Meshtags_from_entities(), incompatible function arguments
Hi all,
I just upgraded dolfinx from version 0.5.2 to version 0.8.0. I tried to relaunch the code provided to me in example by @dokken (Get boundary points from custom cell tags)
from shapely import Polygon, Point
from dolfinx.io.gmshio import model_to_mesh
import dolfinx.plot as plot
import pyvista
pyvista.set_jupyter_backend("static")
pyvista.start_xvfb()
rank = MPI.COMM_WORLD.rank
rect1 = np.array([[1, 1], [4, 1], [4, 4], [1, 4], [1, 1]], dtype=np.float64)
rect2 = np.array([[0, 0], [10, 0], [10, 5], [0, 5], [0, 0]], dtype=np.float64)
rect1_tags = []
rect2_tags = []
for point1, point2 in zip(rect1, rect2):
    p1 = gmsh.model.occ.addPoint(point1[0], point1[1], 0, 1)
    p2 = gmsh.model.occ.addPoint(point2[0], point2[1], 0, 1)
    rect1_tags.append(p1)
    rect2_tags.append(p2)
gmsh.model.occ.synchronize()
rect1_wire = []
rect2_wire = []
for ii in range(len(rect1_tags)):
    if ii > 0:
        l1 = gmsh.model.occ.addLine(rect1_tags[ii - 1], rect1_tags[ii])
        l2 = gmsh.model.occ.addLine(rect2_tags[ii - 1], rect2_tags[ii])
        rect1_wire.append(l1)
        rect2_wire.append(l2)
gmsh.model.occ.addCurveLoop(rect1_wire, 1)
gmsh.model.occ.addCurveLoop(rect2_wire, 2)
gmsh.model.occ.addPlaneSurface([1], 1)
gmsh.model.occ.addPlaneSurface([1, 2], 2)
gmsh.model.addPhysicalGroup(2, [1], 1)
gmsh.model.addPhysicalGroup(2, [2], 2)
# generate 2D mesh
gmsh.option.setNumber("Mesh.Algorithm", 2)
gmsh.model.mesh.generate(2)
gmsh.write("mesh.geo_unrolled")
model_rank = 0
mesh_comm = MPI.COMM_WORLD
cell_partitioner = dolfinx.mesh.create_cell_partitioner(dolfinx.mesh.GhostMode.shared_facet)
mesh, ct, ft = model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=2, partitioner=cell_partitioner)
gmsh.finalize()
def create_meshtags(
    mesh: dolfinx.mesh.Mesh, poly: Polygon
) -> dolfinx.cpp.mesh.MeshTags_int32:
    cells = mesh.topology.connectivity(mesh.topology.dim, 0)
    id_cells_inpoly = []
    for ii in range(len(cells)):
        triangle = Polygon(mesh.geometry.x[cells.links(ii)])
        centroid = triangle.centroid
        if poly.contains(Point(centroid)):
            id_cells_inpoly.append(ii)
    values = np.zeros([len(cells), 1], dtype=np.int32)
    values[id_cells_inpoly] = 1
    meshtags = dolfinx.mesh.meshtags_from_entities(
        mesh, mesh.topology.dim, cells, values
    return meshtags
def plot_meshtags(
    meshtags: dolfinx.cpp.mesh.MeshTags_int32,
    filename: str = "meshtags.png",
    # Create VTK mesh
    cells, types, x = plot.create_vtk_mesh(mesh)
    grid = pyvista.UnstructuredGrid(cells, types, x)
    # Attach the cells tag data to the pyvita grid
    grid.cell_data["Marker"] = meshtags.values
    grid.set_active_scalars("Marker")
    plotter = pyvista.Plotter()
    plotter.add_mesh(grid, show_edges=True, show_scalar_bar=False)
    plotter.view_xy()
    if not pyvista.OFF_SCREEN:
        plotter.show()
        plotter.screenshot(filename)
# plot original cell tags
plot_meshtags(mesh, ct)
# create custom cell tags
ct = create_meshtags(mesh, Polygon(rect1))
# plot custom cell tags
cell_map = mesh.topology.index_map(mesh.topology.dim)
vertex_map = mesh.topology.index_map(0)
mesh.topology.create_entities(mesh.topology.dim-1)
