Memory allocation error when reading in cell tags from a pre-defined mesh file
I’m trying to load a mesh from an XDMF and H5 file (created in Gmsh) using the following code:
# Create the MPI communicator
comm = MPI.COMM_WORLD
import dolfinx # using dolfinx v0.7.2
import h5py
# Read mesh from the XDMF file
with dolfinx.io.XDMFFile(comm, "collimator_tetra.xdmf", "r") as xdmf:
    print("mesh read")
    cell_tags = xdmf.read_meshtags(mesh, name="Grid")
This produces the following error:
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
I’ve seen this previous question, where the user resolved the problem by adding all surfaces to a physical group. I’ve added all entities (including surfaces) to physical groups, but I’m still experiencing the same issue.
I’ve also tried to locate the source of the problem by starting with the simplest shapes and gradually adding shapes, physical groups, and fields until I get an error. The error only occurs after I define the field.
Here is the mesh that is causing the issue:
import gmsh # For creating mesh
import numpy as np # For adding magnets
import meshio # For converting to xdmf format for FEniCSx
from collections import defaultdict # For grouping unsorted entities
\# VARIABLES ------------------------------------------
run_gui = False # Show the mesh in GMSH GUI
\# Thruster / collimator variables:
\# Note that these are arbitrary values
r_c = 0.0125 # m, = 12.5mm, cathode radius
r_coll = 0.05 # m, = 3cm, collimator radius
r_a = 2\*r_c # m, = 25mm, anode radius
r_trig = 0.001 # m = 1mm, trigger radius
kappa = 0.03 # m, = 3cm, cathode-collimator distance
l_c = r_c # m = 12.5mm, length of cathode
l_coll = 0.08 # m, = 10cm, length of collimator
l_a = l_c+kappa # m, = 42.5mm, length of anode
l_trig = l_c \* 3/2 # m, = 18.75mm, length of trigger
n_mag = 3 # number of pairs of magnets
h_mag = 0.0025 # m, = 2.5mm, height of magnet
l_mag = l_coll # m, = 10cm, length of magnet
w_mag = 2\*h_mag # m, = 5mm, width of magnet
\# Plasma variables:
debye_length = 0.005
\# Model variables:
size_min = 0.001
size_max = debye_length
\# File variables:
meshname = "collimator.msh" # Mesh will be saved to this file
\# FUNCTIONS ------------------------------------------
def add_magnet_pair(model:gmsh.model, x:float, y:float, z:float, dx:float, dy:float, dz:float, angle:float, last_tag:int, magnet_surface_list:list, magnet_volume_list:list)->gmsh.model:
   Adds a pair of magnets at a given point on the collimator-thruster mesh.
   The magnet is a rectangle defined by a point (x\', y\', z\') and the extents along the x-, y- and z-axes, and is rotated by angle.
   The second magnet is added diagonally opposite the first.
   Args:
       model: the model to be updated
       x: x-coordinate of one corner of box
       y: y-coordinate of one corner of box
       z: z-coordinate of one corner of box
       dx: x-coordinate of other corner of box
       dy: y-coordinate of other corner of box
       dz: z-coordinate of other corner of box
       angle: (radians) the rectangle is rotated about the x-axis by this angle
       last_tag: the tag of the entity to add the magnets to
       magnet_surface_list: list of dimtags of all surfaces of the magnets
       magnet_volume_list: list of all the tags of the magnet volumes. For defining the magnets as a physical group later.
