Major problem ImportError FFCX
Dear Community,
Since yesterday I have an import error of FFCX each time I try to use form(). Here is the MWE and the bug associated. But before, for the record : I’m using apple silicon M3 and my architecture was based on conda, and I deeply need the complex value architecture of FEniCSx
MWE :
from dolfinx.io import gmshio
from ufl import (TestFunction, TrialFunction,
                 Measure,
                 FacetNormal,
                 inner, grad, div,
                 Dn)
from basix.ufl import element
from dolfinx.fem import functionspace, form, petsc
def generate_cube_gmshio(side_length=1.0, filename="cube.msh"):
    Generate a cube with side length `side_length`,
    export the mesh to `filename`, and
    return (final_mesh, cell_tags, facet_tags).
    # Initialize the Gmsh API
    # Retrieve the MPI communicator and rank
    comm = MPI.COMM_WORLD
    model_rank = 0
    # Reference the Gmsh model
    model = gmsh.model
    model.add("cube")
    # Create the cube with the OpenCASCADE kernel
    # (x, y, z, dx, dy, dz)
    box_tag = model.occ.addBox(0, 0, 0, side_length, side_length, side_length)
    # Synchronize the geometry
    model.occ.synchronize()
    # (Optional) add a physical group for the volume (tag=1)
    model.addPhysicalGroup(3, [box_tag], tag=1)
    # Generate the 3D mesh with second-order elements
    gmsh.option.setNumber("Mesh.ElementOrder", 2)
    gmsh.option.setNumber("Mesh.HighOrderOptimize", 2)
    model.mesh.generate(3)
    # Save the mesh to a .msh file
    gmsh.write(filename)
    # Convert the Gmsh mesh into a FEniCSx mesh
    final_mesh, cell_tags, facet_tags = gmshio.model_to_mesh(
        model, comm, model_rank
    # Finalize Gmsh
    gmsh.finalize()
    # Return the objects describing the mesh in FEniCSx
    return final_mesh, cell_tags, facet_tags
# Example usage:
if __name__ == "__main__":
    # Generate a cube mesh and retrieve mesh data
    final_mesh, cell_tags, facet_tags = generate_cube_gmshio(1.0, "cube.msh")
    # Define volume (dx) and surface (ds) measures
    dx = Measure("dx", domain=final_mesh)
    # Define a Lagrange element of degree 3
    P1 = element("Lagrange", final_mesh.basix_cell(), 2)
    P = functionspace(final_mesh, P1)
    p, v = TrialFunction(P), TestFunction(P)
    # Define the volumetric bilinear form
    k = inner(p, v) * dx
    # Assemble the total form
    A = form(k)
The error :
  File "/opt/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 97, in get_cached_module
    with open(c_filename, "x"):
FileExistsError: [Errno 17] File exists: '/Users/pierremariotti/.cache/fenics/libffcx_forms_8ff3a977f949229519a3cca1fb86ddf3d3d6c342.c'
  File "/Users/pierremariotti/Documents/PhD/FEniCSx/new_try2/root/ABC_FEniCSx_classical/mwe_FEniCSx.py", line 78, in <module>
    A = form(k)
  File "/opt/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 337, in form
    return _create_form(form)
  File "/opt/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 331, in _create_form
    return _form(form)
  File "/opt/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 254, in _form
    ufcx_form, module, code = jit.ffcx_jit(
  File "/opt/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/dolfinx/jit.py", line 62, in mpi_jit
  File "/opt/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/dolfinx/jit.py", line 212, in ffcx_jit
  File "/opt/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 188, in compile_forms
    obj, mod = get_cached_module(module_name, form_names, cache_dir, timeout)
  File "/opt/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 114, in get_cached_module
    compiled_module = importlib.util.module_from_spec(spec)
  File "<frozen importlib._bootstrap>", line 571, in module_from_spec
  File "<frozen importlib._bootstrap_external>", line 1176, in create_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
ImportError: dlopen(/Users/pierremariotti/.cache/fenics/libffcx_forms_8ff3a977f949229519a3cca1fb86ddf3d3d6c342.cpython-310-darwin.so, 0x0002): tried: '/Users/pierremariotti/.cache/fenics/libffcx_forms_8ff3a977f949229519a3cca1fb86ddf3d3d6c342.cpython-310-darwin.so' (duplicate LC_RPATH '/opt/anaconda3/envs/env3-10-complex/lib'), '/System/Volumes/Preboot/Cryptexes/OS/Users/pierremariotti/.cache/fenics/libffcx_forms_8ff3a977f949229519a3cca1fb86ddf3d3d6c342.cpython-310-darwin.so' (no such file), '/Users/pierremariotti/.cache/fenics/libffcx_forms_8ff3a977f949229519a3cca1fb86ddf3d3d6c342.cpython-310-darwin.so' (duplicate LC_RPATH '/opt/anaconda3/envs/env3-10-complex/lib')
And all I tried was removing the cache with
rm -rf ~/.cache/fenics
Thanks for the support,
I’m supposed to submit my article very soon and I need to recover some results..
