I’ve been working on some code to use the (python) PETScSNESSolver together with the mixed dimensional (MeshView) fenics code. I finally got everything to work, but the last thing I am struggling with is that it hangs in parallel. After some tinkering I boiled it down to the function assemble_mixed() and a particular .h5 mesh I am using. This is all using the latest fenicsproject/dev docker container.
My hunch is that there is something about this mesh that is preventing assembly, because I can write out a mesh such as d.UnitCubeMesh(N,N,N) then read it back in as a .h5 in parallel and assemble_mixed() works fine.
I realize that the MWE only makes sense with the file in question so here is a link. The mesh adjacent_cubes.h5 is the mesh that doesn’t work. I also included unit_cube_16.h5 which is simply just d.UnitCubeMesh(16,16,16) exported out into a .h5 file to make sure that it works.
Here is the MWE:
import dolfin as d
rank = d.MPI.comm_world.rank
# Read in mesh
mesh_path = 'adjacent_cubes.h5'
mesh = d.Mesh()
hdf5 = d.HDF5File(mesh.mpi_comm(), mesh_path, 'r')
hdf5.read(mesh, '/mesh', False)
# mesh = d.UnitCubeMesh(26, 26, 26) # something like this will work in both cases (even if it is saved/loaded from a .h5 file)
print(f"cpu {rank}: has {mesh.num_vertices()} vertices")
# define mesh functions
mf3 = d.MeshFunction("size_t", mesh, 3, 0)
mf2 = d.MeshFunction("size_t", mesh, 2, 0)
for c in d.cells(mesh):
mf3[c] = 1+( c.midpoint().z() < 0.5 )*1
for f in d.facets(mesh):
mf2[f] = 11*(0.5-d.DOLFIN_EPS <= f.midpoint().z() <= 0.5+d.DOLFIN_EPS)
# Mixed problem
def mixed_problem():
# submeshes
mesh0 = d.MeshView.create(mf3, 1); mesh1 = d.MeshView.create(mf3, 2); mesh_ = d.MeshView.create(mf2, 11)
# build mesh mappings
mesh_.build_mapping(mesh0); mesh_.build_mapping(mesh1)
# function spaces
V0 = d.FunctionSpace(mesh0, "CG", 1); V1 = d.FunctionSpace(mesh1, "CG", 1)
# Mixed function space
W = d.MixedFunctionSpace(V0, V1)
# functions
u = d.Function(W)
un = d.Function(W)
u0 = u.sub(0); u1 = u.sub(1)
u0n = un.sub(0); u1n = un.sub(1)
# test functions
v = d.TestFunctions(W)
v0 = v[0]; v1 = v[1]
# measures
dx0 = d.Measure('dx', domain=mesh0); dx1 = d.Measure('dx', domain=mesh1); dx_ = d.Measure('dx', domain=mesh_)
# initial condition
expression0 = d.Expression('x[0]+4', degree=1); expression1 = d.Constant(0.5)
u0.assign(expression0); u1.assign(expression1)
un.sub(0).assign(expression0); un.sub(1).assign(expression1)
# define problem
F0 = u0*v0*dx0 + d.inner(d.grad(u0), d.grad(v0))*dx0 - u0n*v0*dx0 - (d.Constant(0.01)*(u1-u0)*v0*dx_)
F1 = u1*v1*dx1 + d.inner(d.grad(u1), d.grad(v1))*dx1 - u1n*v1*dx1 - (d.Constant(0.01)*(u0-u1)*v1*dx_)
return u, [F0,F1]
# Try to assemble a sub-form of the mixed problem
u, F = mixed_problem()
# assemble_mixed() requires us to separate forms by domain
from ufl.form import sub_forms_by_domain
F00,F01 = sub_forms_by_domain(F[0])
Fvec0 = d.assemble_mixed(F00) # works in serial, MPI hangs in parallel
print(f"success! the sum of our assembled vector is {sum(Fvec0)}")
# example of a problem using no mixed assembly that works
def sub_problem():
V = d.FunctionSpace(mesh, "CG", 1)
u = d.Function(V)
v = d.TestFunction(V)
dx = d.Measure('dx', domain=mesh)
expression = d.Expression('x[0]+4', degree=1)
u.assign(expression)
un = u.copy(deepcopy=True)
F = u*v*dx + d.inner(d.grad(u), d.grad(v))*dx - un*v*dx
return u, F
# Assembling the form in a regular problem
u, F = sub_problem()
d.assemble(F)
Fvec = d.assemble_mixed(F) # works in serial and in parallel
print(f"success! the sum of our assembled vector is {sum(Fvec)}")
Perhaps it could have something to do with inconsistent normals or vertex ordering? I’m not sure how to proceed as MPI just hangs and when exiting the error is very generic. If anyone has advice on this specifically or even just advice on how to debug problems of this type I’d really appreciate it. Thank you!
