Solve poisson equation with three submeshes
Hi all,
I’m trying to leverage the entity_maps introduced in dolfinx 0.8.0 to solve a poisson equation on a unit square but with three submeshes codim 0.
Ultimately, I would like to model interface discontinuities using a DG method but have CG elements within the domains to obtain this:
For now, I’m simply trying to understand how to solve a poisson equation (without these discontinuities) on three submeshes.
This is the code that I have:
from dolfinx import mesh, fem
import dolfinx.fem.petsc
import dolfinx.nls.petsc
from ufl import grad, dot, jump, avg
msh = mesh.create_unit_square(MPI.COMM_WORLD, 100, 100)
V = fem.functionspace(msh, ("DG", 1))
tol = 1e-16
def left_domain(x):
    return x[0] < 0.5 + tol
def top_right_domain(x):
    return np.logical_and(x[0] > 0.5 - tol, x[1] > 0.5 - tol)
def bottom_right_domain(x):
    return np.logical_and(x[0] > 0.5 - tol, x[1] < 0.5 + tol)
tdim = msh.topology.dim
fdim = tdim - 1
c_to_f = msh.topology.connectivity(tdim, tdim - 1)
f_to_c = msh.topology.connectivity(tdim - 1, tdim)
facet_map = msh.topology.index_map(tdim - 1)
cell_imap = msh.topology.index_map(tdim)
left_cells = mesh.locate_entities(msh, tdim, left_domain)
top_right_cells = mesh.locate_entities(msh, tdim, top_right_domain)
bottom_right_cells = mesh.locate_entities(msh, tdim, bottom_right_domain)
left_submesh, left_sub_to_parent, _, _ = dolfinx.mesh.create_submesh(
    msh, msh.topology.dim, left_cells
top_right_submesh, top_right_sub_to_parent, _, _ = dolfinx.mesh.create_submesh(
    msh, msh.topology.dim, top_right_cells
bottom_right_submesh, bottom_right_sub_to_parent, _, _ = dolfinx.mesh.create_submesh(
    msh, msh.topology.dim, bottom_right_cells
# Create three function spaces on each submesh
V_left = fem.functionspace(left_submesh, ("CG", 1))
V_top_right = fem.functionspace(top_right_submesh, ("CG", 1))
V_bottom_right = fem.functionspace(bottom_right_submesh, ("CG", 1))
# create functions and test functions
u_left = fem.Function(V_left)
v_left = ufl.TestFunction(V_left)
u_top_right = fem.Function(V_top_right)
v_top_right = ufl.TestFunction(V_top_right)
u_bottom_right = fem.Function(V_bottom_right)
v_bottom_right = ufl.TestFunction(V_bottom_right)
# create dx measures
cell_map = msh.topology.index_map(msh.topology.dim)
num_cells = cell_map.size_local + cell_map.num_ghosts
marker = np.arange(num_cells, dtype=np.int32)
mt = dolfinx.mesh.meshtags(msh, msh.topology.dim, marker, marker)
dx = ufl.Measure("dx", domain=msh, subdomain_data=mt)
dx_left = ufl.Measure("dx", domain=left_submesh)
dx_top_right = ufl.Measure("dx", domain=top_right_submesh)
dx_bottom_right = ufl.Measure("dx", domain=bottom_right_submesh)
F = 0
F += dot(grad(v_left), grad(u_left)) * dx_left
F += dot(grad(v_top_right), grad(u_top_right)) * dx_top_right
F += dot(grad(v_bottom_right), grad(u_bottom_right)) * dx_bottom_right
# source
f = 1
F += -v_left * f * dx_left
F += -v_top_right * f * dx_top_right
F += -v_bottom_right * f * dx_bottom_right
# boundary conditions
boundary_facets = mesh.exterior_facet_indices(msh.topology)
boundary_dofs = fem.locate_dofs_topological(V, tdim - 1, boundary_facets)
uD = fem.Function(V)
uD.interpolate(lambda x: np.full(x[0].shape, 0.0))
bc = fem.dirichletbc(uD, boundary_dofs)
# TODO add dS coupling terms for interfaces
# make entity maps
parent_to_sub_left = np.full(num_cells, -1, dtype=np.int32)
parent_to_sub_left[left_sub_to_parent] = np.arange(
    len(left_sub_to_parent), dtype=np.int32
entity_map = {left_submesh._cpp_object: parent_to_sub_left}
parent_to_sub_right = np.full(num_cells, -1, dtype=np.int32)
parent_to_sub_right[top_right_sub_to_parent] = np.arange(
    len(top_right_sub_to_parent), dtype=np.int32
entity_map.update({top_right_submesh._cpp_object: parent_to_sub_right})
parent_to_sub_bottom = np.full(num_cells, -1, dtype=np.int32)
parent_to_sub_bottom[bottom_right_sub_to_parent] = np.arange(
    len(bottom_right_sub_to_parent), dtype=np.int32
entity_map.update({bottom_right_submesh._cpp_object: parent_to_sub_bottom})
# NonLinearProblem
formulation = dolfinx.fem.form(F == 0, entity_maps=entity_map)
u = fem.Function(V)
problem = fem.petsc.NonlinearProblem(
    formulation,
    u,
    bcs=bc,
solver.solve(u)
At the moment the code doesn’t run and produces the following error:
  File "/home/remidm/FESTIM/interface_submeshes.py", line 118, in <module>
  File "/home/remidm/miniconda3/envs/dolfinx_0.8/lib/python3.12/site-packages/dolfinx/fem/petsc.py", line 905, in __init__
    J = ufl.derivative(F, u, du)
  File "/home/remidm/miniconda3/envs/dolfinx_0.8/lib/python3.12/site-packages/ufl/formoperators.py", line 404, in derivative
    raise ValueError(f"Invalid argument type {type(form)}.")
