Hello all,
I know topic (reading the mesh from gmsh) has been posted and answered several times, even the documentation gives great clarity in explaining the subdomains. I heave tried with the different geometries before and worked fine.
But I am facing the wierd issue now of malloc in reading the mesh tags from the mesh imported from gmsh for this particular case although it writes the tags smoothly which I verified.
Here is MWE
comm = MPI.COMM_WORLD
rank = comm.rank
    out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read": [cell_data.astype(np.int32)]})
    return out_mesh
if rank == 0:
    domain = meshio.read("dp.msh")
    # Create and save one file for the mesh, and one file for the facets
    triangle_mesh = create_mesh(domain, "triangle", prune_z=True)
    line_mesh = create_mesh(domain, "line", prune_z=True)
    meshio.write("mt.xdmf", line_mesh)
MPI.COMM_WORLD.barrier()
with XDMFFile(MPI.COMM_WORLD, "mesh.xdmf", "r") as xdmf:
    ct = xdmf.read_meshtags(mesh, name="Grid")
mesh.topology.create_connectivity(mesh.topology.dim, mesh.topology.dim - 1)
with XDMFFile(MPI.COMM_WORLD, "mt.xdmf", "r") as xdmf:
    ft = xdmf.read_meshtags(mesh, name="Grid")
I don’t see an option of uploading the file here to upload my .msh file, in case you need to try on ur end, please let me know, I will just paste it here in comments.
Getting error while reading the tags
[0]PETSC ERROR: or see FAQ — PETSc 3.21.1 documentation and FAQ — PETSc 3.21.1 documentation
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
Thanks!
