Cell numbering: inconsistent gmsh <=> dolfinx numbering
The cell numbering between gmsh elementTags and doflinx original_cell_indexis not consistent for the following with this mesh.msh:
import dolfinx.io.gmshio
from dolfinx import fem
import pyvista
model_rank = 0
mesh_comm = MPI.COMM_WORLD
gmsh.open("mesh.msh")
node_tags, xyz, _ = gmsh.model.mesh.getNodes()
_, tri_tags, triangles = gmsh.model.mesh.getElements(dim=2)
tag2idx = { _tag: _idx for (_idx, _tag) in enumerate(node_tags)}
vertices = xyz.reshape(-1, 3)
triangles = np.vectorize(tag2idx.get)(triangles[0].reshape(-1, 3))
barycenters = np.einsum("tvx -> tx", vertices[triangles]) / 3
f_arr = np.max(barycenters, axis=1)
view_tag = gmsh.view.add("f(x, y)")
gmsh.view.addModelData(view_tag, 0, '', "ElementData", tri_tags[0], f_arr.reshape(-1, 1))
gmsh.fltk.run()
mesh_data = dolfinx.io.gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=2)
DG0 = fem.functionspace(mesh_data.mesh, ("DG", 0))
P1 =  fem.functionspace(mesh_data.mesh, ("Lagrange", 1))
ugrid = pyvista.UnstructuredGrid(*vtk_mesh(P1))
f = fem.Function(DG0)
f.x.array[:] = f_arr[:]
plotter = pyvista.Plotter()
ugrid["f(x, y)"] = f.x.array[mesh_data.mesh.topology.original_cell_index]
plotter.add_mesh(ugrid)
plotter.view_xy()
plotter.show()
gmsh.finalize()
The same array seen respectively by gmsh and pyvista (based on dolfinx numbering)
See: Renumbered .msh imported data giving wrong subdomains - #4 by dokken
Thanks for your reply.
I already spotted this, but it is not exactly the same issue: here it is the numbering of cells instead of vertices (which [vertices] is actually ok in my case).
In my case, it works for simple geometries with few physical entities – by using the mapping mesh_data.mesh.topology.original_cell_index
Somehow, a “large” number of physical tags mess up this mapping.
Or I didn’t understand what was the solution you suggested (-:
My question is: how to feed dolfinx data array from gmsh array following the elementTags numbering, i.e. tri_tags[0] <=> f_arr[:]:
I specifically mention cell indices:
and I even show how to extract the cells in the correct way using GMSH:
ok, then I simply don’t understand the workflow you proposed
topologies_2 is the nodal definition of the cells.
What’s the next step?
I essentially need a numpy.array(dtype=int) (dolfinx2gmsh) mapping doflinx dofs to gmsh ones:
gmsh.view.addModelData(view_tag, 0, '', "ElementData", tri_tags[0], f_arr.reshape(-1, 1)[dolfinx2gmsh])
equivalent to
gmsh.view.addModelData(view_tag, 0, '', "ElementData", tri_tags[0][gmsh2dolfinx], f_arr.reshape(-1, 1))
It seems I have to brute force this mapping with the nodal definition (gmsh vs dolfinx), doesn’t it?
Doesn’t dolfinx keep track of its renumbering?
I tried
topologies_2 = []
entities = gmsh.model.getEntities()
entities_sorted = np.sort([e[1] for e in entities])
for obj in entities_sorted:
    (entity_types, entity_tags, entity_topologies) = gmsh.model.mesh.getElements(2, tag=obj)
    assert len(entity_types) == 1
    properties = gmsh.model.mesh.getElementProperties(entity_types[0])
    name, dim, _, num_nodes, _, _ = properties
    topology = entity_topologies[0].reshape(-1, num_nodes)
    topologies_2.append(topology)
topologies_2 = np.vstack(topologies_2)
which doesn’t yield what I expect.
topology_2is a numpy.array containing the nodal definition of elements in gmsh, which (at least in my case) corresponds to what is returned by gmsh.model.mesh.getElements(dim=2).
In other words, the order of collections coincide with this loop, which is the numbering of the geometrical entities (not physical).
Therefore, I do not see trivial solution to my matter.
Sorry for the inconvenience.
Ok, I understood how to proceed.
Here are the updates:
phys_grps = gmsh.model.getPhysicalGroups()
numbering = []
for dim, tag in phys_grps:
    if dim == 2:
        entities = gmsh.model.getEntitiesForPhysicalGroup(dim, tag)
        for entity in entities:
            (entity_types, entity_tags, entity_topologies) = gmsh.model.mesh.getElements(dim, tag=entity)
            numbering += entity_tags[0].tolist()
o_cell_idx= mesh_data.mesh.topology.original_cell_index
gmsh_to_index = {value: index for index, value in enumerate(element_tags[1])}
gmsh_to_dolfinx_mapping = np.array([gmsh_to_index[a] for a in numbering])
f.x.array[:] = f_arr[gmsh_to_dolfinx_mapping[o_cell_idx]]
Thank you for your time.
As you can see here, this has nothing to do with DOLFINx.
