Hi guys,
I am trying to perform a modal analysis of a cuboid barge (with stiffeners) made of shell elements. Here is the code
from vedo.dolfin import plot
mesh = Mesh("../barge.xml")
plot(mesh)
E, nu = Constant(1e5), Constant(0.)
rho = Constant(1e-3)
# Lame coefficient for constitutive relation
mu = E/2./(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
def eps(v):
return sym(grad(v))
def sigma(v):
dim = v.geometric_dimension()
return 2.0*mu*eps(v) + lmbda*tr(eps(v))*Identity(dim)
V = VectorFunctionSpace(mesh, 'Lagrange', degree=1)
u_ = TrialFunction(V)
du = TestFunction(V)
def left(x, on_boundary):
return near(x[0],0.)
bc = DirichletBC(V, Constant((0.,0.,0.)), left)
k_form = inner(sigma(du),eps(u_))*dx
l_form = Constant(1.)*u_[0]*dx
K = PETScMatrix()
b = PETScVector()
assemble_system(k_form, l_form, bc, A_tensor=K, b_tensor=b)
m_form = rho*dot(du,u_)*dx
M = PETScMatrix()
assemble(m_form, tensor=M)
bc.zero(M)
eigensolver = SLEPcEigenSolver(K, M)
eigensolver.parameters['problem_type'] = 'gen_hermitian'
eigensolver.parameters['spectral_transform'] = 'shift-and-invert'
eigensolver.parameters['spectral_shift'] = 0.
eigensolver.parameters["spectrum"] = "largest magnitude"
eigensolver.parameters['solver'] = "power"
print(eigensolver.parameters.str(True))
N_eig = 6 # number of eigenvalues
print("Computing {} first eigenvalues...".format(N_eig))
eigensolver.solve(N_eig)
# Exact solution computation
from scipy.optimize import root
from math import cos, cosh
falpha = lambda x: cos(x)*cosh(x)+1
alpha = lambda n: root(falpha, (2*n+1)*pi/2.)['x'][0]
# Set up file for exporting results
file_results = XDMFFile("modal_analysis.xdmf")
# Extraction
for i in range(N_eig):
# Extract eigenpair
r, c, rx, cx = eigensolver.get_eigenpair(i)
# 3D eigenfrequency
freq_3D = sqrt(r)/2/pi
print("Solid FE: {0:8.5f} [Hz] ".format(freq_3D))
# Initialize function and assign eigenvector
eigenmode = Function(V,name="Eigenvector "+str(i))
eigenmode.vector()[:] = rx
But I am getting the following error
Computing 6 first eigenvalues...
<ipython-input-9-62814374ba19> in <module>
17 for i in range(N_eig):
18 # Extract eigenpair
---> 19 r, c, rx, cx = eigensolver.get_eigenpair(i)
20
21 # 3D eigenfrequency
RuntimeError:
*** Error: Unable to extract eigenpair from SLEPc eigenvalue solver.
*** Reason: Requested eigenpair (0) has not been computed.
*** Where: This error was encountered inside SLEPcEigenSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: c5b9b269f4a6455a739109e3a66e036b5b8412f5
Can anyone tell how to resolve this issue ?
