Hi community,
I am struggling to assign values to a function on a submesh from the parent mesh. I have referred to previous posts like first, second, and third.
Problem definition: I have a “mesh_complete” which is a UnitCubeMesh and function “u” defined on the same mesh. I also have a solid mesh which I only use to create a boundary mesh and project the boundary on the “mesh_complete” such as to define a subdomain in the overlapping region on “mesh_complete”.
Next in the overlapping region, I intend to create a submesh (using MeshView because that works in parallel) and create a function “u_cut” on the submesh and assign same values as the original function “u”. Check out the following MWE:
from dolfin import *timer_total = Timer(“Total_run_time”)
wall_time = 0
timer_total.start()mesh_complete = UnitCubeMesh(16,16,16)
V = FunctionSpace(mesh_complete, “Lagrange”, 2)
complete_dofmap = V.dofmap()u = Function(V)
u = interpolate(Expression(“x[1]”, degree=2), V)mesh_solid = BoxMesh(Point(0.2, 0.2, 0.2), Point(0.6, 0.6, 0.6), 11, 11, 11)
bmesh = BoundaryMesh(mesh_solid, ‘exterior’)class MyDomain(SubDomain):
return Truemark_sub_domain = MeshFunction(“size_t”, mesh_complete, mesh_complete.topology().dim(), 0)
mark_sub_domain.set_all(0)
mark_domain = MyDomain() # ? --------------------------
mark_domain.mark(mark_sub_domain, 1)
cut_mesh = MeshView.create(mark_sub_domain, 1)V_cut = VectorFunctionSpace(cut_mesh, “Lagrange”, 2)
u_cut = Function(V_cut)
cut_dofmap = V_cut.dofmap()cut = cut_mesh.topology().mapping()[mesh_complete.id()].cell_map()
for c in cells(cut_mesh):
u_cut.vector()[cut_dofmap.cell_dofs(c.index())] = 0.0 # Assign same values from uFile(‘u.pvd’) << u
File(‘u_cut.pvd’) << mark_sub_domainwall_time = timer_total.stop()
print(wall_time)
My issues are specifically:
- I am not able to create the subdomain on mesh_complete in the overlapping region.
- I am not able to assign the correct values to u_cut in an efficient manner such that it also works for 2nd order vector elements in MPI.
I am using FEniCS 2019-dev version. I have been struggling on this for a while, any suggestions are highly appreciated! ![]()
