I'm trying to solve a coupled micromagnetic problem on two domains with fenicsx v0.9.0 that is installed with conda involving:
- Magnetization (a 3D vector field),
- Scalar magnetic potential, and
- Lagrange multiplier to enforce unit norm of the magnetization.
These fields are defined in a mixed space, but only the scalar potential phi is defined over the entire domain. The magnetization and the Lagrange multiplier are defined only on a subdomain (inner region). The residual and jacobian are constructed with ufl.extract_blocks with entity_maps, and passed into the solver. However, I get the following error and quite unsure about what it means,
Any suggestions would be much appreciated.
Error
self._solver.solve(self.b, self.dx)
File "petsc4py/PETSc/KSP.pyx", line 1782, in petsc4py.PETSc.KSP.solve
petsc4py.PETSc.Error: error code 73
[0] KSPSolve() at /Users/runner/miniforge3/conda-bld/bld/rattler-build_petsc_1738766455/work/src/ksp/ksp/interface/itfunc.c:1094
[0] KSPSolve_Private() at /Users/runner/miniforge3/conda-bld/bld/rattler-build_petsc_1738766455/work/src/ksp/ksp/interface/itfunc.c:843
[0] KSPSetUp() at /Users/runner/miniforge3/conda-bld/bld/rattler-build_petsc_1738766455/work/src/ksp/ksp/interface/itfunc.c:427
[0] PCSetUp() at /Users/runner/miniforge3/conda-bld/bld/rattler-build_petsc_1738766455/work/src/ksp/pc/interface/precon.c:1086
[0] PCSetUp_ILU() at /Users/runner/miniforge3/conda-bld/bld/rattler-build_petsc_1738766455/work/src/ksp/pc/impls/factor/ilu/ilu.c:135
[0] MatILUFactorSymbolic() at /Users/runner/miniforge3/conda-bld/bld/rattler-build_petsc_1738766455/work/src/mat/interface/matrix.c:7094
[0] MatILUFactorSymbolic_SeqAIJ() at /Users/runner/miniforge3/conda-bld/bld/rattler-build_petsc_1738766455/work/src/mat/impls/aij/seq/aijfact.c:1738
[0] Object is in wrong state
[0] Matrix is missing diagonal entry 2997
Main Code
import random
from dolfinx import mesh, fem, default_scalar_type
from dolfinx.fem import Function, locate_dofs_geometrical, locate_dofs_topological
from dolfinx import io
from math import pi, sqrt
from customNewtonSolver import *
Amp, LE, GE, ZE= 1.e0, 1.e0, 1.e0, 1.e0
mu0D = 4 * pi * 1.e-7 * (GE*LE)/(Amp**2*ZE**2)
mu1D = 1.25 * 1.e-1 * (GE*LE)/(Amp**2*ZE**2)
K1D = 5 * 1.e2 * GE/(ZE*ZE*LE)
AexD = 1.3 * 1.e-11 * (GE*LE)/(ZE*ZE)
MsD = 8 * 1.e5 * Amp / LE
g0D = 2.21 * 1.e5 * (Amp*ZE)/GE
#Non-Dimensional Parameters
mu0S , AexS, K1S = 1, 1, 1
MsS = sqrt(mu0D / K1D) * MsD
msh , cell_markers, facet_markers = io.gmshio.read_from_msh("trapezoidal_prisms.msh", MPI.COMM_WORLD,0, gdim=3)
cells_outer = cell_markers.find(2)
cells_inner = cell_markers.find(1)
inner_sm, inner_to_msh = mesh.create_submesh(msh, msh.topology.dim, cells_inner)[0:2]
# Material properties
mu0 = fem.Constant(msh, default_scalar_type(mu0S))
Ms = fem.Constant(msh, default_scalar_type(MsS))
Aexc = fem.Constant(inner_sm, default_scalar_type(AexS))
K1 = fem.Constant(inner_sm, default_scalar_type(K1S))
kl = fem.Constant(inner_sm, default_scalar_type(1.e5))
alpha = fem.Constant(inner_sm, default_scalar_type(1.e0))
t = 0.
