Eigen solver syntax in dolfin-x
Hi, I am solving a modal analysis problem. I am not able to write the syntax of eigen solver in dolfin-x The MWE for the same has been attached.
import dolfinx.fem as fem, dolfinx.generation as generation
from ufl import (Circumradius, FacetNormal, SpatialCoordinate, TrialFunction, TestFunction,
                 div, dx, ds, grad, inner)
from dolfinx.generation import BoxMesh
from dolfinx.mesh import MeshTags, locate_entities
from dolfinx.mesh import CellType, locate_entities_boundary
from dolfinx.fem import (Constant, DirichletBC, Function, LinearProblem, FunctionSpace, VectorFunctionSpace,
                         locate_dofs_topological)
mesh = BoxMesh(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([5, 0.6, 0.3])], [25,3,2], cell_type=CellType.hexahedron)
E, nu = (2e11), (0.3)
rho = (7850)
mu = E/2./(1+nu)
lambda_ = E*nu/(1+nu)/(1-2*nu)
    return ufl.sym(ufl.grad(u)) # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma(u):
    return lambda_ * ufl.nabla_div(u) * ufl.Identity(u.geometric_dimension()) + 2*mu*epsilon(u)
V = VectorFunctionSpace(mesh, ("CG", 1))
u = ufl.TrialFunction(V)
def clamped_boundary(x):
    return np.isclose(x[0], 0)
fdim = mesh.topology.dim - 1
boundary_facets = locate_entities_boundary(mesh, fdim, clamped_boundary)
u_D = Function(V)
with u_D.vector.localForm() as loc:
    loc.set(0)
bc = DirichletBC(u_D, locate_dofs_topological(V, fdim, boundary_facets))
T = Constant(mesh, (0, 0, 0))
ds = ufl.Measure("ds", domain=mesh)
k_form = inner(sigma(u),epsilon(v))*dx
m_form = rho*ufl.dot(u,v)*dx
K = dolfinx.fem.assemble_matrix(k_form, bcs=[bc])
K.assemble()
M = dolfinx.fem.assemble_matrix(m_form, bcs=[bc])
M.assemble()
import sys, slepc4py
slepc4py.init(sys.argv)
from slepc4py import SLEPc
eigensolver = SLEPc.EPS().create(MPI.COMM_WORLD)
eigensolver.setOperators(K,M)
eigensolver.setDimensions(nev=10)
eigensolver.solve()
evs = eigensolver.getConverged()
vr, vi = K.getVecs()
print( "Number of converged eigenpairs %d" % evs )
if evs > 0:
    for i in range (evs):
            l = eigensolver.getEigenpair(i ,vr, vi)
            print(l.real)
I made some changes to your code for the current dolfinx
                 TestFunction, div, dx, ds, grad, inner)
from dolfinx.mesh import MeshTags, locate_entities, create_box
mesh = create_box(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([5, 0.6, 0.3])], [25,3,2], cell_type=CellType.hexahedron)
rho = (7850)
mu = E/2./(1+nu)
def sigma(u):
u_D = Function(V)
    loc.set(0)
T = Constant(mesh, (PETSc.ScalarType(0), PETSc.ScalarType(0), PETSc.ScalarType(0)))
K.assemble()
M.assemble()
eigensolver.solve()
if evs > 0:
            print(l.real)
and I got the following results
Number of converged eigenpairs 12
24170102233.356747
24159609663.2646
24128225812.786083
24064285982.84818
24062146763.88163
24057006404.662098
24047436042.282703
24002756434.838116
23953242686.51013
23912724277.967308
23802203732.108154
23776394801.64928
This is the solution that I was also getting, but this is not correct. Frequency should come in increasing order. These are correct natural frequencies that is coming using dolfin with same problem statement.
