Greetings, I am trying to run a nonlinear fracture simulation using the mixed element method in fenics and no matter how many corrects I implemented using the advice from this forum, I keep getting the following error:
*** Error: Unable to successfully call PETSc function 'MatSetValuesLocal'.
*** Reason: PETSc error code is: 63 (Argument out of range).
*** Where: This error was encountered inside /home/conda/feedstock_root/build_artifacts/fenics-pkgs_1617882212586/work/dolfin/dolfin/la/PETScMatrix.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 7f46aeb0b296da5bbb1fb0845822a72ab9b09c55
Would really appreciate it if someone knew what the problem is. I attached the code below thank you!
# Janel Chua
# Able to handle supersonic (with respect to pressure wave speed)
# in bridges: cd /ocean/projects/dmr120014p/songlinc/
# Preliminaries and mesh
# mesh_half = Mesh('Trial14_coarseEdges8.xml')
# mesh_half = Mesh('Trial31.xml')
mesh_half = Mesh('Trial17.xml')
"eliminate_zeros": True, \
"precompute_ip_const": True}
# Manually introduce the material parameters
class GC(UserExpression):
def set_Gc_values(self, Gc_0, Gc_1):
self.Gc_0, self.Gc_1 = Gc_0, Gc_1
def eval(self, value, x):
"Set value[0] to value at point x"
tol = 1E-14
if x[1] >= 0.015 + tol:
value[0] = self.Gc_0
elif x[1] <= -0.015 + tol:
value[0] = self.Gc_1 #middle layer
# Initialize Gc
Gc = GC()
Gc.set_Gc_values(32, 0.1) #N/mm
# STEEL
l = 0.015#*10**(-3) #mm
E = 206*1000 #MPa = MKg.m^-1.s^-2 #we are using N/mm^2
nu = 0.3 #Poisson's ratio
mu = Constant(E / (2.0*(1.0 + nu))) #80.7692e3# MPa #we are using N/mm^2
lmbda = Constant(E*nu / ((1.0 + nu)*(1.0 - 2.0*nu))) #121.1538e3# MPa #we are using N/mm^2
mu2 = 1e-10 #this mu is used for the evolution equation
# Mass density
rho = Constant(7.8*10**(-9)) # Mkg.m^-3 #we are using (N.s^2)/mm^4
# Generalized-alpha method parameters
alpha_m = Constant(0.2)
alpha_f = Constant(0.4)
gamma = Constant(0.5+alpha_f-alpha_m)
beta = Constant((gamma+0.5)**2/4.)
# Time-stepping parameters
T = 20
Nsteps = 100
dt = Constant(T/Nsteps)
tract = Constant((0, 5)) # Vertical traction
# Define Function Spaces and mixed elements
FE_A = VectorElement("CG", mesh_half.ufl_cell(), 1)
FE_U = VectorElement("CG", mesh_half.ufl_cell(), 1) # 1 originally # displacement
FE_Phi = FiniteElement("CG", mesh_half.ufl_cell(), 1) # phi
Z = FunctionSpace(mesh_half, MixedElement([FE_A, FE_U, FE_Phi]))
dU = TrialFunction(Z)
(A, U, Phi) = split(dU)
U_ = TestFunction(Z)
(V, W, Q) = split(U_)
old = Function(Z)
(Aold, Uold, Phiold) = split(old)
new = Function(Z)
strain = TensorFunctionSpace(mesh_half, "CG", 1)
strain_total = Function(strain, name='Strain')
sigma_fs = TensorFunctionSpace(mesh_half, "CG", 1)
stress_elas = Function(sigma_fs, name='Stress')
VV = FunctionSpace(mesh_half, 'CG', 1)
normSquared = Function(VV)
# Defining velocity of moving defect
vel = as_vector([3000000,0]) # mm/s
velx = vel[0]
# Rayleigh damping coefficients
eta_k = Function(VV)
class etakValues(UserExpression):