   Returns:
       model: updated gmsh model
       last_tag: the tag of the updated model
       magnet_surface_list: list of magnet surfaces by \[(dimension=2, tag)\] (for defining field later)
\# Add first magnet
   mag_1_vol = model.occ.addBox(x,-y+1e-6,-z, dx, dy, dz, tag=last_tag+1)
   model.occ.rotate(\[(3, mag_1_vol)\], x+dx/2,0,0, 1,0,0, angle)
\# Add second magnet opposite the first
   mag_2_vol = model.occ.addBox(x,-y+1e-6,-z, dx, dy, dz, tag=last_tag+2)
   model.occ.rotate(\[(3, mag_2_vol)\], x+dx/2,0,0, 1,0,0, angle+np.pi)
   gmsh.model.occ.synchronize() # Cut both at the same time - reduces synchronise calls.
   mag_1_surf = model.getBoundary(\[(3, mag_1_vol)\], combined=False, oriented=False)
   mag_2_surf = model.getBoundary(\[(3, mag_2_vol)\], combined=False, oriented=False)
   magnet_surface_list.append(mag_1_surf)
   magnet_surface_list.append(mag_2_surf)
   magnet_volume_list.append(mag_1_vol)
   magnet_volume_list.append(mag_2_vol)
\# Update tag
   last_tag = last_tag+2
return model, last_tag, magnet_surface_list, magnet_volume_list
def add_physical_boundary_surface(model:gmsh.model, vol_tag:int|list, phys_tag=int, surf_name=str)->int:
   Adds a physical group containing the boundary of the volume vol_tag.
   The resulting physical group has the tag phys_tag, and the name surf_name.
   Args:
       - model: gmsh model to add the physical group to.
       - vol_tag: (positive integer) the tag of the volume whose surface will be added.
       - phys_tag: (positive integer) the tag of the resulting physical group. -1 to let gmsh assign a tag automatically.
       - surf_name: (string) the name of the physical group.
   Returns: the tag of the physical group, phys_tag.
if type(vol_tag) == int:
       boundary_entities = model.getBoundary(\[(3, vol_tag)\])
       surface_tags = \[tag for dim, tag in boundary_entities if dim == 2\]
return model.addPhysicalGroup(2, surface_tags, tag=phys_tag, name=surf_name)
elif type(vol_tag) == list:
       surface_tags = \[\]
for vol in vol_tag:
           boundary_entities = model.getBoundary(\[(3, vol)\])
for dim, tag in boundary_entities:
if dim == 2:
                   surface_tags.append(tag)
   Modified from code written by J.S. Dokken, December 2021, available here: (https://fenicsproject.discourse.group/t/importing-mesh-gives-error/7282/5)
   This reads in a mesh of type gmsh.mesh, and returns a mesh consisting of only the cells of type cell_type.
   Args:
       - mesh: gmsh.mesh containing mixed cell types
       - cell_type: either "tetra" or "triangle" - the cell type to be included in the output mesh.
   Returns:
       - mesh containing only cells of cell_type.
   cell_data = mesh.get_cell_data("gmsh:physical", cell_type) # For encoding facet tags (required to preserve physical groups)
   points = mesh.points\[:, :2\] if prune_z else mesh.points
   out_mesh = meshio.Mesh(points=points,
cells={cell_type: cells},
cell_data={"name_to_read": \[cell_data.astype(np.int32)\]})
return out_mesh
\# DEFINING A MODEL WITH GMSH -------------------------
\# ---- Set parameters ----
gmsh.model.add("collimator") # Add model with name collimator