Solid FE: 61.76 [Hz]
Solid FE: 122.20 [Hz]
Solid FE: 380.86 [Hz]
Solid FE: 720.322[Hz]
Solid FE: 746.56 [Hz]
Solid FE: 1040.998 [Hz]
With dolfin-x, it should come same
Hi Shubham,
The default setting of the slepc4py eigensolver solved for the largest eigenvalue and as such that may be why you are not getting the correct result. It is difficult for me to reproduce a similar result without an example code that produces the dolfin result. Nonetheless, based on an example from this webpage, I’ve got a similar result except for small differences in the first couples of eigenvalues. Below is the dolfinx code:
import sys
import slepc4py
from dolfinx.mesh import CellType, locate_entities_boundary, create_box
from dolfinx.fem import (Constant, DirichletBC, Function, VectorFunctionSpace,
from ufl import (TrialFunction, TestFunction, Identity, inner, dot, nabla_div,
                 nabla_grad, dx)
mesh = create_box(
    MPI.COMM_WORLD,
    [np.array([0, 0, 0]), np.array([1.0, 1.0, 0.01])],
    [20, 20, 2],
    cell_type=CellType.tetrahedron)
E, nu = (70.0E9), (0.23)
rho = (2500)
mu = E/2./(1+nu)
def sigma(u):
    return lambda_ * nabla_div(u) * Identity(u.geometric_dimension()) \
           + 2*mu*epsilon(u)
V = VectorFunctionSpace(mesh, ("CG", 2))
u_D = Function(V)
    loc.set(0)
k_form = inner(sigma(u), epsilon(v))*dx
m_form = rho*dot(u, v)*dx
K = dolfinx.fem.assemble_matrix(k_form)
K.assemble()
M = dolfinx.fem.assemble_matrix(m_form)
M.assemble()
shift = SLEPc.ST().create(MPI.COMM_WORLD)
shift.setType('sinvert')  # spectral transform
shift.setShift(100)  # spectral shift
eigensolver.setDimensions(nev=15)
eigensolver.setProblemType(2)
eigensolver.setST(shift)
eigensolver.setType('krylovschur')  # Solver type
eigensolver.setWhichEigenpairs(7)  # Target Real
eigensolver.setOperators(K, M)
eps_type = eigensolver.getType()
print("Solution method: %s" % eps_type)
problem_type = eigensolver.getProblemType()
print("Problem type: %s" % problem_type)
which_eigenpairs = eigensolver.getWhichEigenpairs()
print("Eigenpairs type: %s" % which_eigenpairs)
eigensolver.solve()
vr, vi = K.createVecs()
print("Number of converged eigenpairs %d" % evs)
if evs > 0:
    for i in range(evs):
        e_val = eigensolver.getEigenpair(i, vr, vi)
        # Calculation of eigenfrequency from real part of eigenvalue
        freq_3D = np.sqrt(abs(e_val.real))/2/np.pi
        print("Eigenfrequency: {0:8.5f} [Hz]".format(freq_3D))
Hope this helps.
Hello sir,
I am attaching the dolfin code for the same problem as you have asked for it. I have to replicate the same using dolfin-x.
import json
import scipy as sp
%matplotlib inline
mesh = BoxMesh(Point(0.,0.,0.),Point(5,0.6,0.3), 25, 3, 2)
E, nu, rho = (2e11), (0.3), (7850)
mu,lmbda = E/2./(1+nu), E*nu/(1+nu)/(1-2*nu)
def sigma(v):
    dim = v.geometric_dimension()
    return 2.0*mu*eps(v) + lmbda*tr(eps(v))*Identity(dim)
def eps(v):
    return sym(grad(v))
V = VectorFunctionSpace(mesh, 'CG', degree=2)
left = CompiledSubDomain("near(x[0], 0) && on_boundary")
bc = DirichletBC(V, Constant((0.,0.,0.)), left)
k_form = inner(sigma(u),eps(v))*dx
m_form = rho*dot(u,v)*dx
K = PETScMatrix()
assemble(k_form, tensor=K)
M = PETScMatrix()
assemble(m_form, tensor=M)
bc.zero(M), bc.apply(K)
eigensolver = SLEPcEigenSolver(K, M)
eigensolver.parameters['problem_type'] = 'gen_hermitian'
eigensolver.parameters['spectral_transform'] = 'shift-and-invert'
eigensolver.parameters['spectral_shift'] = 0.
N_eig = 40   # number of eigenvalues
print("Computing {} first eigenvalues...".format(N_eig))
eigensolver.solve(N_eig)
L, B, H = 5., 0.3, 0.6 #Dimensions of the beam
# Exact solution computation
from scipy.optimize import root
from math import cos, cosh
falpha = lambda x: cos(x)*cosh(x)+1
alpha = lambda n: root(falpha, (2*n+1)*pi/2.)['x'][0]
file_results = XDMFFile("modal_analysis.xdmf")
# Extraction
eig_v = []
eig_l = []
for i in range(N_eig):
    # Extract eigenpair
    r, c, rx, cx = eigensolver.get_eigenpair(i)
    # 3D eigenfrequency
    freq_3D = sqrt(r)/2/pi
    # Beam eigenfrequency
    if i % 2 == 0: # exact solution should correspond to weak axis bending
        I_bend = H*B**3/12.