def eval_cell(self, value, x, ufc_cell):
etakValue = Constant(1*10**(-9)) # etak's maximum value
etakY = 0.2 # In this case, y position where you would like the value to be turned on. Applies to Pos and Neg Y
etakPosX = 3
etakNegX = 0 #-2.5 # if you want it to be in the positive region you have to add a -
l2 = 0.1
baseline = Constant(0) # Constant(1*10**(-9)) # this is the value in the middle section
def H(u):
return 0.5*( 1 + ((np.exp(2*((u)/l2)) - 1)/(np.exp(2*((u)/l2))+1)) )
# value[0] = (-etakValue)*H(x[0] + etakNegX)*H(x[1] + etakY)*(1-H(x[0] - etakPosX))*(1-H(x[1] - etakY))\
# + etakValue + baseline # Good
# value[0] = baseline
value[0] = etakValue
eta_k.interpolate(etakValues())
# Phi initialisation
class PhiInitialCondition(UserExpression):
if abs(x[1]) < 1e-02 and x[0] <= 0.1:
value[0] = 1.0
value[0] = 0.0
Phiold = interpolate(PhiInitialCondition(), Z.sub(2).collapse())
# Boundary conditions
def top(x,on_boundary):
return near(x[1],1) and on_boundary #(x[0], 1)
def bot(x,on_boundary):
return near(x[1],-1) and on_boundary #(x[0], -1)
def left(x,on_boundary):
return near(x[0],-0.5) and on_boundary #(-0.5, x[1])
def right(x,on_boundary):
return near(x[0],5) and on_boundary #(5, x[1])
bcright = DirichletBC(Z.sub(1).sub(0), Constant(0), right) #Right displacement loaded: u_1
bcright2 = DirichletBC(Z.sub(1).sub(1), Constant(0), right) #Right displacement loaded: u_2
phiright = DirichletBC(Z.sub(2), Constant(0), right)
# Dirichlet Boundary Condition used:
bc_U = [bcright, bcright2, phiright]
n = FacetNormal(mesh_half)
# Create mesh function over the cell facets
boundary_subdomains = MeshFunction("size_t", mesh_half, mesh_half.topology().dim() - 1)
boundary_subdomains.set_all(0)
AutoSubDomain(top).mark(boundary_subdomains, 1) # top boundary
AutoSubDomain(bot).mark(boundary_subdomains, 2) # bottom boundary
AutoSubDomain(left).mark(boundary_subdomains, 3) # left boundary
AutoSubDomain(leftTopHalf).mark(boundary_subdomains, 31) # leftTop boundary
AutoSubDomain(leftBotHalf).mark(boundary_subdomains, 32) # leftBot boundary
AutoSubDomain(right).mark(boundary_subdomains, 4) # right boundary
# Define measure for boundary condition integral
dss = ds(subdomain_data=boundary_subdomains)
# Constituive functions
def epsilon(U):
return sym(grad(U))
def epsilonDot(a):
return -sym(grad(a))
def sigma(U, a, Phi):
eta_e = 1e-10
elastic = ((1.0 - Phi)**2 + eta_e)*(2.0*mu*epsilon(U)+lmbda*tr(epsilon(U))*Identity(len(U)))
dissipative = ((1.0 - Phi)**2 + eta_e)*(eta_k*( 2.0*mu*epsilonDot(a)+lmbda*tr(epsilonDot(a))*Identity(len(U)) ))
return (elastic + dissipative)
def psi_elastic(U):
return 0.5*lmbda*(tr(epsilon(U)))**2 + mu*inner(epsilon(U),epsilon(U)) # isotropic linear elastic
# Mass term weak form
def m(U, a, W, vel):
return rho*inner(a, div(outer(W, vel)) )*dx
# Elastic stiffness weak form
def k(U, a, Phi, W):
return inner(sigma(U, a, Phi), grad(W))*dx
# Boundary Terms
def boundaryLeft(U, W, velx, a, Phi):
stress = sigma(U, a, Phi)
e1 = as_vector([1,0])