ValueError: Invalid argument type <class 'ufl.equation.Equation'>.
I couldn’t find a demo for this application case so I was wondering if the approach was at least the right one?
Thanks for any pointers!
Cheers
Rem
Using non-linear problem for mixed dimensional methods is not stream-lined. Here is a NewtonSolver that I made recently for mixed dim problems:
# Newton solver for mixed dim problems
# Author: Jørgen S. Dokken
# SPDX License identifier: MIT
class NewtonSolver():
    max_iterations: int
    bcs: list[dolfinx.fem.DirichletBC]
    A: PETSc.Mat
    b: PETSc.Vec
    J: dolfinx.fem.Form
    b: dolfinx.fem.Form
    dx: PETSc.Vec
    def __init__(self, F:list[dolfinx.fem.form], J:list[list[dolfinx.fem.form]], w: list[dolfinx.fem.Function],
                 bcs: list[dolfinx.fem.DirichletBC]|None=None, max_iterations:int=5,
                 petsc_options: dict[str, str|float|int|None]=None,
                 problem_prefix = "newton"):
        self.max_iterations = max_iterations
        self.bcs = [] if bcs is None else bcs
        self.b = dolfinx.fem.petsc.create_vector_block(F)
        self.F = F
        self.J = J
        self.A = dolfinx.fem.petsc.create_matrix_block(J)
        self.dx = self.A.createVecLeft()
        self.w = w
        self.x = dolfinx.fem.petsc.create_vector_block(F)
        # Set PETSc options
        opts = PETSc.Options()
        opts.prefixPush(problem_prefix)
        if petsc_options is not None:
            for k, v in petsc_options.items():
                opts[k] = v
        opts.prefixPop()
        # Define KSP solver
        self._solver = PETSc.KSP().create(self.b.getComm().tompi4py())
        self._solver.setOperators(self.A)
        self._solver.setFromOptions()
        # Set matrix and vector PETSc options
        self.A.setOptionsPrefix(problem_prefix)
        self.A.setFromOptions()
        self.b.setOptionsPrefix(problem_prefix)
        self.b.setFromOptions()
    def solve(self, tol=1e-6, beta=1.0):
        i = 0
        while i < self.max_iterations:
            dolfinx.cpp.la.petsc.scatter_local_vectors(
                self.x,
                [si.x.petsc_vec.array_r for si in self.w],
                    (si.function_space.dofmap.index_map, si.function_space.dofmap.index_map_bs)
                    for si in self.w
            self.x.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
            # Assemble F(u_{i-1}) - J(u_D - u_{i-1}) and set du|_bc= u_D - u_{i-1}
            self.b.zeroEntries()
            dolfinx.fem.petsc.assemble_vector_block(self.b, self.F,self.J, bcs=self.bcs,x0=self.x, scale=-1.0)
            self.b.ghostUpdate(PETSc.InsertMode.INSERT_VALUES, PETSc.ScatterMode.FORWARD)
            # Assemble Jacobian
            self.A.zeroEntries()
            dolfinx.fem.petsc.assemble_matrix_block(self.A, self.J, bcs=self.bcs)
            self.A.assemble()
            self._solver.solve(self.b, self.dx)
            assert self._solver.getConvergedReason() > 0, "Linear solver did not converge"
            offset_start = 0
            for s in self.w:
                num_sub_dofs = s.function_space.dofmap.index_map.size_local * s.function_space.dofmap.index_map_bs
                s.x.array[:num_sub_dofs] -= beta*self.dx.array_r[offset_start:offset_start+num_sub_dofs]
                s.x.scatter_forward()
                offset_start += num_sub_dofs
            # Compute norm of update
            correction_norm = self.dx.norm(0)
            print(f"Iteration {i}: Correction norm {correction_norm}")
            if correction_norm < tol:
                break
            i += 1
Thanks for this!
