How to get subarrays from mixed solution array
Dear all,
I’m trying to solve a system in FEniCSx using a mixed element, but I don’t know how get the arrays of the subfunctions back. My naive guess was to think that the first elements of the mixed element would correspond to the first space, and the last to the second space, but that does not seem to be the case. Using .split() and .sub(0) also seems to return the entire array instead of the parts. My other guess would be to use ufl.split() but in that case I don’t know how to get back the arrays belonging to them as those functions do not have the property x.array
Below first my try, and afterwards a different way of solving with substitution that outputs the correct values for the subarrays. The context is that of solving a porous medium type equation but that is not relevant for my question.
My try:
from dolfinx import mesh
from dolfinx.mesh import locate_entities, meshtags
from dolfinx.fem import FunctionSpace
from dolfinx import fem
from dolfinx import io
# Creating an interval as mesh
h = 0.25
x_min, x_max = -1,1
nx = int((x_max - x_min)/h)
domain = mesh.create_interval(MPI.COMM_WORLD, nx, points = (x_min, x_max))
x = ufl.SpatialCoordinate(domain) # Coordinates of domain used for defining general functions
el1 = ufl.FiniteElement("CG", domain.ufl_cell(), 1)
el2 = ufl.FiniteElement("DG", domain.ufl_cell(), 1)
mel = ufl.MixedElement([el1, el2])
Z = FunctionSpace(domain, mel)
V = FunctionSpace(domain, ("CG", 1))
U = FunctionSpace(domain, ("DG", 1))
w_trial, u_trial = ufl.TrialFunctions(Z)
w_test, u_test = ufl.TestFunctions(Z)
Z_sol = fem.Function(Z)
# Constants
m  = 2
alpha_par = 1/3
beta_par = 1/3
kappa_par = 1/12
C = 1/32
t_start  = 0.3
dt = 0.1
def Phi(u):
    return u**m
def exact_sol(x,t):
    return ufl.operators.max_value(0,1/(t**alpha_par) * (C - kappa_par * (ufl.operators.sqrt(x[0]**2)/(t**beta_par))**2 )**(1/(m-1)))
initial_u = exact_sol(x,t_start)
expr_u = fem.Expression(initial_u, U.element.interpolation_points())
# Defining the function spaces for all the functions
u_n = fem.Function(U)
u_n.name = "u_n"
u_n_i = fem.Function(U)
u_n_i.name = "u_n_i"
u_n.interpolate(expr_u)
u_n_i.interpolate(expr_u)
L_par = 1
L_const = fem.Constant(domain, ScalarType(L_par))
a = (u_trial * w_test + dt * ufl.inner(ufl.grad(w_trial), ufl.grad(w_test)) + L_const * u_trial * u_test - w_trial * u_test) * ufl.dx
L = (u_n * w_test + L_const * u_n_i * u_test - Phi(u_n_i) * u_test) * ufl.dx
bilinear_form = fem.form(a)
linear_form = fem.form(L)
b = fem.petsc.assemble_vector(linear_form)
b.assemble()
A = fem.petsc.assemble_matrix(bilinear_form)
solver.setType(PETSc.KSP.Type.PREONLY) # PREONLY means you only use the preconditioner
#solver.setTolerances(rtol=1e-12, atol = 1e-60)
solver.getPC().setType(PETSc.PC.Type.LU) # The LU preconditioner just solves the system using LU factorization.
solver.setOperators(A)
solver.solve(b, Z_sol.vector)
len_V = len(V.tabulate_dof_coordinates())
len_U = len(U.tabulate_dof_coordinates())
w_split, u_split = Z_sol.x.array[:len_V], Z_sol.x.array[len_V:]
w_split2, u_split2 = Z_sol.split()
w_split3, u_split3 = Z_sol.sub(0), Z_sol.sub(1)
print('solve as a system')
print('full solution')
print(Z_sol.x.array)
print(len(Z_sol.x.array))
print('guess for wh using first part of Z_sol')
print(w_split)
print('guess for uh using last part of Z_sol')
print(u_split)
print('guess for wh using .split()')
print(w_split2.x.array)
print('guess for uh using .split()')
print(u_split2.x.array)
print('guess for wh using .sub(0)')
print(w_split3.x.array)
print('guess for uh using .sub(1)')
print(u_split3.x.array)
And what it should output:
h = 0.25
x_min, x_max = -1,1
# Constants
m  = 2
alpha_par = 1/3
beta_par = 1/3
kappa_par = 1/12
C = 1/32
t_start  = 0.3
dt = 0.1
def Phi(u):
    return u**m
def exact_sol(x,t):
def weak_proj(func_u, phi_u, u): # Function that projects func_u on the space corresponding to phi_u and u
    a = ufl.inner(u, phi_u) * ufl.dx
    L = ufl.inner(func_u, phi_u) * ufl.dx
    b.assemble()
    # solver.setTolerances(rtol=1e-12, atol = 1e-50)
    solver.solve(b, u_proj.vector)
    u_proj.x.scatter_forward()
    return u_proj.x.array
u_n.name = "u_n"
# Defining the solution variables
uh = fem.Function(U)
uh.name = "uh"
wh = fem.Function(V)
wh.name = "wh"
u_proj = fem.Function(U)
u_proj.name = "u_proj"
w, phi = ufl.TrialFunction(V), ufl.TestFunction(V)
u, phi_u = ufl.TrialFunction(U), ufl.TestFunction(U)
L_par = 1
a = ((w * phi/L_const) + dt * ufl.inner(ufl.grad(w), ufl.grad(phi))) * ufl.dx
L = ((Phi(u_n_i)/L_const) + u_n - u_n_i) * phi * ufl.dx
b.assemble()
solver.setType(PETSc.KSP.Type.PREONLY) # Solver
#solver.setTolerances(rtol=1e-12, atol = 1e-50)
solver.getPC().setType(PETSc.PC.Type.LU) # Pre-conditioner
solver.solve(b, wh.vector)
wh.x.scatter_forward()
uh.x.array[:] = weak_proj(wh - Phi(u_n_i) + L_const*u_n_i, phi_u,L_const*u)
print('correct wh and uh')
print('wh array')
print(wh.x.array)
print('uh array')
print(uh.x.array)
Any help is very much appreciated.
Kind regards,
Robin
Somebody just solved it for me. This will work:
w_split, u_split = Z_sol.sub(0).collapse(), Z_sol.sub(1).collapse()