\# ---- Define geometry ----
vol_coll = gmsh.model.occ.addCylinder(l_a,0,0, l_coll,0,0, r_coll, 1) # Collimator cylinder, tag = 1
vol_a = gmsh.model.occ.addCylinder(0,0,0, l_a,0,0, r_a,2) # Anode cylinder, tag = 2
\# Then remove the cathode from the anode cylinder
vol_c = gmsh.model.occ.addCylinder(0,0,0, l_c,0,0, r_c, 4) # tag = 4
vol_trig = gmsh.model.occ.addCylinder(0,0,0, l_trig,0,0, r_trig, tag=5) # tag = 5
\# Add magnets:
if n_mag == 0:
pass
elif n_mag > 0:
   last_tag = 5 # Tag of most-recently created entity
   angle_array = np.linspace(0, np.pi, n_mag+1)\[0:n_mag\] # Generate array of equally spaced magnet pairs around spherical cathode surface
   magnet_surface_list = \[\]
   magnet_volume_list = \[\]
for loop_idx, angle in enumerate(angle_array):
       gmsh.model, last_tag, magnet_surface_list, magnet_volume_list = add_magnet_pair(gmsh.model, l_a, r_coll, w_mag/2, l_mag, h_mag, w_mag, angle, last_tag, magnet_surface_list, magnet_volume_list)
flat_magnet_surface_tags = \[tag for surf in magnet_surface_list for (dim, tag) in surf\]
gmsh.model.mesh.embed(2, flat_magnet_surface_tags, 3, vol_coll)
\# DEFINING PHYSICAL GROUPS ----------------------------------
\# ---- Define physical groups -----
print(f"magnet surfaces: {magnet_surface_list}")
print(f"magnet volume: {magnet_volume_list}")
phys_col = gmsh.model.addPhysicalGroup(3, \[vol_coll\], 49, "collimator")
phys_a = gmsh.model.addPhysicalGroup(3, \[vol_a\], 50, "anode")
phys_c = gmsh.model.addPhysicalGroup(3, \[vol_c\], 51, "cathode")
phys_trig = gmsh.model.addPhysicalGroup(3, \[vol_trig\], 52, "trigger")
phys_mag = gmsh.model.addPhysicalGroup(3, magnet_volume_list, 53, "magnets")
phys_surf_col = add_physical_boundary_surface(gmsh.model, vol_coll, 54, "collimator_surface")
phys_surf_a = add_physical_boundary_surface(gmsh.model, vol_a, 55, "anode_surface")
phys_surf_c = add_physical_boundary_surface(gmsh.model, vol_c, 56, "cathode_surface")
phys_surf_trig = add_physical_boundary_surface(gmsh.model, vol_trig, 57, "trigger_surface")
phys_surf_mag = gmsh.model.addPhysicalGroup(2, flat_magnet_surface_tags, 58, "magnets_surface")
\# DEFINING FIELDS -------------------------------------------
# NOTE: when this section is commented out, the resulting xdmf / h5 file is able to be read without error by fenics.
\# ---- Define mesh field ----
\# Get magnet boundary
magnet_array = np.zeros((n_mag\*2\*6))
for mag_idx, magnet in enumerate(magnet_surface_list):
for surf_idx, surface in enumerate(magnet):
       magnet_array\[6\*mag_idx+surf_idx\] = surface\[1\]
distance_field = gmsh.model.mesh.field.add("Distance", 1)
gmsh.model.mesh.field.setNumbers(1, "FacesList", magnet_array)
gmsh.model.mesh.field.setNumber(1, "Sampling", 1000)
threshold_field = gmsh.model.mesh.field.add("Threshold", 2)
gmsh.model.mesh.field.setNumber(2, "InField", distance_field) # Create a mesh field that defines mesh size based on proximity to magnets
gmsh.model.mesh.field.setNumber(2, "SizeMin", size_min)
gmsh.model.mesh.field.setNumber(2, "SizeMax", size_max)
gmsh.model.mesh.field.setNumber(2, "DistMin", 0)
gmsh.model.mesh.field.setNumber(2, "DistMax", 0.05) # 0.5mm