    else:          #exact solution should correspond to strong axis bending
        I_bend = B*H**3/12.
    freq_beam = alpha(i/2)**2*sqrt(E*I_bend/(rho*B*H*L**4))/2/pi
    print("Solid FE: {0:8.5f} [Hz]   Beam theory: {1:8.5f} [Hz]".format(freq_3D, freq_beam))
    # Initialize function and assign eigenvector
    eigenmode = Function(V,name="Eigenvector "+str(i))
    eigenmode.vector()[:] = rx
    file_results.write(eigenmode, 0)
    eig_l.append(freq_3D)
    eig_v.append(rx)
The results are:
Computing 40 first eigenvalues...
Solid FE:  9.83051 [Hz]   Beam theory:  9.78457 [Hz]
Solid FE: 19.45146 [Hz]   Beam theory: 19.56914 [Hz]
Solid FE: 60.61639 [Hz]   Beam theory: 61.31884 [Hz]
Solid FE: 114.64296 [Hz]   Beam theory: 122.63769 [Hz]
Solid FE: 118.82391 [Hz]   Beam theory: 171.69454 [Hz]
Solid FE: 165.68699 [Hz]   Beam theory: 343.38908 [Hz]
This is the closest that I can get to the dolfin solver. I’m not sure of the internal settings of dolfin to obtain a totally similar result. My current implementation contains a couple of eigenvalues that is equal to 1. In the implementation below, I just ignored those eigenvalues.
import sys
import slepc4py
                 nabla_grad, dx)
mesh = create_box(
    MPI.COMM_WORLD,
    [np.array([0, 0, 0]), np.array([L, H, B])],
    [25, 3, 2],
E, nu = (2E11), (0.3)
rho = (7850)
mu = E/2./(1+nu)
def sigma(u):
           + 2*mu*epsilon(u)
u_D = Function(V)
    loc.set(0)
K.assemble()
M.assemble()
shift.setShift(0.0)  # spectral shift
eigensolver.setDimensions(nev=50)
eigensolver.setConvergenceTest(2)
eigensolver.solve()
def falpha(x):
    return np.cos(x) * np.cosh(x) + 1
def alpha(n):
    return root(falpha, (2*n + 1)*np.pi/2)['x'][0]
ef = 0
if evs > 0:
        if (~np.isclose(e_val.real, 1.0)):
            freq_3D = np.sqrt(e_val.real)/2/np.pi
            if ef % 2 == 0:
                I_bend = H*B**3/12.
                # exact solution should correspond to strong axis bending
                I_bend = B*H**3/12.
            freq_beam = alpha(ef/2)**2*np.sqrt(E*I_bend/(rho*B*H*L**4))/2/np.pi
            print(
                "Solid FE: {0:8.5f} [Hz] "
                "Beam theory: {1:8.5f} [Hz]".format(freq_3D, freq_beam))
            ef += 1
If you run this code in dolfinx you’ll get a similar result as you posted before. I’m not an extensive user of SLEPc nor am I an eigenvalue solver expert. So, I don’t know why we get those 1’s eigenvalue. Anyway, hope this helps. :smiley:
Thank you so much for the help :smiley:
Sir, can you also tell the syntax for writing eigen vectors corresponding to these eigen values/frequencies. The dolfin code presented above had
where rx is the eigen vector corresponding to all nodes of the mesh.
The vr PETSc vector should contains the real part of the eigenvector.
I tried with vr but not getting correct results. This the MWE for that
import sys
import slepc4py
                 nabla_grad, dx)
mesh = create_box(
    MPI.COMM_WORLD,
    [25, 3, 2],
rho = (7850)
mu = E/2./(1+nu)
def sigma(u):
           + 2*mu*epsilon(u)
u_D = Function(V)
    loc.set(0)
K.assemble()
M.assemble()
eigensolver.solve()
def falpha(x):
def alpha(n):
eig_v=[]
ef = 0
if evs > 0:
            if ef % 2 == 0:
                I_bend = H*B**3/12.
