Mapping OpenFOAM results into dolfinx
Hi everyone,
I was looking for a way to read OpenFOAM results into dolfinx, meaning being able to generate an equivalent Function in dolfinx from an OpenFOAM case.
I looked at this old topic: however, from my understanding this allows for reading the fields, starting from an xmf file generated from the case itself (I suppose).
In the past, I have implemented a routine, ImportOF, to do so using an external package, fluidfoam. The problem is that a new mesh has to be generated and, as far as I know, there is no easy to directly convert an OpenFOAM mesh, generated with blockMesh into gmsh and then dolfinx.
Lately, I saw that pyvista has capabilities of reading openfoam fields and mesh in here, is it possible to use these last functionalities to map everything into dolfinx?
Thank you for your time :slight_smile:
Hello @Stefano_Riva. Look again, my code snippet can handle vector values. The ordering is pretty simple actually, something like x_1 y_1 x_2 y_2.
Hurts to see my main contribution to this forum described as an old post because it’s true. I hope you can figure it out and my ageing hacks still work.
Best of luck !
I’ve never used it, but perhaps https://precice.org/ fits your needs?
The problem is not entirely related to vector values, actually i was looking for something able to take the openfoam spatial mesh and generate an equivalent one for dolfinx. In this way, we would have a compliant mesh and the interpolation process (using scipy maybe) would be easier, keeping the same features both on OpenFOAM and dolfinx.
I hope this clears it out a bit.
Sorry for calling it old :sweat_smile:, is your code able to generate the mesh also or should it be done outside using openfoam?
I had a look at it a while ago, but it looks a bit complex and i was searching for something more user-friendly
Lastly, pyvista has an UnstructuredGrid class and i was wondering if this could be integrated into dolfinx.mesh
If you can read it into a pyvista unstructured grid, you can extract the topology and geometry and create a dolfinx mesh. I have tried to explain this in the following tutorial:
http://jsdokken.com/FEniCS23-tutorial/src/mesh_generation.html
You should also then consider mesh.topology.original_cell_index and mesh.geometry.input_global_indices, as for instance explained in
Thank you very much! :slight_smile:
I have implemented this code to extract the topology and the points to create the dolfinx mesh from a blockMeshDict in OpenFOAM.
I’ll leave it here if anyone is interested (it works with dolfinx v0.6.0 sorry, but i guess it could be updated accordingly to the new versions).
import pyvista as pv
from pyvista import examples
import ufl  # Import UFL for mesh type definitions
from dolfinx.fem import FunctionSpace, Function
# Load the OpenFOAM file and extract the internal mesh
filename = examples.download_cavity(load=False)
reader = pv.POpenFOAMReader(filename)
reader.set_active_time_value(2.5)
reader.cell_to_point_creation = True
ugrid = reader.read()['internalMesh']
# Nodes of the mesh - They have to be (Nh, gdim)
nodes = ugrid.points
# # Connectivity of the mesh (topology) - The second dimension indicates the type of cell used
args_conn = np.argsort(ugrid.cells_dict[12], axis=1)
connectivity = np.array([ugrid.cells_dict[12][i, arg] for i, arg in enumerate(args_conn)])
# Define mesh element
shape = "hexahedron"
degree = 1
cell = ufl.Cell(shape, geometric_dimension=3)
mesh_ufl = ufl.Mesh(ufl.VectorElement("Lagrange", cell, degree))
# Create domain
cells = np.array(connectivity, dtype=np.int32)
domain = dolfinx.mesh.create_mesh(MPI.COMM_WORLD, cells, nodes, mesh_ufl)
Hi Stefano,
We are trying to read an OpenFOAM field into FEniCSx (for FESTIM :wink: ) and were wondering how one could extend your example to access the data with pyvista.
See you at OSSFE!
Hi James,
I have implemented a class in our package for Data-Driven Reduced Order Modelling, pyforce, that can read OpenFOAM results using either pyvista or fluidfoam, create a 3D mesh for dolfinx from the topological information, and interpolate the OpenFOAM fields to dolfinx.
Here’s the link: https://github.com/ERMETE-Lab/ROSE-pyforce/blob/main/pyforce/pyforce/tools/write_read.py#L134.
I have tested it multiple times in my codes. The only potential issue you might encounter is related to the dolfinx version—I am still using 0.6.0 :sweat_smile:.
Let me know if you need more details, happy to help.
See you at OSSFE!
Best,
Stefano
Hi Stefano! This is brilliant thanks for sharing. From what I can tell the main change would be that ufl.VectorElement has to be replaced by a basix element.
I also don’t think we have to manually do the interpolation but instead use the non-matching meshes interpolation from dolfinx
@dokken do you think this is something we could add in scifem? I’m happy to open a PR
