I have a problem that requires to define a submesh of different topology and then relate the dofs of each mesh with each other (considering that the same vertex at each mesh has the same dofs). This works fine in serial, however, when I moved to parallel I found some issues on how MeshView deals with the shared vertex dofs. Here is an MWE of a rectangle mesh, where the submesh is just the upper and lower boundary:
import dolfin as d
nx, ny = 8, 6
#%% Parent mesh
mesh = d.RectangleMesh(d.Point(0., -1), d.Point(10., 1.), nx, ny)
d.File('mesh/mesh.pvd') << mesh
comm = mesh.mpi_comm()
rank = comm.rank
V = d.VectorFunctionSpace(mesh, 'CG', 1)
dofmap = V.dofmap()
u = d.Function(V)
dofs = d.Function(V)
dofs.rename('dofs', 'dofs')
dofs.vector().set_local(np.arange(dofs.vector().local_size())+ dofmap.ownership_range()[0])
d.File('dofs.pvd') << dofs
#%% Submesh
class Surface(d.SubDomain):
return (d.near(x[1], -1.) or d.near(x[1], 1)) and on_boundary
surf = Surface()
marker = d.MeshFunction("size_t", mesh, mesh.topology().dim() - 1, 0)
surf.mark(marker, 1)
submesh = d.MeshView.create(marker, 1)
SV = d.VectorFunctionSpace(submesh, 'CG', 1)
sdofmap = SV.dofmap()
us = d.Function(SV)
sdofs = d.Function(SV)
sdofs.rename('sdofs', 'sdofs')
sdofs.vector().set_local(np.arange(sdofs.vector().local_size()) +
sdofmap.ownership_range()[0])
d.File('sdofs.pvd') << sdofs
#%% Unowned dofs
print(rank, 'parent', dofmap.local_to_global_unowned())
print(rank, 'submesh', sdofmap.local_to_global_unowned())
If I run these MWE with two processors, I have 7 shared vertex in the parent mesh and 2 in the submesh (one in the upper boundary, one in the lower). I would expect that, if the dofs of the shared upper node on the parent mesh belongs to the partition 0, then the dofs of this node on the submesh belongs to this partition too. This way I can relate all the dofs of one parent partition with the dofs of the submesh partition. However, this is not the case. If I plot the dofs at each partition, I get something like these (if the value is 0 it means that the dofs doesn’t belong to the partition):
Here you can see that the X dof of the upper shared node belongs to the left partition in the submesh whereas it belongs to the right partition in the parent mesh. This doesn’t happen always, for example, if I use a coarser mesh (nx=ny=4) I get the desired behavior:
In summary, I want to be able to relate the dofs of a submesh to the parent mesh inside a partition. Right now, I can’t do that because the shared vertex dofs are not distributed equally in the parent and the submesh. It wasn’t so easy to explain, so I hope I made it clear.
Thank you!
