I am trying to initialize a function in a mixed space. The mixed space is defined over a submesh and the code runs in parallel. I have created the minimal code here but since I needed to use MeshView I couldn’t use Fenics in-built meshes. So I added a link to my github with the mesh file I have used here.
mesh = Mesh()
hdf5 = HDF5File(mesh.mpi_comm(), "Mesh.h5", "r")
hdf5.read(mesh, "/mesh", False)
Volume = MeshFunction("size_t",mesh,2)
hdf5.read(Volume, "/Volume")
bnd_mesh = MeshFunction("size_t",mesh,1)
hdf5.read(bnd_mesh, "/bnd_mesh")
Sub_Mesh0 = MeshView.create(Volume, 3)
surface_marker0 = MeshFunction("size_t", Sub_Mesh0, Sub_Mesh0.topology().dim() - 1, 0)
volume_marker0 = MeshFunction("size_t", Sub_Mesh0, Sub_Mesh0.topology().dim())
P1 = FiniteElement('P', triangle,1)
element = MixedElement([P1,P1,P1])
Mixed_Space = FunctionSpace(Sub_Mesh0, element)
U = Function(Mixed_Space)
u1,u2,u3 = split(U)
ox_0 = Expression('x[0]', degree=0)
Tn_0 = Expression('x[1]', degree=0)
Th_0 = Expression('x[0]*x[1]', degree=0)
ox0 = interpolate(ox_0, Mixed_Space.sub(0).collapse())
Tn0 = interpolate(Tn_0, Mixed_Space.sub(1).collapse())
Th0 = interpolate(Th_0, Mixed_Space.sub(2).collapse())
assign(U.sub(0),ox0)
assign(U.sub(1),Tn0)
assign(U.sub(2),Th0)
and the error is
File "/home/nm24a/Test/untitled2.py", line 24, in <module>
File "/usr/local/lib/python3.5/dist-packages/dolfin/function/functionspace.py", line 124, in sub
return FunctionSpace(cpp.function.FunctionSpace.sub(self._cpp_object, i))
RuntimeError:
*** Error: Unable to build sub-dofmap view.
*** Reason: Re-ordering map not available. It may be been cleared by the user.
*** Where: This error was encountered inside DofMapBuilder.cpp.
*** Process: 1
*** Git changeset: 946dbd3e268dc20c64778eb5b734941ca5c343e5
You can find the mesh file here.
Any help would be much appreciated.
Best,
More observations: I realize the problem is with Mixed_Space.sub(0), more specifically the .sub(0) part. Also if I want to do something like this:
u1_, u2_, u3_ = U.split()
I get the same error. Is this a bug?