e2 = as_vector([0,1])
n = as_vector([-1,0])
return -rho*velx*a[0]*dot(W,e1)*n[0] - rho*velx*a[1]*dot(W,e2)*n[0]
def boundary22(Phi, W, tract): # For traction boundary
eta_e = 1e-10
return ((1.0 - Phi)**2 + eta_e)*dot(W, tract)
# Weak form for a -------------------------------------------------------------#
E_A = ( inner(dot(grad(Uold),vel), V) - inner(Aold, V) )*dx
# Weak form for u -------------------------------------------------------------#
# Nonlinear
E_U = m(Uold, Aold, W, vel) \
- k(Uold, Aold, Phiold, W ) \
+ ( boundaryLeft(Uold, W, velx, Aold, Phiold ) )*dss(3) \
+ ( boundary22(Phiold, W, tract) )*dss(31) \
+ ( boundary22(Phiold, W, -tract) )*dss(32)
# Weak form for Phi... For the fracture case ----------------------------------#
E_Phi = (-mu2*inner(grad(Phiold),vel)*Q + Gc*l*inner(grad(Phiold),grad(Q)) + ((Gc/l)+2.0*psi_elastic(Uold))*inner(Phiold,Q) - 2.0*psi_elastic(Uold)*Q)*dx
form = E_A + E_U + E_Phi
# Nonlinear Solver
J = derivative(form, old, dU)
# Solve problem using Newton's method
problem = NonlinearVariationalProblem(form, old, bc_U, J)
prm = solver.parameters
info(prm, True)
prm["nonlinear_solver"] = "newton"
prm["newton_solver"]["absolute_tolerance"] = 1E-8
prm["newton_solver"]["relative_tolerance"] = 1E-8
prm["newton_solver"]["maximum_iterations"] = 100
# Initialization of the iterative procedure and output requests
time = np.linspace(0, T, Nsteps+1)
tol = 1e10
#Name of file used for storage
store_Phi = File ("mydata/Phi.pvd")
store_u = File ("mydata/u.pvd")
store_a = File ("mydata/a.pvd")
store_stress_elas = File ("mydata/stress_elas.pvd")
# Looping through time here.
for (i, dt) in enumerate(np.diff(time)):
t = time[i+1]
print("Time: ", t)
iter = 0
err = 1e11
while err > tol:
iter += 1
# Solve for new displacement
# Nonlinear Solver
solver.solve()
# Split the solution and plot results
(Anew, Unew, Phinew) = old.split()
# Calculate error
err_a = errornorm(Anew,Aold,norm_type = 'l2',mesh = None)
err_u = errornorm(Unew,Uold,norm_type = 'l2',mesh = None)
err_Phi = errornorm(Phinew,Phiold,norm_type = 'l2',mesh = None)
err = max(err_a, err_u, err_Phi)
print(err_a, err_u, err_Phi)
# Update new fields in same timestep with new calculated quantities
Aold.assign(Anew)
Uold.assign(Unew)
Phiold.assign(Phinew)
print ('Iterations:', iter, ', Total time', t, ', error', err)
if err < tol:
# Update old fields from previous timestep with new quantities
Aold.assign(Anew)
Uold.assign(Unew)
print ('err<tol :D','Iterations:', iter, ', Total time', t, ', error', err)
if round(t*1e1) % 2 == 0: # each saved data point is 2e-9s
store_a << Aold
store_u << Uold #mm
store_Phi << Phiold
stress_elas.assign(project( sigma(Uold, Aold, Phiold) ,sigma_fs, solver_type="cg", preconditioner_type="amg")) # 1MPa = 1N/mm^2
store_stress_elas << stress_elas
File('mydata/saved_mesh.xml') << mesh_half
File('mydata/saved_a.xml') << Aold
File('mydata/saved_u.xml') << Uold
print ('Iterations:', iter, ', Total time', t, 'Saving datapoint')
print ('Simulation completed')
