Error occuring in fem.form
Dear all,
I recently bought a new computer and installed fenicsx (0.6.0) on WSL2 (Ubuntu) through anaconda.
I tried to run some old code on my new computer (same version of fenicsx as before), and while the first time it ran, it ran fine, but the second time when I changed a variable in my fem.form (e.g. dt) I got an error. The code I used here to generate the error is just an adapted version of the heat equation tutorial (I know it can be done more efficiently as is done in the real tutorial, but I have the same error for code where both the bilinear and linear form are time-dependent so this is the easiest similar case I could come up with. Update: I also get the exact same error when completely copy-pasting the tutorial):
from dolfinx import fem, mesh, io, plot
# Define temporal parameters
t = 0 # Start time
T = 1.0 # Final time
num_steps = 50
# Define mesh
nx, ny = 50, 50
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([-2, -2]), np.array([2, 2])],
                               [nx, ny], mesh.CellType.triangle)
# Create initial condition
def initial_condition(x, a=5):
    return np.exp(-a*(x[0]**2+x[1]**2))
u_n = fem.Function(V)
u_n.name = "u_n"
u_n.interpolate(initial_condition)
# Create boundary condition
boundary_facets = mesh.locate_entities_boundary(
    domain, fdim, lambda x: np.full(x.shape[1], True, dtype=bool))
bc = fem.dirichletbc(PETSc.ScalarType(0), fem.locate_dofs_topological(V, fdim, boundary_facets), V)
xdmf = io.XDMFFile(domain.comm, "diffusion.xdmf", "w")
xdmf.write_mesh(domain)
# Define solution variable, and interpolate initial solution for visualization in Paraview
uh = fem.Function(V)
uh.name = "uh"
uh.interpolate(initial_condition)
xdmf.write_function(uh, t)
f = fem.Constant(domain, PETSc.ScalarType(0))
for i in range(num_steps):
    a = u * v * ufl.dx + dt*ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
    L = (u_n + dt * f) * v * ufl.dx
    bilinear_form = fem.form(a)
    linear_form = fem.form(L)
    A = fem.petsc.assemble_matrix(bilinear_form, bcs=[bc])
    b = fem.petsc.create_vector(linear_form)
    fem.petsc.set_bc(b, [bc])
    b.assemble()
    solver.setOperators(A)
    # Solve linear problem
    solver.solve(b, uh.vector)
    u_n.x.array[:] = uh.x.array
    # Write solution to file
xdmf.close()
The error I got out is the following:
INFO:root:running build_ext
INFO:root:building 'libffcx_forms_1790fb3e8ead4c2bdbfebd6a45e3be2c80395974' extension
INFO:root:/home/rsmeets/anaconda3/envs/fenicsx/bin/x86_64-conda-linux-gnu-cc -Wno-unused-result -Wsign-compare -DNDEBUG -fwrapv -O2 -Wall -fPIC -O2 -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -fPIC -O2 -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -march -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/rsmeets/anaconda3/envs/fenicsx/include -DNDEBUG -D_FORTIFY_SOURCE -fPIC -I/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ffcx/codegeneration -I/home/rsmeets/anaconda3/envs/fenicsx/include/python3.10 -c libffcx_forms_1790fb3e8ead4c2bdbfebd6a45e3be2c80395974.c -o ./libffcx_forms_1790fb3e8ead4c2bdbfebd6a45e3be2c80395974.o -O2 -g0
x86_64-conda-linux-gnu-cc: error: unrecognized command-line option '-march'
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/setuptools/_distutils/unixccompiler.py", line 185, in _compile
    self.spawn(compiler_so + cc_args + [src, '-o', obj] + extra_postargs)
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/setuptools/_distutils/ccompiler.py", line 1041, in spawn
    spawn(cmd, dry_run=self.dry_run, **kwargs)
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/setuptools/_distutils/spawn.py", line 70, in spawn
    raise DistutilsExecError(
distutils.errors.DistutilsExecError: command '/home/rsmeets/anaconda3/envs/fenicsx/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/cffi/ffiplatform.py", line 51, in _build
    dist.run_command('build_ext')
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/setuptools/dist.py", line 989, in run_command
    super().run_command(command)
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
    cmd_obj.run()
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/setuptools/command/build_ext.py", line 88, in run
    _build_ext.run(self)
