Mesh adaptivity in fenics
Hello guys,
I would like to control the meshsize [h] based of value of the solution [u] i.e f(u) be the function/ criterion evaluated at each node. Then in 2d case with linear elements I will have 3 values for each element f_i(u)
One example for f(u) would be f(u):= u ||grad(u)|| / 25. Solution u is scalar quantity.
for each cell :
if h > max(f_i(u)) :
Perform refinement
This is used to solve nonliner solid mechanics problem with load step.
This is what I would like achieve this. But i don’t think demo example Auto adaptive Poisson equation won’t be helpful since it requires global criterion. However if I were to refine the mesh manually using refine function then I have to manually updated the spaces and also transfer the solution to the new mesh.
Is there a better approach to achieve this local adaptivity using some inbuilt functions of fenics?
Hello guys,
As with the second approach to manually adapting the mesh. The code would look something like:
# Sub domain for Dirichlet boundary condition
class DirichletBoundary(SubDomain):
        return abs(x[0] - 1.0) < DOLFIN_EPS and on_boundary
mesh = UnitSquareMesh(32, 32)
meshfile = File("mesh.pvd")
meshfile << mesh
# Define boundary condition
g = Expression("t",t=1.0,degree=1)
bc = DirichletBC(V, g, DirichletBoundary())
f = Expression("x[0]*sin(x[1])", degree=2)
F = inner((1 + u**2)*grad(u), grad(v))*dx - f*v*dx
#cell local refinement criterion
def meshAdaptivityMarker(mesh, uTemp):
	cellMarkers = MeshFunction("bool",mesh,2)
	cellMarkers.set_all(False)
	for cell in cells(mesh):
		coordinates = np.reshape(cell.get_coordinate_dofs(),(-1,mesh.geometry().dim()))
		cellRegPar = np.array([uTemp(x) for x in coordinates])
		minRegPara= np.nanmin(cellRegPar)
		if(cell.h() > minRegPara/147.0):
			cellMarkers[cell]=True
	return cellMarkers
# Save solution in VTK format
file = File("nonlinear_poisson.pvd")
# This for loops through various load step
for i in [1.0,2.0,3.0]:
	g.t = i
# Compute solution
	solve(F == 0, u, bc,
      	solver_parameters={"newton_solver":{"relative_tolerance":1e-6}})
	file << u
	cellMarkers = meshAdaptivityMarker(mesh, u)
	mesh = refine(mesh,cellMarkers)
	meshfile << mesh
However this approach is not optimal. So I would be very grateful for any advise to improve this or suggest any other approach.
Hi Djay92,
Have you found a solution for your problem?
I am wondering if I could use such a method to deal with large mesh deformation (?)
Thank you in advance,
