Magnetomechanical static coupled problem compared with commercial software
Hi everyone,
I’m analyzing the magneto mechanical static 2D problem of a ferromagnetic bar influenced by an electromagnet, the image below describes the geometry:
All materials are assumed isotropic and the ferromagnetic material is considered as linear. Later, I’ll try to implement the nonlinearities of the material and analyze the modal response (also seeking for advise in these matters).
When comparing with a commercial software (COMSOL) I’m getting a lot of difference in the displacement results.
Thanks for reading and any help is appreciated.
here’s the code:
from math import sin, cos, pi
import time
w = 0.2
h = 3.5
eh = 0.1
Ab = w * h  #coil area
domain = Rectangle(Point(0, 0), Point(8, 8))
#geometry
inf_arm = Rectangle(Point(1, 2), Point(6, 1))
lef_arm = Rectangle(Point(1, 6), Point(2, 2))
sup_arm = Rectangle(Point(1, 7), Point(6, 6))
arm = Rectangle(Point(6.1, 7), Point(7.1, 1))
core = sup_arm + inf_arm + lef_arm
coil1 = Rectangle(Point(0.7, 5.7), Point(0.9, 2.2))
coil2 = Rectangle(Point(2.1, 5.7), Point(2.3, 2.2))
domain.set_subdomain(1, core)
domain.set_subdomain(2, coil1)
domain.set_subdomain(3, coil2)
domain.set_subdomain(4, arm)
mesh = generate_mesh(domain, 64)
mu_0 = 4 * pi * 1e-7
mu_ra = 1500
mu_rc = 1
class Permeability(UserExpression):
        super(Permeability, self).__init__(**kwargs)
        self.markers = markers
        if self.markers[cell.index] == 0:
            values[0] =  mu_0 #vac perm
        elif self.markers[cell.index] == 1:
            values[0] = mu_ra * mu_0   # iron perm
        elif self.markers[cell.index] == 4:
            values[0] = mu_rc * mu_0
mu = Permeability(markers, degree=1)
perm = project(mu, FunctionSpace(mesh, "DG", 0))
# current (A)
I_s = Constant(1)
I_e = Constant(-1)
# magnetostatic
VE = FunctionSpace(mesh, 'P', 2)
A_z = TrialFunction(VE)
v_E = TestFunction(VE)
aE = (1 / mu) * dot(grad(A_z), grad(v_E)) * dx
N1_s = I_s * v_E * dx(2)
N1_e = I_e * v_E * dx(3)
LE = (1 / Ab) * (N1_s + N1_e)
bcE = DirichletBC(VE, Constant(0), 'on_boundary')
Az = Function(VE)
solve(aE == LE, Az, bcE)
W = VectorFunctionSpace(mesh, 'DG', 0)
B = project(as_vector((Az.dx(1), -Az.dx(0))), W)
Bx = Az.dx(1)
By = -Az.dx(0)
Hx = Bx / mu
Hy = By / mu
Fx = mu * Hx * Hy * eh
Fy = (0.5 * mu) * (Hy ** 2 - Hx ** 2) * eh
dF = project(as_vector((Fx, Fy)), W)
f = dF
E = Constant(212E6)
nu = Constant(0.3)
lmbda = (E * nu) / ((1 + nu) * (1 - 2 * nu))
miu = E / 2 / (1 + nu)
Vi = VectorFunctionSpace(mesh, 'Lagrange', 2)
def eps(v):
    return sym(grad(v))
def sigma(v):
    return lmbda * tr(eps(v)) * Identity(2) + 2.0 * miu * eps(v)
class Solid(SubDomain):
        return between(x[0], (6.1, 7.1)) and between(x[1], (1.0, 7.0))
subdomain_marker = MeshFunction("size_t", mesh, mesh.geometry().dim(), 0)
Solid().mark(subdomain_marker, 1)
class Boundary(SubDomain):
        tol = 1e-14
        return between(x[0], (6.1, 7.1)) and x[1] == 1
boundary_marker = MeshFunction("size_t", mesh, mesh.geometry().dim() - 1, 0)
arm_bound = Boundary()
Boundary().mark(boundary_marker, 2)
du = TrialFunction(Vi)
u_ = TestFunction(Vi)
a = inner(sigma(du), eps(u_)) * dx(4)
fm = inner(f, u_) * dx(4)
start = time.time()
bc = DirichletBC(Vi, Constant((0, 0)), boundary_marker, 2)
u = Function(Vi, name="Displacement")
solve(a == fm, u, bc)
I’m comparing with comsol in order to validate the results of the code, so I’m expecting to have values approximated to the comsol results.
The code that you have supplied does not run, using the latest release of dolfin.
I have done several modifications to the code to make it executable. Please carefully look through the code to make sure you understand the differences
import time
w = 0.2
h = 3.5
eh = 0.1
Ab = w * h  # coil area
# geometry
mu_ra = 1500
mu_rc = 1
            values[0] = mu_0  # vac perm
markers = MeshFunction("size_t", mesh, mesh.topology().dim(), mesh.domains())
# current (A)
I_s = Constant(1)
I_e = Constant(-1)
# magnetostatic
dxC = Measure("dx", domain=mesh, subdomain_data=markers)
aE = (1 / mu) * dot(grad(A_z), grad(v_E)) * dxC
N1_s = I_s * v_E * dxC(2)
N1_e = I_e * v_E * dxC(3)
Az = Function(VE)
Bx = Az.dx(1)
By = -Az.dx(0)
Hx = Bx / mu
Hy = By / mu
f = dF
E = Constant(212E6)
nu = Constant(0.3)
def eps(v):
    return sym(grad(v))
def sigma(v):
        tol = 1e-14
a = inner(sigma(du), eps(u_)) * dxC(4)
fm = inner(f, u_) * dxC(4)
start = time.time()
A = assemble(a, keep_diagonal=True)
b = assemble(fm)
A.ident_zeros()
bc.apply(A, b)
solve(A, u.vector(), b)
XDMFFile("u.xdmf").write_checkpoint(u, "u", 0)
Thank you!, yes I realize I omitted the markers definition. And you added the lines where the matrix is defined.
cheers