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 345, in run
    self.build_extensions()
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 467, in build_extensions
    self._build_extensions_serial()
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 493, in _build_extensions_serial
    self.build_extension(ext)
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/setuptools/command/build_ext.py", line 249, in build_extension
    _build_ext.build_extension(self, ext)
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 548, in build_extension
    objects = self.compiler.compile(
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/setuptools/_distutils/ccompiler.py", line 600, in compile
    self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts)
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/setuptools/_distutils/unixccompiler.py", line 187, in _compile
    raise CompileError(msg)
distutils.errors.CompileError: command '/home/rsmeets/anaconda3/envs/fenicsx/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
  File "/home/rsmeets/coding/biolin/minworkexample.py", line 53, in <module>
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 176, in form
    return _create_form(form)
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 171, in _create_form
    return _form(form)
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 145, in _form
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/jit.py", line 56, in mpi_jit
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/dolfinx/jit.py", line 204, in ffcx_jit
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 186, in compile_forms
    impl = _compile_objects(decl, forms, form_names, module_name, p, cache_dir,
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 270, in _compile_objects
    ffibuilder.compile(tmpdir=cache_dir, verbose=True, debug=cffi_debug)
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/cffi/api.py", line 725, in compile
    return recompile(self, module_name, source, tmpdir=tmpdir,
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/cffi/recompiler.py", line 1564, in recompile
    outputfilename = ffiplatform.compile('.', ext,
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/cffi/ffiplatform.py", line 22, in compile
    outputfilename = _build(tmpdir, ext, compiler_verbose, debug)
  File "/home/rsmeets/anaconda3/envs/fenicsx/lib/python3.10/site-packages/cffi/ffiplatform.py", line 58, in _build
    raise VerificationError('%s: %s' % (e.__class__.__name__, e))
cffi.VerificationError: CompileError: command '/home/rsmeets/anaconda3/envs/fenicsx/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
I think the real error is in the third section and thus seems to have to do something with fem.form (I see these first two blocks almost always when there is an error with the third block). I have the same error with other code where I want to change parameters in fem.form. Has anyone encountered this problem before and/or knows how to solve it? I have tried deleting the environment with fenicsx and the package, and reinstalling but that did not work unfortunately.
Many thanks,
Robin
I am sorry, I know that this may not be a big help, but the code runs without error on my PC via ubuntu WSL2 in Windows 11, everything in latest versions.
Hi Belmont, thanks for replying :slight_smile:
I’m pretty sure I have the exact same (Windows 11, WSL2, Ubuntu, latest versions), which is the more reason I’m confused of what is happening haha
I ran your code in a the dolfinx tutorial docker image.
It is just a few commands and one can easily start using dolfinx.
docker pull ghcr.io/jorgensd/dolfinx-tutorial:v0.6.0.post0
Once the pull is complete, run the following command
docker run -ti -p 8888:8888 -v "$(pwd)":/root/ ghcr.io/jorgensd/dolfinx-tutorial:v0.6.0.post0
  1. Open a browser and access jupyter-lab where you can create a new notebook, paste your code and run it.
http://127.0.0.1:8888/
Your code runs without giving the errors that you mention.
Hi Ampdes,
Thank you for your reply :slight_smile: . On my old laptop I did work through docker and never had this issue, and so I absolutely believe that this would work. But it should work on Windows 11 through Ubuntu WSL2 and anaconda as well right?
