Hello, everyone!
I have a couple PDE who it’s very similar to the Navier-Stokes equations, and I’ve trying to implement a IPCS scheme to my set of equations, however, there is a step in which I have a fourth order operator, and due to that I introduce an auxiliary variable, just like in the following equations:
And we have the following relationship between R_i and u_i, which reads
Essentially, the right-hand side of the following equation is known, because I start the simulation with a given flow, and Q_{ij}^{\star} is a quantity calculated before.
I have been trying to implement something like in the Mixed Poisson Demo, for the previous set of equations, considering the contribution from Q^{\star} = 0 , just for simplicity, but I get the following error ValueError: not enough values to unpack (expected 1, got 0)
Here’s my code:
## Define parameters for time stepping and constants
dt = 0.1
num_steps = 1
T = dt *num_steps ## final time
lamb = 0.1 ## lambda parameter
Pe = 10.0 ## Peclet number
## Create the mesh
x_channel = 0.5
y_channel = 0.2
nx = ny = 20
mesh = RectangleMesh(Point(0, 0), Point(x_channel, y_channel), 2*nx, ny, 'crossed')
## Define vector elements and function spaces
UE = VectorElement("Lagrange", mesh.ufl_cell(), 2)
# Define function spaces
ME = MixedElement([UE, UE])
U = FunctionSpace(mesh, ME)
Rspace = U.sub(0)
Uspace = U.sub(1)
## Define boundaries
inflow = 'near(x[0], 0)'
outflow = 'near(x[0], 0.5)'
walls = 'near(x[1], 0) || near(x[1], 0.2)'
## Define inflow profile for the velocity
inflow_profile = ('4.0*1.5*x[1]*(0.1 - x[1]) / pow(0.1, 2)',
'0')
## Define boundary conditions for the velocity
## For mixed systems, we should specify which subsystem we set
## the boundary condition. This is done via the sub(0) and sub(1)
bcu_inflow = DirichletBC(Uspace,
Expression(inflow_profile,
degree=2),
inflow)
bcu_walls = DirichletBC(Uspace,
Constant((0, 0)),
walls)
bcu = [bcu_inflow, bcu_walls] ## Colect all boundary conditions for the velocity
## Define trial and test functions
(R, u) = TrialFunctions(U)
(tau, v) = TestFunctions(U)
## Define expressions used in variational forms
k1 = Constant(dt)
k2 = Constant(Pe)
F = (1 / k2) * inner(nabla_grad(R), nabla_grad(tau))*dx \
+ (2*lamb / 3. - (1 / k1)) * inner(R, tau)*dx \
+ (2 / 3) * inner(nabla_grad(u), nabla_grad(v))*dx - inner(R, v)*dx
a2 = lhs(F)
L2 = rhs(F)
# Assemble matrices
A2 = assemble(a2)
# Apply boundary conditions to matrices
[bc.apply(A2) for bc in bcu]
# Time-stepping
w = Function(U)
t = 0
for n in range(num_steps):
# Update current time
b2 = assemble(L2)
solve(A2, w, b2)
(R, u) = w.split()
Hope you could help me.
Thanks