This is extracting each cell (entity) in GMSH in the order, and getting the nodal definition of them.
Here is a slightly adapted version of `dolfinx.io.gmshio.model_to_mesh, that can read in scalar fields or vector fields, as long as they are defined with physical groups.
Extract GMSH data (float values) from a mesh and assign to dolfinx mesh
Author: Jørgen S. Dokken
SPDX-License-Identifier: LGPL-3.0-or-later
Certain functions for topology extraction is adapted from DOLFINx (dolfinx.io.gmshio)
and is licensed under the LGPL-3.0-or-later license. The original code can be found at
https://github.com/FEniCS/dolfinx/blob/main/python/dolfinx/io/gmshio.py
import typing
import numpy.typing as npt
class ExtendedTopologyDict(dolfinx.io.gmshio.TopologyDict):
    element_tags: npt.NDArray[typing.Any]
def extract_topology_and_markers(
    model, name: typing.Optional[str] = None
) -> tuple[dict[int, ExtendedTopologyDict], dict[str, tuple[int, int]]]:
    """Extract all entities tagged with a physical marker in the gmsh model.
    Returns a nested dictionary where the first key is the gmsh MSH
    element type integer. Each element type present in the model
    contains the cell topology of the elements and corresponding
    markers.
    Args:
        model: Gmsh model.
        name: Name of the gmsh model. If not set the current
            model will be used.
    Returns:
        A tuple ``(topologies, physical_groups)``, where ``topologies`` is a
        nested dictionary where each key corresponds to a gmsh cell
        type. Each cell type found in the mesh has a 2D array containing
        the topology of the marked cell and a list with the
        corresponding markers. ``physical_groups`` is a dictionary where the key
        is the physical name and the value is a tuple with the dimension
        and tag.
    if name is not None:
        model.setCurrent(name)
    # Get the physical groups from gmsh in the form [(dim1, tag1),
    # (dim1, tag2), (dim2, tag3),...]
    phys_grps = model.getPhysicalGroups()
    topologies: dict[int, ExtendedTopologyDict] = {}
    # Create a dictionary with the physical groups where the key is the
    # physical name and the value is a tuple with the dimension and tag
    physical_groups: dict[str, tuple[int, int]] = {}
        # Get the entities of dimension `dim`, dim=0 -> Points, dim=1 -
        # >Lines, dim=2 -> Triangles/Quadrilaterals, etc.
        entities = model.getEntitiesForPhysicalGroup(dim, tag)
            # Get cell type, list of cells with given tag and topology
            # of tagged cells NOTE: Assumes that each entity only have
            # one cell-type,
            # i.e. facets of prisms and pyramid meshes are not supported
            (entity_types, entity_tags, entity_topologies) = model.mesh.getElements(
                dim, tag=entity
            # Determine number of local nodes per element to create the
            # topology of the elements
            properties = model.mesh.getElementProperties(entity_types[0])
            # Array of shape (num_elements,num_nodes_per_element)
            # containing the topology of the elements on this entity.
            # NOTE: Gmsh indexing starts with one, we therefore subtract
            # 1 from each node to use zero-based numbering
            topology = entity_topologies[0].reshape(-1, num_nodes) - 1
            # Create marker array of length of number of tagged cells
            marker = np.full_like(entity_tags[0], tag)
            # Group element topology and markers of the same entity type
            entity_type = entity_types[0]
            if entity_type in topologies.keys():
                topologies[entity_type]["topology"] = np.concatenate(
                    (topologies[entity_type]["topology"], topology), axis=0
                topologies[entity_type]["cell_data"] = np.hstack(
                    [topologies[entity_type]["cell_data"], marker]
                topologies[entity_type]["element_tags"] = np.hstack(
                    [topologies[entity_type]["element_tags"], entity_tags[0]]
                topologies[entity_type] = {
                    "topology": topology,
                    "cell_data": marker,
                    "element_tags": entity_tags[0],
        physical_groups[model.getPhysicalName(dim, tag)] = (dim, tag)
    return topologies, physical_groups
def create_msh_file():
    # Create geometric description of mesh with physical groups
    rectangle = gmsh.model.occ.addRectangle(0, 0, 0, 1, 1)
    gmsh.model.occ.synchronize()
    gmsh.model.addPhysicalGroup(2, [rectangle], 1)
    gmsh.model.mesh.generate(2)
    # Add data to physical group
    all_2D_tags = []
    all_2D_topologies = []
        if dim == 2:
                # All marked 2D tags
                (entity_types, entity_tags, entity_topologies) = (