I’ve also been having a similar issue, but I have no idea what is happening. Seems to have started with the installation of dolfinx v0.6.0 when I upgraded from v0.5.x
I’m running dolfinx in a conda environment (can provide full package list if it is helpful) and working in VSCode. I was able to reproduce your error message once, but then if I re-run the exact same script in “debug mode”, the error goes away for subsequent runs. How in the world does that happen? (I’ve seen this happen for a few different scripts):
INITIAL RUN ERROR MESSAGE:
(MY_ENV) (base) usr@MACHINE:~/DIR$ /home/usr/anaconda3/envs/MY_ENV/bin/python "/home/usr/DIR/MWEfrompreviouspost.py"
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/setuptools/_distutils/unixccompiler.py", line 186, in _compile
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/setuptools/_distutils/ccompiler.py", line 1007, in spawn
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/setuptools/_distutils/spawn.py", line 70, in spawn
distutils.errors.DistutilsExecError: command '/home/usr/anaconda3/envs/MY_ENV/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/cffi/ffiplatform.py", line 51, in _build
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/setuptools/dist.py", line 1217, in run_command
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 987, in run_command
    cmd_obj.run()
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/setuptools/command/build_ext.py", line 84, in run
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 346, in run
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 466, in build_extensions
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 492, in _build_extensions_serial
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/setuptools/command/build_ext.py", line 246, in build_extension
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 547, in build_extension
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/setuptools/_distutils/ccompiler.py", line 599, in compile
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/setuptools/_distutils/unixccompiler.py", line 188, in _compile
distutils.errors.CompileError: command '/home/usr/anaconda3/envs/MY_ENV/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
  File "/home/usr/DIR/MWEfrompreviouspost.py", line 18, in <module>
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/dolfinx/fem/function.py", line 487, in __init__
    (self._ufcx_element, self._ufcx_dofmap), module, code = jit.ffcx_jit(
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/dolfinx/jit.py", line 56, in mpi_jit
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/dolfinx/jit.py", line 206, in ffcx_jit
    r = ffcx.codegeneration.jit.compile_elements([ufl_object], options=p_ffcx, **p_jit)
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 144, in compile_elements
    impl = _compile_objects(decl, elements, names, module_name, p, cache_dir,
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 270, in _compile_objects
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/cffi/api.py", line 725, in compile
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/cffi/recompiler.py", line 1564, in recompile
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/cffi/ffiplatform.py", line 22, in compile
  File "/home/usr/anaconda3/envs/MY_ENV/lib/python3.10/site-packages/cffi/ffiplatform.py", line 58, in _build
cffi.VerificationError: CompileError: command '/home/usr/anaconda3/envs/MY_ENV/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
Subsequent runs AFTER RUNNING IN DEBUG MODE, do not throw this same error. Very weird.
I also have a more complicated package that seems to keep throwing a similar error. The error seems to show up with the assembly of the RHS petsc vector, regardless of what that form looks like and even for forms that are assembled in a similar “spaghetti code” and run without throwing this error.
The error seems to show up at the creation of the RHS petsc vector
#...... SOME CODE ABOVE
self.b=create_vector(form(self.L_form))
#MORE CODE.....
Thank you! That seems indeed awfully similar to my error under the same circumstances. Does running it in debug mode fix it? And if so, how do you run in debug mode? :slight_smile:
Very strange, but seriously, all I’m doing is this after the error:
I’m not necessarily proposing this as a “fix”, but just noting it as something I’ve seen so far to help track down what’s going on.
This post also had some useful information. I noticed that I was having issues even importing some packages and certain code was throwing a PETSc Segmentation violation error in debug mode like this:
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
The solution in the linked post helped me get rid of my last ‘ComplieError’.
Thank you. I unfortunately did not manage to fix it and just decided to install docker and run it through there and that works. It must be something that goes wrong when installing it through anaconda but as it is all done automatically, I’m not quite what happens.
In any way, for those encountering the same error and who are looking for a solution, my best advice right now is to just run it through docker
e.g. in powershell run the command
docker run --rm -ti -v [path of your wanted directory]:[place holder name directory] dolfinx/dolfinx:stable
and then run the command:
cd [place holder name directory]
In my case that looks like:
docker run --rm -ti -v \\wsl.localhost\Ubuntu\home\rsmeets\coding:/opt/project dolfinx/dolfinx:stable
cd /opt/project
Ofcourse you should install docker to do this, but it is quite easy and straightforward.
tldr: no fix, try docker
