Manipulate components of mixed functions
Given a mixed function space, how to manipulate the “coefficient array views” that underly the components of a function? I would like to do something like
a,b = u.split()
a.vector().set_local(...)  # only set the data that belongs to a
b.vector().get_local(...) # only get the data that belongs to b
But a.vector(), b.vector(), u.vector() all point to the same object:
mesh = UnitIntervalMesh(10)
cell = mesh.ufl_cell()
el = MixedElement(
    FiniteElement("P", cell, 2),
    FiniteElement("P", cell, 1),
V = FunctionSpace(mesh, el)
a,b = u.split()
# these are the same vector:
assert id(a.vector()) == id(b.vector())
print(u.vector()) # <dolfin.cpp.la.PETScVector object at 0x7f6713c96f10>
print(a.vector()) # <dolfin.cpp.la.PETScVector object at 0x7f6713c96f10>
You’ll have to modify the following to work correctly in parallel, but here’s the gist of what you need to do:
el = MixedElement(
dm0 = V.sub(0).dofmap()
dm1 = V.sub(1).dofmap()
a_nodes = u.vector().vec()[dm0.dofs()]
b_nodes = u.vector().vec()[dm1.dofs()]
print(a_nodes)
print(b_nodes)
Ok thanks. That solves the “get” part of my problem, but not the “set” part as a_nodes is a copy. E.g.
a_nodes[:] = range(100, 121)
assert all(u.vector().vec()[:] == 0)
Edit: Okay the following works
u.vector().vec()[dm0.dofs()] = range(100, 121)
Is that the way to go or is there something more convenient? I would prefer to have a “view” on
u[dm0.dofs()] instead of passing u and dm0.dofs() around.
If you do
a, b = u.split(deepcopy=True)
you can access and set the dof values of the individual functions with e.g.
b.vector()[0] = 1
Of course, since you now have seperate arrays, these changes are not done in the original function u.