                # Reshape topology to (num_cells, num_nodes_per_cell)
                all_2D_tags.append(entity_tags)
                all_2D_topologies.append(entity_topologies[0].reshape(-1, num_nodes))
    tags_for_computation = np.hstack(all_2D_tags)
    topologies_for_computation = np.vstack(all_2D_topologies)
    tag2idx = {_tag: _idx for (_idx, _tag) in enumerate(node_tags)}
    cells = np.vectorize(tag2idx.get)(topologies_for_computation)
    barycenters = np.einsum("tvx -> tx", vertices[cells]) / vertices[cells].shape[2]
    g_arr = barycenters[:, :2]
    view_tag = gmsh.view.add("g(x, y)")
        view_tag, 0, "", "ElementData", tags_for_computation[0], g_arr
    # NOTE: Needs this special write to write view data
    gmsh.view.write(view_tag, "mesh.msh")
    # gmsh.fltk.run()
    gmsh.finalize()
# Create mesh
rank = 0
gdim = 2
dtype = np.float64
if comm.rank == 0:
    create_msh_file()
comm.Barrier()
if comm.rank == rank:
    gmsh.merge("mesh.msh")
    tags = gmsh.view.getTags()
    assert len(tags) == 1
    # Extract geometry
    x = dolfinx.io.gmshio.extract_geometry(gmsh.model)
    # Extract topology
    topologies, physical_groups = extract_topology_and_markers(gmsh.model)
    # Extract Gmsh cell id, dimension of cell and number of nodes to
    # cell for each
    num_cell_types = len(topologies.keys())
    cell_information = dict()
    cell_dimensions = np.zeros(num_cell_types, dtype=np.int32)
    for i, element in enumerate(topologies.keys()):
        _, dim, _, num_nodes, _, _ = gmsh.model.mesh.getElementProperties(element)
        cell_information[i] = {"id": element, "dim": dim, "num_nodes": num_nodes}
        cell_dimensions[i] = dim
    # Sort elements by ascending dimension
    perm_sort = np.argsort(cell_dimensions)
    # Broadcast cell type data and geometric dimension
    cell_id = cell_information[perm_sort[-1]]["id"]
    tdim = cell_information[perm_sort[-1]]["dim"]
    num_nodes = cell_information[perm_sort[-1]]["num_nodes"]
    cell_id, num_nodes = comm.bcast([cell_id, num_nodes], root=rank)
    cells = np.asarray(topologies[cell_id]["topology"], dtype=np.int64)
    cell_values = np.asarray(topologies[cell_id]["cell_data"], dtype=np.int32)
    physical_groups = comm.bcast(physical_groups, root=rank)
    cell_id, num_nodes = comm.bcast([None, None], root=rank)
    cells, x = (
        np.empty([0, num_nodes], dtype=np.int32),
        np.empty([0, gdim], dtype=dtype),
    cell_values = np.empty((0,), dtype=np.int32)
    physical_groups = comm.bcast(None, root=rank)
# Create distributed mesh
ufl_domain = dolfinx.io.gmshio.ufl_mesh(cell_id, gdim, dtype=dtype)
gmsh_cell_perm = dolfinx.io.gmshio.cell_perm_array(
    dolfinx.cpp.mesh.to_type(str(ufl_domain.ufl_cell())), num_nodes
cells = cells[:, gmsh_cell_perm].copy()
partitioner = dolfinx.cpp.mesh.create_cell_partitioner(
    dolfinx.mesh.GhostMode.shared_facet
mesh = dolfinx.mesh.create_mesh(
    comm, cells, x[:, :gdim].astype(dtype, copy=False), ufl_domain, partitioner
# Create MeshTags for cells
local_entities, local_values = dolfinx.io.gmshio.distribute_entity_data(
    mesh, mesh.topology.dim, cells, cell_values
mesh.topology.create_connectivity(mesh.topology.dim, 0)
adj = dolfinx.graph.adjacencylist(local_entities)
ct = dolfinx.mesh.meshtags_from_entities(
    mesh, mesh.topology.dim, adj, local_values.astype(np.int32, copy=False)
ct.name = "Cell tags"
def find_position(data, values):
    Find the position in values of each entry in data
    Example:
        .. highlight:: python
        .. code-block:: python
            values = np.array([4, 5, 1, 3, 2], dtype=np.int32)
            data = np.array([1, 2, 3, 4, 5, 2, 1], dtype=np.int32)
            b = find_position(data, values) # [2,4,3,0,1,4 2]
    if len(data) == 0:
        return np.zeros(0, dtype=np.int32)
    return (values == data[:, None]).argmax(1)
if comm.rank == 0:
    # Extract the new data in order
    cell_data = topologies[cell_id]["element_tags"]
    model_data = gmsh.view.get_model_data(tags[0], 0)
    _, tags, data, time, num_components = model_data
    position = find_position(cell_data, tags)
    sorted_data = np.asarray(data).reshape(-1, num_components)[position]
    cell_data = np.zeros(0, dtype=np.int64)
    num_components = 0
num_components = comm.bcast(num_components, root=0)
if comm.rank != 0:
    sorted_data = np.zeros((0, num_components), dtype=dtype)
# Gather the data on all processes
# NOTE: This could be done in a more efficient way
sorted_data = comm.bcast(sorted_data, root=0)
cell_data = sorted_data[mesh.topology.original_cell_index, :]
Q = fem.functionspace(mesh, ("DG", 0, (num_components,)))
q = fem.Function(Q)
q.x.array[:] = cell_data.flatten()
with dolfinx.io.XDMFFile(mesh.comm, "data.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh)
    xdmf.write_function(q)
