Dear all,
I am trying to solve the following optimal control problem using Lagrange function
\min\limits_{m} \frac{1}{2}{ \parallel u-u_{d} \parallel}^{2}_{L^{2}(\Omega)} + \frac{\alpha}{2}{ \parallel m\parallel}^{2}_{L^{2}(\Gamma)}
subject to
- \Delta u + u^{3} - u = 0 in \Omega
\frac{ \partial u}{\partial \nu} = m on \Gamma
here the control variable m is defined only on the boundary, and therefore I am using a mixed dimensional branch.
However, when running it via terminal I encounter the following error
[problem.py] size F = 3
[problem] create list of residual forms OK
[problem.py] size J = 9
[problem] create list of jacobian forms OK, J_list size = 9
[MixedNonlinearVariationalProblem]::check_forms - To be implemented
Build mapping between 0 and 7
Segmentation fault (core dumped)
It seems to me that there is something wrong with the part where I take derivatives.
I tried to use extract_blocks as suggested by @cdaversin here. However, I think, in my case, I don’t have enough Arguments before differentiation (in the weak formulation all functions are basically trial functions and test functions appear only later as a direction in which I take derivatives)
I would appreciate any suggestions on how to resolve the issue.
Here is a MWE
mesh = RectangleMesh(Point(0.0, 0.0), Point(1.0, 2.0), 10, 10)
class Boundary(SubDomain):
return on_boundary
mf = MeshFunction("size_t", mesh, mesh.geometry().dim()-1, 0)
Boundary().mark(mf,1)
boundary_mesh = MeshView.create(mf, 1)
U = FunctionSpace(mesh, "CG", 1) # forward solution
V = FunctionSpace(mesh, "CG", 1) # adjoint solution
M = FunctionSpace(boundary_mesh, "CG", 1) # control
Z = MixedFunctionSpace(U, V, M)
dx = Measure("dx", domain=Z.sub_space(0).mesh())
dBoundary = Measure("dx", domain=Z.sub_space(2).mesh())
z = Function(Z)
u, uT, m = z.sub(0),z.sub(1),z.sub(2)
F = inner(grad(u), grad(uT))*dx - m*uT*dBoundary + inner(u**3, uT)*dx - inner(u, uT)*dx
ud = Constant(3)
J = 0.5*inner(u-ud, u-ud)*dx + 0.5*Constant(1e-7)*inner(m, m)*dBoundary
bcs = []
# Derive optimality conditions
L = J + F
kkt = []
for zi in z.split():
d = derivative(L, zi)
kkt.append(d)
Hes = []
for Js_i in kkt:
d = derivative(Js_i, zi)
Hes.append(d)
problem = MixedNonlinearVariationalProblem(kkt, z._functions, bcs, Hes)
solver = MixedNonlinearVariationalSolver(problem)
solver.solve()
