An old Maxwell’s equation solver example (Stable and unstable finite elements for the Maxwell eigenvalue problem — DOLFIN documentation) ported to DolfinX (Waveguide number of eigenmodes - #8 by MatsievskiySV) used to work fine prior to v0.5, but now it does not produce physical solutions. The only difference is substitution of compute_boundary_facets with locate_entities_boundary. What is wrong here?
Full code:
from dolfinx import (io, fem, mesh)
from slepc4py import SLEPc
msh = mesh.create_rectangle(comm=MPI.COMM_WORLD,
points=((0, 0), (2, 1)),
n=(40, 40),
cell_type=mesh.CellType.triangle)
N1curl = ufl.FiniteElement("Nedelec 1st kind H(curl)", msh.ufl_cell(), 1)
V = fem.FunctionSpace(msh, N1curl)
u = ufl.TrialFunction(V)
a = ufl.inner(ufl.curl(u), ufl.curl(v)) * ufl.dx
b = ufl.inner(u, v) * ufl.dx
bc_facets = mesh.locate_entities_boundary(msh,
msh.topology.dim - 1,
lambda x: np.full(x.shape[1], True, dtype=bool))
bc_dofs = fem.locate_dofs_topological(V, msh.topology.dim-1, bc_facets)
u_bc = fem.Function(V)
u_bc.x.array[:] = ScalarType(0)
bc = fem.dirichletbc(u_bc, bc_dofs)
A = fem.petsc.create_matrix(fem.form(a))
fem.petsc.assemble_matrix(A, fem.form(a), bcs=[bc])
B = fem.petsc.create_matrix(fem.form(b))
fem.petsc.assemble_matrix(B, fem.form(b), bcs=[bc])
B.assemble()
eps = SLEPc.EPS().create(MPI.COMM_WORLD)
eps.setOperators(A, B)
eps.setType(SLEPc.EPS.Type.KRYLOVSCHUR)
st = eps.getST()
st.setType(SLEPc.ST.Type.SINVERT)
eps.setWhichEigenpairs(SLEPc.EPS.Which.TARGET_MAGNITUDE)
eps.setTarget(12)
eps.setDimensions(30)
eps.solve()
vals = [(i, eps.getEigenvalue(i)) for i in range(eps.getConverged())
if not np.isclose(eps.getEigenvalue(i), 0)
and not np.isclose(eps.getEigenvalue(i), 1)]
vals.sort(key=lambda x: x[1].real)
j = 0
E = fem.Function(V)
with io.XDMFFile(MPI.COMM_WORLD, "out.xdmf", "w") as xdmf:
xdmf.write_mesh(msh)
for i, _ in vals:
print(f"eigenvalue: {eps.getEigenpair(i, E.vector).real:.12f}")
E.name = f"E-{j+1:03d}-{eps.getEigenpair(i, E.vector).real:.4f}"
xdmf.write_function(E)
j += 1
OS: Debian bookworm
Built from main branches as of 24-08-2022:
BASIX commit: Update UFL wrapper (#575) · FEniCS/basix@1fdeeb4 · GitHub
DOLFIN commit: correct gdim/tdim (#2307) · FEniCS/dolfinx@e3d7b51 · GitHub
UFL commit: Sanitise unicode input (#111) · FEniCS/ufl@50d2a48 · GitHub
FFCX commit: Use Basix element functionality over UFL (#515) · FEniCS/ffcx@4bc7476 · GitHub