I’ve modified the code to the following:
u = fem.Function(V)
    F=formulation, w=[u_left, u_top_right, u_bottom_right], bcs=bc, J=[]  # not sure how to compute J here
solver.solve(u)
But now have this error:
  File "/home/remidm/FESTIM/interface_submeshes.py", line 125, in <module>
  File "/home/remidm/FESTIM/newton_solver_mixed_dim.py", line 29, in __init__
  File "/home/remidm/miniconda3/envs/dolfinx_0.8/lib/python3.12/site-packages/dolfinx/fem/petsc.py", line 124, in create_vector_block
    maps = [
TypeError: 'Equation' object is not iterable
I thought maybe the F==0 in form was causing the issue but when only setting dolfinx.fem.form(F, entity_maps=entity_map) I get:
  File "/home/remidm/FESTIM/interface_submeshes.py", line 117, in <module>
    formulation = dolfinx.fem.form(F, entity_maps=entity_map)
  File "/home/remidm/miniconda3/envs/dolfinx_0.8/lib/python3.12/site-packages/dolfinx/fem/forms.py", line 249, in form
    return _create_form(form)
  File "/home/remidm/miniconda3/envs/dolfinx_0.8/lib/python3.12/site-packages/dolfinx/fem/forms.py", line 244, in _create_form
    return _form(form)
  File "/home/remidm/miniconda3/envs/dolfinx_0.8/lib/python3.12/site-packages/dolfinx/fem/forms.py", line 178, in _form
    (domain,) = list(sd.keys())  # Assuming single domain
ValueError: too many values to unpack (expected 1)
You would not make an equation in that sense, you would do something like:
F0 = F00 + F01
F1 = F10 + F11
residual_0 = dolfinx.fem.form(F0, entity_maps=entity_maps)
residual_1 = dolfinx.fem.form(F1, entity_maps=entity_maps)
jac00 = ufl.derivative(F0, u)
jac01 = ufl.derivative(F0, psi)
jac10 = ufl.derivative(F1, u)
jac11 = ufl.derivative(F1, psi)
J00 = dolfinx.fem.form(jac00, entity_maps=entity_maps)
J01 = dolfinx.fem.form(jac01, entity_maps=entity_maps)
J10 = dolfinx.fem.form(jac10, entity_maps=entity_maps)
J11 = dolfinx.fem.form(jac11, entity_maps=entity_maps)
J = [[J00, J01], [J10, J11]]
F = [residual_0, residual_1]
For a two-domain problem
It’s unclear to me what F00 is with respect to F01
Moreover, is psi the test function?
is u a function defined over the whole domain not only a submesh?
Hi Remi,
Sorry for the lack of clarity (my example is a bit experimental, using an exotic variational formulation Im not ready to share yet).
However, I can give you the context:
In my example u is a function on the whole mesh, while psi is a function on the subset of the boundary (using Joe’s meshview branches).
So u and psi are the two unknowns
After a bit of trial and error this is where I am.
I’ve simplified the problem to only a two domain problem (left and right).
  • I created a new Function psi since the test function wasn’t accepted. But maybe I did this wrong…
  • It’s unclear to me if I need to create functions on the submeshes and test functions on the whole mesh, or the opposite.