gmsh.model.mesh.field.setAsBackgroundMesh(2)
gmsh.option.setNumber("Mesh.MeshSizeExtendFromBoundary", 0)
gmsh.option.setNumber("Mesh.MeshSizeFromPoints", 0)
gmsh.option.setNumber("Mesh.MeshSizeFromCurvature", 0)
\# UNGROUPED ENTITIES PHYSICAL GROUPS ---------------------------------
entities = gmsh.model.get_entities(-1)
print("Entities")
for e in entities:
print(f"dim:{e\[0\]}, tag:{e\[1\]}")
\# Find entities not already part of a physical group and add them to a physical group by dimension
ungrouped_entities = entities
misctags = defaultdict(list)
physicalgroups = gmsh.model.get_physical_groups(-1)
print("Physical groups")
for p in physicalgroups:
print(f"{gmsh.model.get_physical_name(p\[0\], p\[1\])}, dim: {p\[0\]}, tag = {p\[1\]}")
   grouped_entities = gmsh.model.get_entities_for_physical_group(p\[0\], p\[1\])
print(f"entities in {gmsh.model.get_physical_name(p\[0\], p\[1\])}: {grouped_entities}")
for g in grouped_entities:
       dt = (p\[0\], int(g))
if dt in ungrouped_entities:
           ungrouped_entities.remove(dt)
\# Sort ungrouped entities by dimension
for d, e in ungrouped_entities:
   misctags\[d\].append(e)
phys_misc = defaultdict(int)
phys_names = \["points", "lines", "surfaces", "volumes"\]
for ii in range(0, 3):
if ii in misctags:
       phys_misc\[ii\] = gmsh.model.addPhysicalGroup(ii, misctags\[ii\], tag=-1, name=phys_names\[ii\])
print(f"Physical group created for ungrouped {phys_names\[ii\]}, contains these tags: {misctags\[ii\]}")
for t in misctags\[ii\]:
           dt = (ii, t)
\# Check again for ungrouped entities: (expect this to print an empty list)
print(f"Ungrouped entities after grouping: {ungrouped_entities}")
\# GENERATE MESH ------------------------------------------
\# ---- Parallelize ----
gmsh.option.setNumber("General.NumThreads", 5) # Use multithreading to generate mesh faster
gmsh.option.setNumber("Mesh.Algorithm3D", 4) # Frontal-Delaunay (default. If this causes issues consider changing to 10 - HXT which is a version of Delaunay that is optimised for parallel meshing).
\# ---- Generate Mesh ----
gmsh.model.mesh.generate() #(3) # Generate in 3d
gmsh.write(meshname) # Save mesh as meshname
\# ---- Output to GUI ----
if run_gui: # Off by default for remote server.
   gmsh.fltk.run()
gmsh.finalize()
print("Done")
\# CONVERT TO XDMF FORMAT -------------------------------------
\# This step reads in the msh file so that the cell can be run without the use of gmsh.
in_mesh = meshio.read(meshname)
collimator_tetra = create_mesh(in_mesh, "tetra")
collimator_triangle = create_mesh(in_mesh, "triangle")
meshio.write("collimator_tetra.xdmf", collimator_tetra, compression=None)
meshio.write("collimator_tetra_facets.xdmf", collimator_triangle, compression=None)
For reference, when the field section is commented out, the resulting XDMF/H5 files can be read by FEniCSx without any problems.
Any help would be very much appreciated! :slightly_smiling_face:
You code is not correctly formatted, so it is quite painful to reproduce the example (try copying the code into an editor, and you will see things such as:
and weird tabulation.
