In order to improve the robustness of my code (FEniCS 2019.2.0.dev0), I try to come up with a MMS for a 2d-Poisson equation with pure Robin boundary conditions.
-\Delta = f
-\frac{\partial u}{\partial n}=r_i(u-s_i) at the boundary
The MMS is based on the tutorial ft_01_poisson.py.
I derived the weak form to
\Rightarrow F = \int_{\Omega} \kappa \nabla u \cdot \nabla v dx - \int_{\partial \Omega} \kappa \frac{\partial u}{\partial n} v ds - \int_{\Omega} f v dx \\ \Leftrightarrow F = \int_{\Omega} \kappa \nabla u \cdot \nabla v dx - \int_{\Gamma_l} \kappa \frac{\partial u}{\partial n} ds - \int_{\Gamma_r} \kappa \frac{\partial u}{\partial n} ds - \int_{\Gamma_b} \kappa \frac{\partial u}{\partial n} ds - \int_{\Gamma_t} \kappa \frac{\partial u}{\partial n} ds - \int_{\Omega} f v dx \\ \Leftrightarrow F = \int_{\Omega} \kappa \nabla u \cdot \nabla v dx + \int_{\Gamma_l} r_l \left ( u - s_l \right ) ds + \int_{\Gamma_r} r_r \left ( u - s_r \right ) ds + \int_{\Gamma_b }r_b \left ( u - s_b \right ) ds + \int_{\Gamma_t} r_t \left ( u - s_t \right ) ds - \int_{\Omega} f v dx
For the exact solution u_e = 1 + x² + 2y² I derived to following boundary parameters
- left boundary: x=0
-\frac{\partial u}{\partial n} = - \frac{\partial \left ( 1 + x^2 + 2y^2 \right )}{\partial x} = -2x = 0 \\ \Rightarrow \quad r_l = \mathrm{arbitrary} , \quad s_l = u_e
- right boundary: x=1
- \frac{\partial u}{\partial n} = - \frac{\partial \left ( 1 + x^2 + 2y^2 \right )}{\partial x} = -2x = -2 \\ \Rightarrow \quad r_r = -2 , \quad s_r = x^2 + 2y^2
- bottom boundary: y=0
- \frac{\partial u}{\partial n} = - \frac{\partial \left ( 1 + x^2 + 2y^2 \right )}{\partial y} = -4y = 0 \\ \Rightarrow \quad r_b = \mathrm{arbitrary} , \quad s_b = u_e
- upper boundary: y=1
- \frac{\partial u}{\partial n} = - \frac{\partial \left ( 1 + x^2 + 2y^2 \right )}{\partial y} = -4y = -4 \\ \Rightarrow \quad r_u = -4 , \quad s_u = x^2 + 2y^2
Unfortunately, the L2-norm, which is calculated by errornorm(u_e,u, 'L2') does not yield to zero.
What are your suggestions?
Here is the aquivalent code:
def define_boundaries(mesh, space_dim):
class Boundary_left(SubDomain):
return near(x[0], 0.0)
class Boundary_right(SubDomain):
return near(x[0], 1.0)
class Boundary_bottom(SubDomain):
return near(x[1], 0.0)
class Boundary_top(SubDomain):
return near(x[1], 1.0)
# Initialize sub-domain instances
boundary_left = Boundary_left()
boundary_right = Boundary_right()
boundary_bottom = Boundary_bottom()
boundary_top = Boundary_top()
boundaries = MeshFunction("size_t", mesh, space_dim - 1)
boundaries.set_all(0)
boundary_left.mark(boundaries, 1)
boundary_right.mark(boundaries, 2)
boundary_bottom.mark(boundaries, 3)
boundary_top.mark(boundaries, 4)
# Define new measures associated with the exterior boundaries
return ds
mesh = UnitSquareMesh(8, 8)
V = FunctionSpace(mesh, 'CG', 2)
space_dim = mesh.geometry().dim()
ds = define_boundaries(mesh, space_dim)
# Define boundary condition
u_e = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree=2)
f = Constant(-6.0)
r_l = 1000.0
s_l = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree=2)
r_r = -2.0
s_r = Expression('x[0]*x[0] + 2*x[1]*x[1]', degree=2)
r_b = 1000.0
s_b = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree=2)
r_t = -4.0
s_t = Expression('x[0]*x[0] + 2*x[1]*x[1]', degree=2)
F = dot(grad(u), grad(v))*dx \
+ r_l*(u-s_l)*ds(1) + r_r*(u-s_r)*ds(2) + r_b*(u-s_b)*ds(3) + r_b*(u-s_b)*ds(4) \
- f*v*dx
a, L = lhs(F), rhs(F)
# Compute solution
solve(a == L, u)
# Compute error in L2 norm
error_L2 = errornorm(u_e, u, 'L2')
# Compute maximum error at vertices
vertex_values_u_D = u_e.compute_vertex_values(mesh)
error_max = np.max(np.abs(vertex_values_u_D - vertex_values_u))
# Print errors
print('error_L2 =', error_L2)
print('error_max =', error_max)