This is my code (apologies for the length…):
from newton_solver_mixed_dim import NewtonSolver
tol = 1e-16
def left_domain(x):
def right_domain(x):
    return x[0] > 0.5 - tol
def interface(x):
    return np.isclose(x[0], 0.5)
fdim = tdim - 1
right_cells = mesh.locate_entities(msh, tdim, right_domain)
interface_facets = mesh.locate_entities(msh, fdim, interface)
num_facets = facet_map.size_local + facet_map.num_ghosts
indices = np.arange(0, num_facets)
values = np.zeros(indices.shape, dtype=np.intc)  # all facets are tagged with zero
interface_id = 2
values[boundary_facets] = 1
values[interface_facets] = interface_id
mesh_tags_facets = mesh.meshtags(msh, fdim, indices, values)
right_submesh, right_sub_to_parent, _, _ = dolfinx.mesh.create_submesh(
    msh, msh.topology.dim, right_cells
V_right = fem.functionspace(right_submesh, ("CG", 1))
u_right = fem.Function(V_right)
v_right = ufl.TestFunction(V_right)
u = fem.Function(V)
# create measures
indices = np.arange(0, num_cells)
values_cells = np.zeros(indices.shape, dtype=np.intc)
index_left = 1
index_right = 2
values_cells[left_cells] = index_left
values_cells[right_cells] = index_right
mesh_tags_cells = mesh.meshtags(msh, tdim, indices, values_cells)
mt = dolfinx.mesh.meshtags(msh, msh.topology.dim, indices, values_cells)
dx_right = ufl.Measure("dx", domain=right_submesh)
dS = ufl.Measure("dS", domain=msh, subdomain_data=mesh_tags_facets)
F0 = dot(grad(v), grad(u_left)) * dx(index_left)
F1 = dot(grad(v), grad(u_right)) * dx(index_right)
# source
f = 1
F0 += -v * f * dx(index_left)
F1 += -v * f * dx(index_right)
h = ufl.CellDiameter(msh)
n = ufl.FacetNormal(msh)
alpha = 1000
F0 += (
    -dot(avg(grad(v)), jump(u, n)) * dS(interface_id)
    - dot(jump(v, n), avg(grad(u))) * dS(interface_id)
    + alpha / avg(h) * dot(jump(v, n), jump(u, n)) * dS(interface_id)
# make entity maps
parent_to_sub_right[right_sub_to_parent] = np.arange(
    len(right_sub_to_parent), dtype=np.int32
entity_maps = {
    left_submesh._cpp_object: parent_to_sub_left,
    right_submesh._cpp_object: parent_to_sub_right,
# NonLinearProblem
psi = dolfinx.fem.Function(V)
solver = NewtonSolver(F=[residual_0, residual_1], w=[u_left, u_right], bcs=[bc], J=J)
solver.solve()
Giving:
  File "/home/remidm/FESTIM/interface_submeshes.py", line 148, in <module>
    solver.solve()
  File "/home/remidm/FESTIM/newton_solver_mixed_dim.py", line 88, in solve
  File "petsc4py/PETSc/KSP.pyx", line 1774, in petsc4py.PETSc.KSP.solve
petsc4py.PETSc.Error: error code 73
[0] KSPSolve() at /home/conda/feedstock_root/build_artifacts/petsc_1717048443064/work/src/ksp/ksp/interface/itfunc.c:1078
[0] KSPSolve_Private() at /home/conda/feedstock_root/build_artifacts/petsc_1717048443064/work/src/ksp/ksp/interface/itfunc.c:831
[0] KSPSetUp() at /home/conda/feedstock_root/build_artifacts/petsc_1717048443064/work/src/ksp/ksp/interface/itfunc.c:415
[0] PCSetUp() at /home/conda/feedstock_root/build_artifacts/petsc_1717048443064/work/src/ksp/pc/interface/precon.c:1079
[0] PCSetUp_ILU() at /home/conda/feedstock_root/build_artifacts/petsc_1717048443064/work/src/ksp/pc/impls/factor/ilu/ilu.c:135
[0] MatILUFactorSymbolic() at /home/conda/feedstock_root/build_artifacts/petsc_1717048443064/work/src/mat/interface/matrix.c:7036
[0] MatILUFactorSymbolic_SeqAIJ() at /home/conda/feedstock_root/build_artifacts/petsc_1717048443064/work/src/mat/impls/aij/seq/aijfact.c:1745
[0] Object is in wrong state
[0] Matrix is missing diagonal entry 0
So obviously something is wrong :frowning:
Should be pretty much straightforward to with multiphenicsx, considering that the third tutorial (interface case) basically has the same structure.
However, the downside is that you would be installing an additional library, rather than using Joe’s functionalities which are built-in in dolfinx.
Hey, have you found a solution to this “missing diagonal entry”?
I don’t remember anything about this exact problem but with successfully implemented interface discontinuities using the mixed domain approach and entity maps. Ping @dokken
There are several variations of the Poisson problem with coupling.
One of them is within FESTIM itself (GitHub - RemDelaporteMathurin/FESTIM: My personal fork of FESTIM) and might be hard to parse.
We have several other versions floating around on discourse, including:
Discontinuity at interface using mixed domains - #2 by dokken
and the subsequent typo fix by @RemDelaporteMathurin
as well as:
Poisson submesh DG coupling · GitHub
(which is also cross posted multiple times on discourse: Search results for 'https://gist.github.com/jorgensd/8a5c32f491195e838f5863ca88b27bce' - FEniCS Project)
Hello dokken, your comment worries me a little, as I use the standard Newton solver without any visible issue solving a mixed elements problem.
Do you mean that the solution I get might not be the correct one? Or do you mean that it is hard to reach convergence or something else?
MixedElement is not the same as MixedFunctionSpace.
You shouldn’t be worried if the code runs and gives a solution for all variables.
