Hi everyone,
I would like to solve a Poisson problem with a matrix-free approach.
For now, I managed to do it by using a PETSc ksp solver and defining a mult routine for which I used the ufl.action function (see example below).
However, I have the following problems:
- This example does not work in parallel.
- The number of iterations of the conjugate gradient is too important. How can I define a matrix-free preconditioner for this problem ?
Cheers,
Fabien
import petsc4py.PETSc as petsc
n = 100
mesh = UnitSquareMesh(n,n)
class Laplace:
def __init__(self, mesh):
self.V = FunctionSpace(mesh,"CG",1)
u = TrialFunction(self.V)
v = TestFunction(self.V)
self.a = inner(grad(u),grad(v))*dx
self.L = inner(Constant(1.),v)*dx
def bounds(x, on_boundary):
return on_boundary
self.bc = DirichletBC(self.V,Constant(0.),bounds)
self.sol = Function(self.V)
self.b = PETScVector()
self.A = PETScMatrix()
assemble(self.L, tensor=self.b)
self.bc.apply(self.b)
def mult(self, mat, X, Y):
csol = self.sol.vector().vec().getArray(readonly=0)
XX = X.getArray(readonly=1)
csol[:] = XX[:]
Act = action(self.a, self.sol)
AX = PETScVector()
assemble(Act, tensor=AX)
self.bc.apply(AX)
Y.getArray(readonly=0)[:] = AX.vec().getArray(readonly=1)[:]
def setup_ksp(self, solver='cg', prec='none'):
fM = assemble(TrialFunction(self.V)*TestFunction(self.V)*dx)
M = petsc.Mat()
M.create(comm=petsc.COMM_WORLD)
M.setSizes(as_backend_type(fM).mat().getSizes())
M.setType(petsc.Mat.Type.PYTHON)
M.setPythonContext(self)
M.setUp()
PETScOptions.set("ksp_monitor_true_residual")
self.ksp = petsc.KSP().create()
self.ksp.setType(solver)
pc = self.ksp.getPC()
pc.setType(prec)
self.ksp.setOperators(M)
self.ksp.setName("laplace")
self.ksp.setTolerances(rtol=1e-6)
self.ksp.setFromOptions()
x, b = M.getVecs()
b.getArray(readonly=0)[:] = self.b.vec().getArray(readonly=1)[:]
return x, b
def solve(self, B, X):
self.ksp.solve(B, X)
self.sol.vector().vec().getArray(readonly=0)[:] = X.getArray(readonly=1)[:]
l = Laplace(mesh)
x, b = l.setup_ksp()
l.solve(b,x)
comm = MPI.comm_world
with XDMFFile(comm,"laplace_matrixfree.xdmf") as infile:
infile.write(l.sol)