                I_bend = B*H**3/12.
            print(
            eig_v.append(vr)
            ef += 1
print(np.array(eig_v).T)
With this code getting this result
array([[ 7.87128161e-05,  7.87128161e-05,  7.87128161e-05, ...,
         7.87128161e-05,  7.87128161e-05,  7.87128161e-05],
       [-4.79422279e-05, -4.79422279e-05, -4.79422279e-05, ...,
        -4.79422279e-05, -4.79422279e-05, -4.79422279e-05],
       [ 2.09577501e-06,  2.09577501e-06,  2.09577501e-06, ...,
         2.09577501e-06,  2.09577501e-06,  2.09577501e-06],
       [-3.39323655e-03, -3.39323655e-03, -3.39323655e-03, ...,
        -3.39323655e-03, -3.39323655e-03, -3.39323655e-03],
       [-1.81604351e-02, -1.81604351e-02, -1.81604351e-02, ...,
        -1.81604351e-02, -1.81604351e-02, -1.81604351e-02],
       [-2.21205070e-03, -2.21205070e-03, -2.21205070e-03, ...,
        -2.21205070e-03, -2.21205070e-03, -2.21205070e-03]])
but the correct one from dolfin code presented above is
Screenshot 2022-01-06 083818
Hi Shubham,
Have you tried to plot the eigenmode and check whether it is correct?
Adeeb
Hello sir,
sorry for the late reply.
I tried writing eigenmode in xdmf. But getting some error. Can you please help.
import sys
import slepc4py
from dolfinx.fem import (Constant, dirichletbc, Function, VectorFunctionSpace,
                         locate_dofs_topological,assemble_matrix, form)
                 nabla_grad, dx)
mesh = create_box(
    MPI.COMM_WORLD,
    [25, 3, 2],
rho = (7850)
mu = E/2./(1+nu)
def sigma(u):
           + 2*mu*epsilon(u)
u_D = Function(V)
    loc.set(0)
bc = dirichletbc(u_D, locate_dofs_topological(V, fdim, boundary_facets))
k_form= form(inner(sigma(u), epsilon(v)) * dx)
K = assemble_matrix(k_form, bcs=[bc])
K.assemble()
m_form = form(rho*dot(u, v)*dx)
M = assemble_matrix(m_form, bcs=[bc])
M.assemble()
eigensolver.solve()
def falpha(x):
def alpha(n):
import dolfinx.io
eig_v=[]
ef = 0
if evs > 0:
            if ef % 2 == 0:
                I_bend = H*B**3/12.
                I_bend = B*H**3/12.
            print(
            eig_v.append(vr.copy())
            with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "eigenvector.xdmf", "w") as xdmf:
                xdmf.write_mesh(mesh)
                vr.name = "eigenvector"
                xdmf.write_function(vr.copy())
            ef += 1
You cannot write a PETSc vector directly to XDMF. You need to wrap it as a dolfinx.fem.Function:
ur = dolfinx.fem.Function(V)
ur.vector.array[:] = vr
xdmf.write_function(ur.copy())
Thanks sir,
I have modified the code, but getting only one vector in xdmf. I need to get all the eigenmodes in one xdmf file.
import sys
import slepc4py
                 nabla_grad, dx)
mesh = create_box(
    MPI.COMM_WORLD,
    [25, 3, 2],
rho = (7850)
mu = E/2./(1+nu)
def sigma(u):
           + 2*mu*epsilon(u)
u_D = Function(V)
    loc.set(0)
K.assemble()
M.assemble()
eigensolver.solve()
def falpha(x):
def alpha(n):
import dolfinx.io
eig_v=[]
ef = 0
if evs > 0:
            if ef % 2 == 0:
                I_bend = H*B**3/12.
                I_bend = B*H**3/12.
            print(
            ef += 1
You need to move the declartion of the XDMFFile outside of the for loop, or use the append mode. Currently you are rewriting it at every entry to the loop.
I changed this. but every mode eigenvector is giving white colour contour only.
the code is
import dolfinx.io
eig_v=[]
ef = 0
if evs > 0:
            if ef % 2 == 0:
                I_bend = H*B**3/12.
                I_bend = B*H**3/12.
            print(
            ef += 1
the output is coming like this for all the modes
See: Using Paraview for visualization — FEniCSx tutorial
File->Open.Xdmf3ReaderT->Filters->Alphabetic shows the list of options, which are not selectable. I am unable to click on ExtractBlock. The screenshot is attached.
Press «apply» before trying to extract the block (green buttom center left on your screenshot)
I tried with that also, but there is no view after applying ExtractBlock.
It may be possible that syntax for writing the file is not correct. you may please go through this.
