Mass Lumping in dolfinx
While porting my code from dolfin to dolfinx, it looks like the way to implement mass-lumping does not work anymore.
Back in dolfin one would have written:
dxL = dx(metadata={'quadrature_degree': 1, 'quadrature_scheme': 'vertex'})
In my MWE however the printed mass matrix is not diagonal as it should be, but does not even take the provided metadata into account…
MWE:
from dolfinx import mesh
from dolfinx.fem.petsc import assemble_matrix
from dolfinx.fem import VectorFunctionSpace, Function
domain = mesh.create_unit_square(MPI.COMM_WORLD, 8, 8, mesh.CellType.triangle)
V = VectorFunctionSpace(domain, ("Lagrange", 1), dim =2)
from dolfinx import fem
u = ufl.TrialFunction(V)
u0 = Function(V)
# Mass Lumping
dxL = ufl.dx(metadata={'quadrature_degree': 1, 'quadrature_scheme': 'vertex'})
Eqa = ufl.inner(u, v)*ufl.dx
Eqb = ufl.inner(u,v)*dxL
Xa= assemble_matrix(fem.form(Eqa))
Xb= assemble_matrix(fem.form(Eqb))
Xa.assemble()
Xb.assemble()
Xa.convert("dense")
Ca = Xa.getDenseArray()
Xb.convert("dense")
Cb = Xa.getDenseArray()
print("w/o mass lumping \n",Ca)
print("w/ mass lumping \n",Cb)
Output:
w/o mass lumping
 [[0.00390625 0.         0.00065104 ... 0.         0.         0.        ]
 [0.         0.00390625 0.         ... 0.         0.         0.        ]
 [0.00065104 0.         0.00130208 ... 0.         0.         0.        ]
 [0.         0.         0.         ... 0.00390625 0.         0.00065104]
 [0.         0.         0.         ... 0.         0.00130208 0.        ]
 [0.         0.         0.         ... 0.00065104 0.         0.00130208]]
w/ mass lumping
What am I missing?
You have a typo here.
This should be
Xb.convert("dense")
Cb = Xb.getDenseArray()
Thanks for noticing the typo! What a rookie mistake on my side…
Also, I was able to solve the problem myself in the meantime based on the following topic:
The correct way would be:
dxL = ufl.Measure("dx", metadata = {"quadrature_rule": "vertex"})
I am not fully sure about further meta-settings. But for now it works in my application.
The whole MWE that compares the methods.
import numpy
u0 = Function(V)
# Mass Lumping
Xa.assemble()
Xb.assemble()
Xa.convert("dense")
Xb.convert("dense")
print("difference: ", np.max(np.abs(Ca-Cb)))
only_diagonal = True
for i in range(len(Cb)):
    for j in range(len(Cb[0])):
        if i!=j:
            if Cb[i][j] != 0.0:
                only_diagonal=False
print("only values on the diagonal: ",only_diagonal)
Hey there,
I also wanted to implement mass lumping and found this discussion. While this works nicely in 2D, it seems to make issues in 1D. In this MWE
mesh_1d = df.mesh.create_unit_interval(MPI.COMM_WORLD,10)
V_1d = df.fem.FunctionSpace(mesh_1d,("Lagrange",1))
u = ufl.TrialFunction(V_1d)
v = ufl.TestFunction(V_1d)
lumped_integration_dx = ufl.Measure("dx", metadata={"quadrature_rule": "vertex"})
mass_form = df.fem.form(ufl.inner(u,v)* lumped_integration_dx)
MassMatrix = df.fem.petsc.assemble_matrix(mass_form, bcs=[])
MassMatrix.assemble()
I get the following traceback (running dolfinx 0.5.2 on Ubuntu22)
  File "/home/user/Workspace/domainsplitting/src/utilities.py", line 166, in <module>
    MWE_mass_lumping()
  File "/home/user/Workspace/domainsplitting/src/utilities.py", line 118, in MWE_mass_lumping
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/forms.py", line 166, in form
    return _create_form(form)
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/forms.py", line 161, in _create_form
    return _form(form)
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/forms.py", line 135, in _form
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/jit.py", line 56, in mpi_jit
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/jit.py", line 204, in ffcx_jit
    r = ffcx.codegeneration.jit.compile_forms([ufl_object], parameters=p_ffcx, **p_jit)
  File "/usr/lib/python3/dist-packages/ffcx/codegeneration/jit.py", line 168, in compile_forms
    impl = _compile_objects(decl, forms, form_names, module_name, p, cache_dir,
  File "/usr/lib/python3/dist-packages/ffcx/codegeneration/jit.py", line 232, in _compile_objects
    _, code_body = ffcx.compiler.compile_ufl_objects(ufl_objects, prefix=module_name, parameters=parameters)
  File "/usr/lib/python3/dist-packages/ffcx/compiler.py", line 107, in compile_ufl_objects
    code = generate_code(ir, parameters)
  File "/usr/lib/python3/dist-packages/ffcx/codegeneration/codegeneration.py", line 50, in generate_code
    code_integrals = [integral_generator(integral_ir, parameters) for integral_ir in ir.integrals]
  File "/usr/lib/python3/dist-packages/ffcx/codegeneration/codegeneration.py", line 50, in <listcomp>
  File "/usr/lib/python3/dist-packages/ffcx/codegeneration/integrals.py", line 27, in generator
    logger.info(f"--- type: {ir.integral_type}")
AttributeError: 'numpy.ndarray' object has no attribute 'integral_type'
Are you aware of any work arounds for that instead of manually summing up the rows (this should be equivalent in 1D)?
I’ve fixed this in: Fix interval integrals with vertex rules by jorgensd · Pull Request #562 · FEniCS/ffcx · GitHub