tmax = g0D * K1D * (1.e2 * ZE * 1.e-9) / (MsD * mu0D)
dt = tmax / 2.e7
fs_m = fem.functionspace(inner_sm, ("Lagrange", 1, (msh.geometry.dim, )))
fs_l = fem.functionspace(inner_sm, ("Lagrange", 1))
fs_phi = fem.functionspace(msh, ("Lagrange", 1))
V = ufl.MixedFunctionSpace(fs_m, fs_phi, fs_l)
m = fem.Function(fs_m, name="Magnetization")
m0 = fem.Function(fs_m, name="Magnetization") #previous solution
phi = fem.Function(fs_phi, name="Magnetic Potential")
l = fem.Function(fs_l, name="Lagrange Multiplier")
dm, dphi, dl = ufl.TrialFunctions(V)
dH = -ufl.grad(dphi)
m_var = ufl.variable(m)
l_var = ufl.variable(l)
H = -ufl.grad(phi)
H_var = ufl.variable(H)
a=ufl.as_vector([1, 0, 0])
psi_mag = - 0.5 * mu0 * ufl.dot(H, H) - mu0 * Ms * ufl.dot(m, H)
psi_exc = Aexc * ufl.inner(ufl.grad(m), ufl.grad(m))
psi_ani = K1 * (1. - ufl.dot(m, a)**2)
psi_lag = l*(ufl.dot(m, m) - 1) - 0.5*l*l / kl
psi = (psi_mag + psi_exc + psi_ani + psi_lag)
B = -ufl.diff(psi, H_var)
T = ufl.diff(psi, m_var)
fdim = msh.topology.dim - 1
node = locate_dofs_geometrical(fs_phi, lambda x: np.isclose(x[0], 0.0) & np.isclose(x[1], 0.0) & np.isclose(x[2], 0.0))
bc_phi1 = fem.dirichletbc(fem.Constant(inner_sm, default_scalar_type(1)), node, fs_phi)
bcs = [bc_phi1]
def initial_condition(x):
values = np.zeros((3, x.shape[1]))
for i in range(x.shape[1]):
x_r, y_r, z_r = np.random.random(), np.random.random(), np.random.random()
norm = np.sqrt(x_r**2 + y_r**2 + z_r**2) + 1e-12
values[:, i] = np.array([x_r, y_r, z_r]) / norm
return values
m.interpolate(initial_condition)
m.x.scatter_forward()
cell_imap = msh.topology.index_map(msh.topology.dim)
num_cells = cell_imap.size_local + cell_imap.num_ghosts
msh_to_inner = np.full(num_cells, -1)
msh_to_inner[inner_to_msh] = np.arange(len(inner_to_msh))
entity_maps = {inner_sm: msh_to_inner}
marker = np.ones(num_cells, dtype=np.int32)
marker[cells_inner] = 2
cell_tag = mesh.meshtags(msh, 3, np.arange(num_cells, dtype=np.int32), marker)
dx = ufl.Measure("dx", domain=msh, subdomain_data=cell_tag)
F0 = ufl.dot(dH, B) * dx
F1 = alpha * ufl.dot(dm, T + (m-m0)/dt) * dx(2) + alpha * 2 * Aexc * ufl.inner(ufl.grad(m), ufl.grad(dm)) * dx(2)
F2 = (ufl.dot(m,m) - 1 - l/kl) * dl * dx(2) + 2*l*ufl.dot(m, dm) * dx(2)
F = F0 + F1 + F2
residual = fem.form(ufl.extract_blocks(F), entity_maps=entity_maps)
m_, phi_, l_ = ufl.TestFunctions(V)
jac = ufl.derivative(F, m, m_) + ufl.derivative(F, phi, phi_) + ufl.derivative(F, l, l_)
J = fem.form(ufl.extract_blocks(jac), entity_maps=entity_maps)
solver = customNewtonSolver(residual, J, [m, phi, l], bcs)
tot_step = tmax/dt
counter, ii = 0, 0
m0.x.array[:] = m.x.array
while t < tmax:
n, bConverged = solver.solve()
phi.x.scatter_forward()
l.x.scatter_forward()
if n==0:
break
Solver
from dolfinx import fem
from dolfinx.cpp.la.petsc import scatter_local_vectors
class customNewtonSolver():
max_iterations: int
bcs: list[fem.DirichletBC]
A: PETSc.Mat
b: PETSc.Vec
J: fem.Form
b: fem.Form
dx: PETSc.Vec
def __init__(self, F: list[fem.form], J: list[list[fem.form]], w: list[fem.Function],
bcs: list[fem.DirichletBC] | None = None, max_iterations: int = 5,
petsc_options: dict[str, str | float | int | None] = None,
problem_prefix="newton"):
self.max_iterations = max_iterations
self.bcs = [] if bcs is None else bcs
self.b = fem.petsc.create_vector_block(F)
