What is the current equivalent of =ufl.VectorElement= with =dolfinx.fem.FunctionSpace=?
Short description
The DOLFINx tutorial
(c9214c68438ab27d2fa8936307027c5209272162)
mentions that
creating a vector element `element = ufl.VectorElement(\“CG\”,
mesh.ufl~cell~(), 1) … , and intitializing the function space as `V
= dolfinx.fem.FunctionSpace(mesh, element)`
Current behaviour
However, trying that combination:
  File "<stdin>", line 1, in <module>
AttributeError: module 'dolfinx.mesh' has no attribute 'ufl_cell'
What I have tried (not working either)
I also tried with
element = basix.ufl.element("Lagrange", basix.CellType.hexahedron, 1)
V = dolfinx.fem.FunctionSpace(mesh, element)
  File "/usr/lib/python3.11/site-packages/dolfinx/fem/function.py", line 581, in FunctionSpace
    return functionspace(mesh, element, form_compiler_options, jit_options)
  File "/usr/lib/python3.11/site-packages/dolfinx/fem/function.py", line 527, in functionspace
    if ufl_e.cell() != mesh.ufl_domain().ufl_cell():
AttributeError: module 'dolfinx.mesh' has no attribute 'ufl_domain'
and
fem.FunctionSpace(ufl.VectorElement("Lagrange", ufl.hexahedron, 1))
MWE
import basix
from dolfinx import fem
from dolfinx import mesh
My system
* FEniCSx software
dolfinx: 0.7.0.dev0_r27554.cfeffe0-1
basix: 0.7.0.dev0_r945.1117a8d-1
ufl: 2023.2.0.dev0_r3562.77ae57c-1
ffcx: 0.7.0.dev0_r7077.1d27238-1
* Dependencies
python: 3.11.5-2
python-numpy: 1.26.0-1
petsc: 3.19.5.1171.g37df9106526-1
hdf5-openmpi: 1.14.2-1
boost: 1.83.0-2
adios2: 2.8.3-5
scotch: 7.0.4-1
pybind11: 2.11.1-1
python-build: 1.0.1-1
python-cffi: 1.15.1-4
python-cppimport: 22.08.02.r6.g0849d17-1
python-installer: 0.7.0-3
python-mpi4py: 3.1.4-3
python-pytest: 7.4.2-1
python-scikit-build: 0.17.6-1
python-setuptools: 1:68.0.0-1
python-wheel: 0.40.0-3
xtensor: 0.24.0-2
xtensor-blas: 0.20.0-1
* Operating system
Arch Linux: 6.5.4-arch2-1
Your mesh variable refers to the python module dolfinx.mesh, and not an actual dolfinx.mesh.Mesh instance. E.g.
import basix
mesh = dolfinx.mesh.create_unit_cube(MPI.COMM_WORLD, 1, 1, 1, cell_type=dolfinx.mesh.CellType.hexahedron)
Oh, ok. Thanks! That makes a lot of sense (to not use a module as in input parameter >.<). It also shows why the convenience function exists (2 shorter lines of code compared to 3 longer lines).
Is there any advantage of doing it as you showed? (compared to what is shown in the tutorial):
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([L, W, W])],
                  [20,6,6], cell_type=mesh.CellType.hexahedron)
V = fem.VectorFunctionSpace(domain, ("CG", 1))
The basix path provides much more control/power for custom elements and quadrature schemes. If you want a “fire and forget” continuous Galerkin basis on hexes, the method you’ve used immediately above is perfectly sufficient.
