I’ve been spending a lot of time recently trying to use FEniCS for electromagnetics simulation, and have managed to get the magnetostatics demo working, using pygmsh for the mesh generation and dolfinx for solving. I am new to FEniCS and FEM simulation so I’m not sure all of my modifications were valid, but I figured I would post the code in any case if it is useful for others. I haven’t compared the result to the working example in dolfin (to do) but the magnetic vector potential result looks superficially similar.
Mesh generation:
from pygmsh.opencascade import Geometry
from pygmsh import generate_mesh
a = 1.0 # inner radius of iron cylinder
b = 1.2 # outer radius of iron cylinder
c_1 = 0.8 # radius for inner circle of copper wires
c_2 = 1.4 # radius for outer circle of copper wires
r = 0.1 # radius of copper wires
R = 5.0 # radius of domain
n = 10 # number of windings
lc1 = 0.1 #Maximum length of mesh
lc2 = 0.05
lc3 = 0.03
geom = Geometry()
center_point = [0,0,0]
# Define geometry for wires (N = North (up), S = South (down))
angles_N = [i*2*np.pi/n for i in range(n)]
angles_S = [(i + 0.5)*2*np.pi/n for i in range(n)]
wires_N = [geom.add_disk([c_1*np.cos(v), c_1*np.sin(v),0], r, char_length=lc3) for v in angles_N]
wires_S = [geom.add_disk([c_2*np.cos(v), c_2*np.sin(v), 0], r, char_length=lc3) for v in angles_S]
wires_N = geom.boolean_union(wires_N)
wires_S = geom.boolean_union(wires_S)
circle1 = geom.add_disk([0,0,0], b, char_length=lc2)
circle2 = geom.add_disk(center_point, a, char_length=lc2)
cylinder = geom.boolean_difference([circle1], [circle2])
#wires = wires_S+wires_N
domain = geom.add_disk(center_point, R, char_length=lc1)
domain_sub = geom.boolean_difference([domain], [wires_S]+[wires_N]+[cylinder], delete_other=False)
system = geom.boolean_fragments([domain_sub], [cylinder]+[wires_S]+[wires_N])
geom.add_raw_code("Physical Surface(1) = {" + cylinder.id + "};")
geom.add_raw_code("Physical Surface(2) = {" + wires_N.id + "};")
geom.add_raw_code("Physical Surface(3) = {" + wires_S.id + "};")
geom.add_raw_code("Physical Surface(4) = {" + domain_sub.id + "};")
geom.add_raw_code("Physical Curve(1) = {24};")
mesh = generate_mesh(geom, geo_filename = "test.geo", prune_z_0 = True)
# What follows is this (strange) mesh conversion stuff ... . ;-)
line_cells = None
line_data = None
triangle_cells = None
triangle_data = None
for key in mesh.cell_data_dict["gmsh:physical"].keys():
if key == "triangle":
triangle_data = mesh.cell_data_dict["gmsh:physical"][key]
print(set(triangle_data))
elif key == "line":
line_data = mesh.cell_data_dict["gmsh:physical"][key]
for cell in mesh.cells:
if cell.type == "line":
if line_cells is None:
line_cells = cell.data
line_cells = np.vstack([line_cells, cell.data])
elif cell.type == "triangle":
if triangle_cells is None:
triangle_cells = cell.data
triangle_cells = np.vstack([triangle_cells, cell.data])
line_mesh = meshio.Mesh(points=mesh.points,
cells={"line": line_cells},
cell_data={"name_to_read":[line_data]})
triangle_mesh =meshio.Mesh(points=mesh.points,
meshio.xdmf.write("line_mesh.xdmf", line_mesh)
meshio.xdmf.write("triangle_mesh.xdmf", triangle_mesh)
Solver:
from dolfinx import Mesh, geometry, Function, DirichletBC, Constant, solve, FunctionSpace