facet_map = mesh.topology.index_map(mesh.topology.dim-1)
f_to_c =  mesh.topology.connectivity(mesh.topology.dim-1, mesh.topology.dim)
f_to_v =  mesh.topology.connectivity(mesh.topology.dim-1, 0)
assert len(ct.indices) == cell_map.size_local + cell_map.num_ghosts
exterior_facets = dolfinx.mesh.exterior_facet_indices(mesh.topology)
vertex_marker = np.zeros(vertex_map.size_local + vertex_map.num_ghosts, dtype=np.int32)
for facet in range(facet_map.size_local+ facet_map.num_ghosts):
    cells = f_to_c.links(facet)
    cell_markers = ct.values[cells]
    # If exterior facet and connected cell is marked with 1
    if 1 in cell_markers and facet in exterior_facets:
        vertices = f_to_v.links(facet)
        vertex_marker[vertices] = 1
    # If on interface between the two domains
    if 1 in cell_markers and 0 in cell_markers:
vt = dolfinx.mesh.meshtags(mesh, 0, np.arange(len(vertex_marker), dtype=np.int32), vertex_marker)
with dolfinx.io.XDMFFile(mesh.comm, "vertices.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh)
    mesh.topology.create_connectivity(0, mesh.topology.dim)
    xdmf.write_meshtags(vt)
However, now I get the following error:
  line 534, in meshtags_from_entities
    return MeshTags(_cpp.mesh.create_meshtags(mesh.topology, dim, entities, values))
TypeError: create_meshtags(): incompatible function arguments. The following argument types are supported:
    1. create_meshtags(arg0: dolfinx.cpp.mesh.Topology, arg1: int, arg2: dolfinx.cpp.graph.AdjacencyList_int32, arg3: ndarray[dtype=int8, writable=False, shape=(*), order='C'], /) -> dolfinx.cpp.mesh.MeshTags_int8
    2. create_meshtags(arg0: dolfinx.cpp.mesh.Topology, arg1: int, arg2: dolfinx.cpp.graph.AdjacencyList_int32, arg3: ndarray[dtype=int32, writable=False, shape=(*), order='C'], /) -> dolfinx.cpp.mesh.MeshTags_int32
    3. create_meshtags(arg0: dolfinx.cpp.mesh.Topology, arg1: int, arg2: dolfinx.cpp.graph.AdjacencyList_int32, arg3: ndarray[dtype=int64, writable=False, shape=(*), order='C'], /) -> dolfinx.cpp.mesh.MeshTags_int64
    4. create_meshtags(arg0: dolfinx.cpp.mesh.Topology, arg1: int, arg2: dolfinx.cpp.graph.AdjacencyList_int32, arg3: ndarray[dtype=float64, writable=False, shape=(*), order='C'], /) -> dolfinx.cpp.mesh.MeshTags_float64
Invoked with types: dolfinx.cpp.mesh.Topology, int, dolfinx.cpp.graph.AdjacencyList_int32, ndarray
Can anyone help me? Thanks in advance.
Hi mnotazio,
The problem is in the shape of the values array in create_meshtags(). Changing line 72 to
values = np.zeros(len(cells), dtype=np.int32)
should do the trick, at least the plots generated by your code looks good when I run the code with this change. The reason this change is needed is that dolfinx.mesh.meshtags_from_entities() takes the meshtag values as an ndarray, and your syntax
creates and ndarray of ndarrays. I would recommend printing both of the two versions of creating the array to see this.
Additionally, I could not run the code with Dolfinx version 0.8.0 without changing
to
cells, types, x = plot.vtk_mesh(mesh)
on line 86, and also
to
xdmf.write_meshtags(vt, mesh.geometry)
on line 136, since both of these syntaxes have changed.
Cheers,
Halvor
Hi @hherlyng,
Works like a charm, thank you so much!