Dear @pierremrtt,
What error message do you get when removing the “cached” form file at:
Looking further at your error message, it looks related to:
See the suggested resolution in the post:
I’m not sure what happened so I’m going to give it line by line :
I firstly removed the file quoted using
rm -rf /Users/pierremariotti/.cache/fenics/libffcx_forms_8ff3a977f949229519a3cca1fb86ddf3d3d6c342.c
which didn’t gave any error or message.
I re-run my script and the following error appeared :
ld: warning: duplicate -rpath '/opt/anaconda3/envs/env3-10-complex/lib' ignored
  File "/Users/pierremariotti/Documents/PhD/FEniCSx/new_try2/root/ABC_FEniCSx_classical/mwe_FEniCSx.py", line 79, in <module>
    A = form(k)
    return _form(form)
  File "/opt/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 225, in compile_forms
    raise e
  File "/opt/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 205, in compile_forms
    impl = _compile_objects(
  File "/opt/anaconda3/envs/env3-10-complex/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 390, in _compile_objects
    fd = open(ready_name, "x")
FileExistsError: [Errno 17] File exists: '/Users/pierremariotti/.cache/fenics/libffcx_forms_8ff3a977f949229519a3cca1fb86ddf3d3d6c342.c.cached'
So I removed the “cached” file, the same one but with “.cached” added at the end :
rm -rf /Users/pierremariotti/.cache/fenics/libffcx_forms_8ff3a977f949229519a3cca1fb86ddf3d3d6c342.c.cached
Still no message out of this command.
Then I re-re-run the code and now it works. As I receated a conda env now I have to re install all lib like matplotlib and so on but it looks like it worked. And you are right @dokken , the topic is exactly related. If I face again the error, I’ll go to check.
I’ve built again all the libraries I need and the problem is back
FileExistsError: [Errno 17] File exists: '/Users/pierremariotti/.cache/fenics/libffcx_forms_9b983cebf9ff7ad90e3f6922a3beee48e45114fa.c'
  File "/Users/pierremariotti/Documents/PhD/FEniCSx/new_try2/root/ABC_FEniCSx_classical/test_oldABCnewVn.py", line 72, in <module>
    ope     = B2p(mesh_)
  File "/Users/pierremariotti/Documents/PhD/FEniCSx/new_try2/root/ABC_FEniCSx_classical/operators_POO.py", line 1029, in __init__
    self.list_D = self.b2p_newVersion()
  File "/Users/pierremariotti/Documents/PhD/FEniCSx/new_try2/root/ABC_FEniCSx_classical/operators_POO.py", line 1081, in b2p_newVersion
    K = form(k)
    return _form(form)
ImportError: dlopen(/Users/pierremariotti/.cache/fenics/libffcx_forms_9b983cebf9ff7ad90e3f6922a3beee48e45114fa.cpython-310-darwin.so, 0x0002): tried: '/Users/pierremariotti/.cache/fenics/libffcx_forms_9b983cebf9ff7ad90e3f6922a3beee48e45114fa.cpython-310-darwin.so' (duplicate LC_RPATH '/opt/anaconda3/envs/env3-10-complex/lib'), '/System/Volumes/Preboot/Cryptexes/OS/Users/pierremariotti/.cache/fenics/libffcx_forms_9b983cebf9ff7ad90e3f6922a3beee48e45114fa.cpython-310-darwin.so' (no such file), '/Users/pierremariotti/.cache/fenics/libffcx_forms_9b983cebf9ff7ad90e3f6922a3beee48e45114fa.cpython-310-darwin.so' (duplicate LC_RPATH '/opt/anaconda3/envs/env3-10-complex/lib')
I’m going to check in the post you shared.
Thanks