from dolfinx.plotting import plot
from ufl import TrialFunction, TestFunction, dot, grad, dx, inner, Measure
comm = MPI.COMM_WORLD
with XDMFFile(MPI.COMM_WORLD,"triangle_mesh.xdmf",'r') as infile:
mesh = infile.read_mesh(dolfinx.cpp.mesh.GhostMode.none, name="Grid")
with XDMFFile(MPI.COMM_WORLD, "triangle_mesh.xdmf", "r") as xdmf_infile:
mt = xdmf_infile.read_meshtags(mesh, name="Grid")
with XDMFFile(MPI.COMM_WORLD, "line_mesh.xdmf", "r") as xdmf_infile:
mt_line = xdmf_infile.read_meshtags(mesh, name="Grid")
n=10 #ten wires on each side of the cylinder
# Define function space
CG = ufl.FiniteElement("P", mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, CG)
# Define boundary condition
inner_facets = mt_line.indices[mt_line.values == 1]
dofs_outer = dolfinx.fem.locate_dofs_topological(V, 1, inner_facets)
ubcOuter = Function(V)
ubcOuter.vector.set(0)
bc = DirichletBC(ubcOuter, dofs_outer)
#bc = DirichletBC(V, Constant(mesh, 0), 'on_boundary')
# Define subdomain markers and integration measure
dx = Measure('dx', domain=mesh, subdomain_data=mt)
# Define current densities
J_N = Constant(mesh, 1.0)
J_S = Constant(mesh, -1.0)
#Locate wires
facets_N = mt.indices[mt.values == 2]
dofs_N = dolfinx.fem.locate_dofs_topological(V, 2, facets_N)
facets_S = mt.indices[mt.values == 3]
dofs_S = dolfinx.fem.locate_dofs_topological(V, 2, facets_S)
facets_cylinder = mt.indices[mt.values == 1]
dofs_cylinder = dolfinx.fem.locate_dofs_topological(V, 2, facets_cylinder)
#determine if coordinate is in wire:
#First generate the list of coordinates that is within wire_N
dof_array = V.dofmap.list.array()
coordinates = V.tabulate_dof_coordinates()
coords_cylinder = coordinates[dofs_cylinder[:,0]]
coords_N = coordinates[dofs_N[:,0]]
coords_S = coordinates[dofs_S[:,0]]
coords_copper = np.vstack((coords_N, coords_S))
# Define magnetic permeability
def permeability(x):
#initialize vector to be returned
perm = np.full(x.shape[1], 0, dtype=np.float64)
for i in range(x.shape[1]):
#Wire
if np.any(np.all(x[:,i]==coords_copper, axis=1)):
perm[i] = 1.26e-3
elif np.any(np.all(x[:,i]==coords_cylinder, axis=1)):
perm[i] = 1e-5 # Iron (but not right)
perm[i] = 4*np.pi*1e-7
print(perm)
return perm
mu = Function(V)
mu.interpolate(permeability)
#def in_wire_N(x):
# #Generate boolean array
# for i in x.shape[1]:
# if x[:,] in coords_N
A_z = TrialFunction(V)
a = (1 / mu)*inner(grad(A_z), grad(v))*dx
L_N = inner(J_N,v)*dx(2)
L_S = inner(J_S,v)*dx(3)
L = L_N + L_S
# Solve variational problem
A_z = Function(V)
solve(a == L, A_z, bc)
with XDMFFile(MPI.COMM_WORLD, "A_z.xdmf", "w") as file:
file.write_mesh(mesh)
file.write_function(A_z)
# Compute magnetic field (B = curl A)
#W = VectorFunctionSpace(mesh, 'P', 1)
#B = project(as_vector((A_z.dx(1), -A_z.dx(0))), W)
The most hacky part of the demo is the interpolation of mu, I couldn’t find an elegant way in dolfinx to have mu be determined topologically rather than by coordinate. So until I find such a utility function, I have a search function that maps each coordinate to a subdomain. Is there an elegant way to do this in dolfinx?
My last question is about the project() function. I couldn’t find it in dolfinx, is there a way to achieve the same functionality currently?