Fixing the formatting of your code such that it is ok:
r_a = 2 * r_c  # m, = 25mm, anode radius
l_a = l_c + kappa  # m, = 42.5mm, length of anode
l_trig = l_c * 3 / 2  # m, = 18.75mm, length of trigger
w_mag = 2 * h_mag  # m, = 5mm, width of magnet
# Plasma variables:
# Model variables:
size_min = 0.001
# File variables:
    model: gmsh.model,
    x: float,
    y: float,
    z: float,
    dx: float,
    dy: float,
    dz: float,
    angle: float,
    last_tag: int,
    magnet_surface_list: list,
    magnet_volume_list: list,
) -> gmsh.model:
    Args:
    Returns:
        magnet_surface_list: list of magnet surfaces by [(dimension=2, tag)] (for defining field later)
    # Add first magnet
    mag_1_vol = model.occ.addBox(x, -y + 1e-6, -z, dx, dy, dz, tag=last_tag + 1)
    model.occ.rotate([(3, mag_1_vol)], x + dx / 2, 0, 0, 1, 0, 0, angle)
    mag_2_vol = model.occ.addBox(x, -y + 1e-6, -z, dx, dy, dz, tag=last_tag + 2)
    model.occ.rotate([(3, mag_2_vol)], x + dx / 2, 0, 0, 1, 0, 0, angle + np.pi)
    mag_1_surf = model.getBoundary([(3, mag_1_vol)], combined=False, oriented=False)
    mag_2_surf = model.getBoundary([(3, mag_2_vol)], combined=False, oriented=False)
    # Update tag
    last_tag = last_tag + 2
    model: gmsh.model, vol_tag: int | list, phys_tag=int, surf_name=str
) -> int:
    Args:
        boundary_entities = model.getBoundary([(3, vol_tag)])
        surface_tags = [tag for dim, tag in boundary_entities if dim == 2]
        surface_tags = []
        for vol in vol_tag:
            boundary_entities = model.getBoundary([(3, vol)])
                if dim == 2:
    Args:
    Returns:
        points=points,
        cell_data={"name_to_read": [cell_data.astype(np.int32)]},
    return out_mesh
    l_a, 0, 0, l_coll, 0, 0, r_coll, 1
    0, 0, 0, l_a, 0, 0, r_a, 2
vol_c = gmsh.model.occ.addCylinder(0, 0, 0, l_c, 0, 0, r_c, 4)  # tag = 4
vol_trig = gmsh.model.occ.addCylinder(0, 0, 0, l_trig, 0, 0, r_trig, tag=5)  # tag = 5
# Add magnets:
if n_mag == 0:
    pass
elif n_mag > 0:
    angle_array = np.linspace(0, np.pi, n_mag + 1)[
        0:n_mag
    magnet_surface_list = []
    magnet_volume_list = []
            gmsh.model,
            l_a,
            r_coll,
            w_mag / 2,
            l_mag,
            h_mag,
            w_mag,
            angle,
            last_tag,
            magnet_volume_list,
flat_magnet_surface_tags = [tag for surf in magnet_surface_list for (dim, tag) in surf]
phys_col = gmsh.model.addPhysicalGroup(3, [vol_coll], 49, "collimator")
phys_a = gmsh.model.addPhysicalGroup(3, [vol_a], 50, "anode")
phys_c = gmsh.model.addPhysicalGroup(3, [vol_c], 51, "cathode")
phys_trig = gmsh.model.addPhysicalGroup(3, [vol_trig], 52, "trigger")
magnet_array = np.zeros(n_mag * 2 * 6)
        magnet_array[6 * mag_idx + surf_idx] = surface[1]
print("Entities")
for e in entities:
    print(f"dim:{e[0]}, tag:{e[1]}")
    print(f"{gmsh.model.get_physical_name(p[0], p[1])}, dim: {p[0]}, tag = {p[1]}")
    grouped_entities = gmsh.model.get_entities_for_physical_group(p[0], p[1])
    print(f"entities in {gmsh.model.get_physical_name(p[0], p[1])}: {grouped_entities}")
        dt = (p[0], int(g))
    misctags[d].append(e)
phys_names = ["points", "lines", "surfaces", "volumes"]
    if ii in misctags:
        phys_misc[ii] = gmsh.model.addPhysicalGroup(
            ii, misctags[ii], tag=-1, name=phys_names[ii]
        print(
            f"Physical group created for ungrouped {phys_names[ii]}, contains these tags: {misctags[ii]}"
for t in misctags[ii]:
    dt = (ii, t)
gmsh.model.mesh.generate()  # (3) # Generate in 3d
    gmsh.fltk.run()
gmsh.finalize()
print("Done")
it is quite easy to debug the issue, by adding the following:
print("Number of nodes in grid:", collimator_tetra.points.shape)
tetra_nodes = np.unique(collimator_tetra.cells_dict["tetra"].flatten())
print(
    "Number of unique nodes in grid:",
    len(tetra_nodes),
triangle_indices = np.unique(collimator_triangle.cells_dict["triangle"].flatten())
print(
    "Number of triangle nodes that are not in tetra grid:",
    np.sum(np.invert(np.isin(triangle_indices, tetra_nodes))),
which returns
Number of nodes in grid: (56547, 3)
Number of unique nodes in grid: 56516
Number of triangle nodes that are not in tetra grid: 31
which means that:
