Hello everyone,
I am currently working on optimizing my structural mechanics code to enable remeshing during explicit dynamics simulations. I have been following the tutorials :
to make as many components as possible mesh-independent in my code, thereby reducing compilation/computation time when remeshing occurs.
However, I am stuck on whether it’s possible to abstract a nonlinear problem in this manner. Specifically, I believe there is no UFL equivalent to dolfinx.fem.Function - is this correct?
More specifically, the following code:
import basix.ufl
c_el = basix.ufl.element("Lagrange", "triangle", 1, shape=(2,))
domain = ufl.Mesh(c_el)
V = ufl.FunctionSpace(domain, c_el)
u = ufl.TrialFunction(V)
F = ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
u_func = dolfinx.fem.Function(V)
raises an error when creating the Function:
File ~/Téléchargements/compile_form (1).py:12
File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/function.py:319 in __init__
V.element.dtype, np.dtype(dtype).type(0).real.dtype
AttributeError: 'FunctionSpace' object has no attribute 'element'
Is there a way to define a functional F(u) where u is a Function defined on an abstract vector space V created from a ufl.Mesh?
Any insights or suggestions would be greatly appreciated.
Thank you!