self.F = F
self.J = J
self.A = fem.petsc.create_matrix_block(J)
self.dx = self.A.createVecLeft()
self.w = w
self.x = fem.petsc.create_vector_block(F)
# Set PETSc options
opts = PETSc.Options()
opts.prefixPush(problem_prefix)
if petsc_options is not None:
for k, v in petsc_options.items():
opts[k] = v
opts.prefixPop()
# Define KSP solver
self._solver = PETSc.KSP().create(self.b.getComm().tompi4py())
self._solver.setOperators(self.A)
self._solver.setFromOptions()
# Set matrix and vector PETSc options
self.A.setOptionsPrefix(problem_prefix)
self.A.setFromOptions()
self.b.setOptionsPrefix(problem_prefix)
self.b.setFromOptions()
def solve(self, tol=1e-6, beta=1.0):
i = 0
while i < self.max_iterations:
scatter_local_vectors(
self.x,
[si.x.petsc_vec.array_r for si in self.w],
(si.function_space.dofmap.index_map, si.function_space.dofmap.index_map_bs)
for si in self.w
self.x.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
# Assemble F(u_{i-1}) - J(u_D - u_{i-1}) and set du|_bc= u_D - u_{i-1}
self.b.zeroEntries()
fem.petsc.assemble_vector_block(self.b, self.F, self.J, bcs=self.bcs, x0=self.x)
self.b.ghostUpdate(PETSc.InsertMode.INSERT_VALUES, PETSc.ScatterMode.FORWARD)
# Assemble Jacobian
self.A.zeroEntries()
fem.petsc.assemble_matrix_block(self.A, self.J, bcs=self.bcs)
self.A.assemble()
assert self._solver.getConvergedReason() > 0, "Linear solver did not converge"
offset_start = 0
for s in self.w:
num_sub_dofs = s.function_space.dofmap.index_map.size_local * s.function_space.dofmap.index_map_bs
s.x.array[:num_sub_dofs] -= beta * self.dx.array_r[offset_start:offset_start + num_sub_dofs]
s.x.scatter_forward()
offset_start += num_sub_dofs
# Compute norm of update
correction_norm = self.dx.norm(0)
print(f"Iteration {i}: Correction norm {correction_norm}")
if correction_norm < tol:
break
i += 1
Mesh Generation Code
import sys
import pygmsh
from dolfinx.cpp.mesh import create_mesh
gmsh.model.add("trapezoidal_prisms")
# Define the points
Lx = 0.37210420376762543
Ly = 0.01860521018838127
Lz = 0.18605210188381271
Ly_mid = Ly
Lz_mid = Lz
LMesh = 1.2*Ly
# Left prism points
p1 = gmsh.model.occ.addPoint(0, Ly-Ly, Lz-Lz, LMesh)
p2 = gmsh.model.occ.addPoint(0, Ly+Ly, Lz-Lz, LMesh)
p3 = gmsh.model.occ.addPoint(0, Ly+Ly, Lz+Lz, LMesh)
p4 = gmsh.model.occ.addPoint(0, Ly-Ly, Lz+Lz, LMesh)
# Right prism points
p9 = gmsh.model.occ.addPoint(Lx/2, Ly-Ly_mid, Lz-Lz_mid, LMesh)
p10 = gmsh.model.occ.addPoint(Lx/2,Ly+ Ly_mid,Lz -Lz_mid, LMesh)
p11 = gmsh.model.occ.addPoint(Lx/2,Ly+ Ly_mid,Lz+ Lz_mid, LMesh)
p12 = gmsh.model.occ.addPoint(Lx/2,Ly-Ly_mid, Lz+Lz_mid,LMesh)
p5 = gmsh.model.occ.addPoint(Lx,Ly -Ly,Lz -Lz, LMesh)
p6 = gmsh.model.occ.addPoint(Lx,Ly+ Ly,Lz -Lz, LMesh)
p7 = gmsh.model.occ.addPoint(Lx,Ly+ Ly,Lz+ Lz, LMesh)
p8 = gmsh.model.occ.addPoint(Lx,Ly -Ly,Lz+ Lz, LMesh)
# ... [Lines, surfaces, loops and volume creation code] ...
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 8*LMesh)
gmsh.model.occ.synchronize()
left_surf = [idx for (dim, idx) in map_to_input[1] if dim == 3]
right_surf = [idx for (dim, idx) in map_to_input[0] if dim == 3 and idx not in left_surf]
gmsh.model.addPhysicalGroup(3, left_surf, tag=1)
gmsh.model.addPhysicalGroup(3, right_surf, tag=2)
gmsh.model.mesh.generate(3)
gmsh.write("trapezoidal_prisms.msh")