  1. You have more nodes in your grid that is in your tetrahedra.
  2. These nodes correspond to the indices of your triangles.
Adding:
gmsh.model.mesh.remove_duplicate_nodes()
gmsh.model.mesh.remove_duplicate_elements()
removes some duplicate nodes from your grid, but not all:
Number of nodes in grid: (56539, 3)
Number of unique nodes in grid: 56508
However, as your script is very long, it is a bit hard for me to pinpoint where you are making a mistake. According to gemini, the issue is that you use gmsh.model.embed and overlapping cells:
1. Misuse of the embed command
The embed command is designed to force a 3D mesh to conform to an internal lower-dimensional entity (like a 2D sheet completely inside a 3D box).
However, your magnets start at x = l_a, which is exactly the boundary face of the vol_coll cylinder. When you attempt to embed a surface that is flush with or touching the boundary of the parent volume, Gmsh’s 3D mesher struggles to integrate it. It successfully meshes the 2D surface (creating your extra triangles), but fails to connect them to the 3D tetrahedral grid of the volume. This leaves you with exactly what your debug script found: 2D nodes that aren’t part of any 3D tetrahedron.
2. Missing Boolean Operations (Overlapping Volumes)
You are creating overlapping 3D volumes (the magnets addBox and the collimator addCylinder), but you are never telling the OpenCASCADE (OCC) kernel how they interact. Without a Boolean operation like fragment or cut, Gmsh treats them as completely independent objects that happen to occupy the same space. It will mesh the collimator, and then it will mesh the magnets on top of it, generating massive amounts of overlapping elements and duplicate nodes.
The Fix
To resolve this properly, you need to use gmsh.model.occ.fragment() to compute the intersections between all your overlapping 3D shapes. This merges overlapping boundaries into shared surfaces, guaranteeing a perfectly conforming mesh without needing the embed command or manual duplicate removal.
Notes from my end.
I still couldn’t get gmsh to give a valid mesh, and gemini suggested the following:
The Diagnosis
1. The Root Cause: Duplicate Edges in the Surface Mesh
Error : ERROR: Edge 3 - 22 multiple times in surface mesh
The mesher builds a 3D mesh (tetrahedra) by starting from the 2D surface mesh (triangles) and working inward. However, it found that a specific edge (likely between points/nodes 3 and 22) is defined multiple times. This usually means your geometry is “non-manifold” (overlapping surfaces, unmerged duplicate lines, or poorly defined boundaries where two volumes touch).
2. The Consequence: Volumes Fail to Mesh
Warning : No elements in volume 9 10
Because the surface mesh bounding Volumes 9 and 10 is mathematically invalid (due to the duplicate edge mentioned above), the Frontal 3D meshing algorithm aborts for those specific volumes. They remain empty.
3. The Post-Processing Result: Orphaned Nodes
Number of unique nodes in grid: 58275 (out of 58324 total) Number of triangle nodes that are not in tetra grid: 49
Because Volumes 9 and 10 failed to generate 3D tetrahedra, the 2D triangles that make up their outer shell are left “floating.” Those 49 nodes belong to the surface mesh of Volumes 9/10, but since no 3D elements were generated inside them, they aren’t connected to the rest of the 3D grid.
