Dear all,
recently I found a very attrative feature in the mixed-dimensional branch, which enable the MixedFunctionSpace defined with various submeshes, see Replacement of MixedFunctionSpace. It seems that this new feature aims at solving problem with different topology dimensions. While my interset is another way of “mixed-dimension”, which is the the multi-dimension grid size meshes on the same domain, namely, geometric multigrid.
In order to do so, it is required first to create a SubMesh() on the same domain but with different resolution. I searched for a while but found that the SubMesh() in the current version is based on cell (or edge for BoundaryMesh). I’m looking for a way to walk around and create a SubMesh() based on some kind of macro cell (groupd few cells to make the resolution coarser) or the parent of the refined mesh (with built-in refine() function) or geometric multigrid. Please help me if you have any idea of possible ways.
Thank you!
P.S. I found there is a built-in cpp MeshHierarchy() function in the source code, in firedrake it is avaible but the python interface in FEniCS seems not provided yet. I was thinking if this interface can be added and then if the SubMesh() could build upon this MeshHierarchy()? This might be interesting in general.
