Mesh refinement using dolfinx.mesh.refine_plaza()
Dear all, while using the above mentioned function in python interface of latest dolfinx v0.8.0 (conda), it seems to me that the returned parent_cells aren’t what they should be. Here’s a MWE to reproduce the results:
import dolfinx.mesh
import pyvista as pv
from dolfinx.cpp.refinement import RefinementOption
def main():
    msh_c = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 2, 2)
    msh_c.topology.create_entities(1)
    msh_f, parent_cells, _ = dolfinx.mesh.refine_plaza(msh_c, option=RefinementOption.parent_cell)
    for child, parent in enumerate(parent_cells):
        print(f"Child {child} has parent {parent}")
        child_vertices = dolfinx.mesh.compute_incident_entities(msh_f.topology, child, 2, 0)
        child_vertex_coords = msh_f.geometry.x[child_vertices]
        print(f"Child {child} has vertices {child_vertices} at {child_vertex_coords}")
        parent_vertices = dolfinx.mesh.compute_incident_entities(msh_c.topology, parent, 2, 0)
        parent_vertex_coords = msh_c.geometry.x[parent_vertices]
        print(f"Parent {parent} has vertices {parent_vertices} at {parent_vertex_coords}")
    # Plot fine mesh
    grid = pv.UnstructuredGrid(*dolfinx.plot.vtk_mesh(msh_f, msh_f.topology.dim))
    plotter = pv.Plotter(window_size=[1000, 1000])
    plotter.show_axes()
    plotter.show_grid()
    plotter.show()
if __name__ == "__main__":
    main()
If reproducing the result, be sure to first manually locally apply the fix to refine_plaza(): Input for mesh refinement with refine_plaza - #4 by francesco-ballarin.
Now, as you can see after running the example, child 6 for example does not have the right parent, as the output contains:
Child 6 has parent 1
Child 6 has vertices [4 6 8] at [[0.5 0. 0. ]
[0.5 0.25 0. ]
[0.25 0.25 0. ]]
Parent 1 has vertices [0 2 3] at [[0.5 0. 0. ]
[1. 0.5 0. ]
[0.5 0.5 0. ]]
From the vertices we can see that parent 1 does not contain child 6.
Is this a bug or am I interpreting the results wrong? If it’s a bug, is there any other way I can get the mesh cells’ parent-child relationships, or can it maybe be fixed easily? And if it’s the latter, how should they be interpreted?
I think what you want is:
msh_c = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 1, 1)
msh_f, parent_cells, _ = dolfinx.mesh.refine_plaza(msh_c, option=dolfinx.mesh.RefinementOption.parent_cell)
child_vertices = dolfinx.mesh.entities_to_geometry(msh_f, 2, np.arange(len(parent_cells), dtype=np.int32))
parent_vertices = dolfinx.mesh.entities_to_geometry(msh_c, 2, parent_cells)
for i, (child_vertex, parent_vertex) in enumerate(zip(child_vertices, parent_vertices)):
    print(f"Child {i} has parent {parent_cells[i]}")
    child_vertex_coords = msh_f.geometry.x[child_vertex]
    print(f"Child {i} has vertices {child_vertex} at {child_vertex_coords}")
    parent_vertex_coords = msh_c.geometry.x[parent_vertex]
    print(f"Parent {parent_cells[i]} has vertices {parent_vertex} at {parent_vertex_coords}")
i.e. this computes the relationship between the mesh topology and geometry before accessing the coordinates.
Seems like I’m getting the same output as before with your code (I only left both nx and ny of create_unit_square(comm, nx, ny) at 2). The problem persists.
Agreed. Illustrated with:
msh_f, parent_cells, _ = dolfinx.mesh.refine_plaza(msh_c, redistribute=False, option=dolfinx.mesh.RefinementOption.parent_cell)
num_cells = msh_c.topology.index_map(msh_c.topology.dim).size_local
marker = np.arange(num_cells, dtype=np.int32)
ct = dolfinx.mesh.meshtags(msh_c, msh_c.topology.dim, marker, marker)
ct_refined = dolfinx.mesh.meshtags(msh_f, msh_f.topology.dim, np.arange(len(parent_cells), dtype=np.int32), parent_cells)
with dolfinx.io.XDMFFile(msh_c.comm, "ct.xdmf", "w") as xdmf:
    xdmf.write_mesh(msh_c)
    xdmf.write_meshtags(ct, msh_c.geometry)
with dolfinx.io.XDMFFile(msh_c.comm, "ct_refined.xdmf", "w") as xdmf:
    xdmf.write_mesh(msh_f)
    xdmf.write_meshtags(ct_refined, msh_f.geometry)
yielding:
Issue made at: Parent cells not correct in refine_plaza · Issue #3303 · FEniCS/dolfinx · GitHub
Turns out you can get the mapping with the following:
msh_c = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 2, 5, ghost_mode=dolfinx.mesh.GhostMode.none)
ct_refined = dolfinx.mesh.MeshTags(dolfinx.cpp.refinement.transfer_cell_meshtag(ct._cpp_object, msh_f.topology, parent_cells))
with dolfinx.io.XDMFFile(msh_f.comm, "ct_refined.xdmf", "w") as xdmf:
where ct_refined.values is the map between cells in the refined mesh and cells in the original mesh.