How to Fix It
This is almost certainly a geometry issue, not a meshing parameter issue. You need to ensure that adjacent volumes share the exact same geometric faces, rather than having two overlapping faces touching each other.
Here are the standard steps to resolve this, assuming you are using Gmsh:
1. Use the Coherence Command (Recommended)
If you built the geometry natively in Gmsh using .geo scripting, add the Coherence; command at the very end of your geometry definitions, right before you generate the mesh.
  • Coherence; automatically searches for duplicate points, lines, and surfaces that share the same coordinates and merges them together, creating a watertight mesh.
2. Use Boolean Fragments (If using OpenCASCADE)
If you imported a CAD file (like a .step or .iges) or are using the OpenCASCADE kernel (SetFactory("OpenCASCADE");), you must ensure overlapping volumes are fragmented so their boundaries conform to one another. Add this after loading/creating your volumes:
Code snippet
// Replace the volume numbers with your actual volume tags, or use an array of all volumes
BooleanFragments { Volume{1:23}; Delete; }{}
This forces the CAD kernel to slice intersecting volumes and merge shared boundaries properly.
3. Inspect Edge 3-22
If Coherence or BooleanFragments doesn’t work, open the Gmsh GUI and look specifically at the geometry around Points/Lines 3 and 22.
  • Go to Tools > Visibility > Elementary entities and isolate lines/points 3 and 22.
  • You will likely find a tiny gap, a sliver surface, or a duplicate line in that exact spot that needs to be deleted or merged in your original CAD software.
4. Adjust Mesh Tolerance (Rare)
If the overlapping nodes are infinitesimally close but not mathematically identical, the mesher might not merge them. You can slightly increase the geometric tolerance in your script:
Code snippet
Geometry.Tolerance = 1e-4; // Adjust based on the scale of your model
Thanks so much for your response! (and my apologies for the formatting of my code - it pasted strangely and I thought I had caught all the issues, but clearly not!)
I removed the embed command and used fragment to compute the intersections between the shapes, as you suggested. You said that didn’t work for you, and originally it didn’t work for me either.
However, after some testing I found that I could generate a valid mesh if I used fragment on all the shapes other than the magnets, which were cut from the collimator instead.
In the Define Geometry section, I added:
fragment, fragment_map = gmsh.model.occ.fragment(
    [(3, vol_coll)],
        (3, vol_a),
        (3, vol_c),
        (3, vol_trig)
     -1)
vol_coll = fragment_map[0][0][1]
vol_a = fragment_map[1][0][1]
vol_c = fragment_map[2][0][1]
vol_trig = fragment_map[3][0][1]
vol_c_trig = fragment_map[3][1][1]
# The trigger sits within the cathode
# - this is the section of the trigger that overlaps with the cathode.
I moved the magnets so that they only overlap the collimator on 3 sides (having them sit completely inside the collimator resulted in the same duplicate edges error that Gemini mentions). I then added this line to my add_magnet_pair() function, where the magnets are added to the model:
# Cut magnets into the collimator - this ensures that the mesh cells in the magnet and the collimator are conformal
    dt, dtmap = model.occ.cut(
        [(3, vol_col)],
            (3, mag_1_vol),
            (3, mag_2_vol)
            -1,
            removeObject=True,
            removeTool=False)
    # The magnet and collimators are deleted and recreated when cut is used.
    # We then need to find their new tags programatically.
    vol_col = dtmap[0][0][1]
    mag_1_vol = dtmap[1][0][1]
    mag_2_vol = dtmap[2][0][1]
This produced the following output:
Number of nodes in grid: (58659, 3)
Number of unique nodes in grid: 58659
Number of triangle nodes that are not in tetra grid: 0
This was then loaded into FEniCSx without any issues!
I’m not sure why this worked - there are other shapes that overlap (e.g., the trigger and cathode) that work using fragment. But I’m glad it’s working now. Thank you so much for your advice!
