theta = 0
#%% Create geometry
def create_geom():
gmsh.option.setNumber("General.Terminal", 0) # disable output messages
gmsh.clear()
gdim = 3
model_rank = 0
box1 = gmsh.model.occ.addBox(-fov_x/2, -fov_y/2, -fov_z/2, fov_x, fov_y, fov_z)
gmsh.model.occ.synchronize()
# number all domains
all_doms = gmsh.model.getEntities(gdim)
for j, edge in enumerate(all_doms):
gmsh.model.addPhysicalGroup(edge[0], [edge[1]], j + 1) # create the main group/node
# number all boundaries
all_edges = gmsh.model.getEntities(gdim - 1)
for j, edge in enumerate(all_edges):
gmsh.model.mesh.refine()
# gmsh.write('geom/plane_wave_mwe.msh')
model_rank = 0
mesh, ct, ft = gmshio.model_to_mesh(gmsh.model, mpi4py.MPI.COMM_WORLD, model_rank, gdim)
gmsh.fltk.run() # visible inspection, for debugging
gmsh.finalize()
return mesh, ct, ft
mesh, ct, ft = create_geom() # create fenics geometry, cell tags and facet tags
elem = ufl.FiniteElement('Nedelec 1st kind H(curl)', mesh.ufl_cell(), degree=2)
Omega = dolfinx.fem.FunctionSpace(mesh, elem)
k0 = dolfinx.fem.Constant(mesh, 2*np.pi/wlen) # vacuum wave number
U = ufl.TrialFunction(Omega)
Ut = ufl.TestFunction(Omega)
dx = ufl.Measure("dx", mesh, subdomain_data=ct) # for selective integration in domains
p_param = 1 # to be modified later
q_param = 1 # to be modified later
# weak form in the volume
F = (p_param*ufl.inner(ufl.curl(U), ufl.curl(Ut)) - k0**2*q_param*ufl.inner(U, Ut))*ufl.dx
#%% boundary conditions
class PlaneWave:
def __init__(self, U0:tuple, k0:float, n:complex=1, theta:float=0):
self.U0 = U0 # amplitude
self.theta = theta # incident angle
self.k0 = k0 # vacuum wavevector
self.n = n # refractive index
def eval(self, x: np.typing.NDArray[np.float64]) -> typing.Tuple[
np.typing.NDArray[np.complex128],
np.typing.NDArray[np.complex128]]:
kx = self.k0 * self.n * np.sin(self.theta)
ky = 0
kz = self.k0 * self.n * np.cos(self.theta)
phi = kx * x[0] + ky * x[1] + kz * x[2]
return (self.U0[0] * np.exp(1j * phi), self.U0[1] * np.exp(1j * phi), self.U0[2] * np.exp(1j * phi))
n = ufl.FacetNormal(mesh) # boundary normal vector
ds = ufl.Measure("ds", domain=mesh, subdomain_data=ft) # boundary differential element
kxi = dolfinx.fem.Constant(mesh, 0.0)
kzi = dolfinx.fem.Constant(mesh, np.sqrt(k0.value**2-kxi.value**2)) # incident medium
kzt = dolfinx.fem.Constant(mesh, np.sqrt(k0.value**2-kxi.value**2)) # transmitted medium
ki = ufl.as_vector((kxi, 0, -kzi)) # incident, going in -z direction
kr = ufl.as_vector((kxi, 0, kzi)) # reflected, going in +z direction
kt = ufl.as_vector((kxi, 0, -kzt)) # transmitted, going in -z direction
# U_inc = ufl.as_vector((0, U0, 0))
pw_inc = PlaneWave((0,U0,0), k0.value, 1, 0)
U_inc = dolfinx.fem.Function(Omega)
U_inc.interpolate(pw_inc.eval)
bc_inc_abs = ufl.inner(-1j*kzi*U, Ut)*ds(port_bnd[0]) # incident port
bc_tr_abs = ufl.inner(-1j*kzt*U, Ut)*ds(port_bnd[1]) # transmission port
bc_inc_exc = ufl.inner(2j*kzi*U_inc, Ut)*ds(port_bnd[0]) # incident port excitation
F += bc_inc_abs
F += bc_tr_abs
F += bc_inc_exc
a = ufl.lhs(F)
L = ufl.rhs(F)
# dirichlet: set the polarization componets x,z zero
# for p-pol, it amounts to choosing PMC while for s-polarization PEC
# QUESTION: Is this correct way of doing nxE = 0?
def perfect_cond_bnd(x:np.typing.NDArray[np.float64]):
'''identify pec/pmc planes for s/p polarization'''
return np.isclose(np.abs(x[1]), fov_y/2)
gdim=3
perfect_cond_facets = dolfinx.mesh.locate_entities_boundary(mesh, gdim-1, perfect_cond_bnd)
perfect_cond_dofs = dolfinx.fem.locate_dofs_topological(Omega, mesh.topology.dim-1, perfect_cond_facets)
ubc = dolfinx.fem.Function(Omega)
ubc.x.set(0+0j)
bc_perfect_cond = dolfinx.fem.dirichletbc(ubc, perfect_cond_dofs)
#%% solve
Lin_system = dolfinx.fem.petsc.LinearProblem(a, L, bcs = [bc_perfect_cond], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
U_sol = Lin_system.solve()
