Eigen vectors in dolfinx
Hi, I am solving an eigen value analysis/modal analysis problem. I want to compute eigen vectors in dolfin-x. The MWE for the same has been attached. I believe, the vr PETSc vectors contain the eigenvector.
import sys
import slepc4py
from scipy.optimize import root
from slepc4py import SLEPc
from dolfinx.mesh import CellType, locate_entities_boundary, create_box
from dolfinx.fem import (Constant, DirichletBC, Function, VectorFunctionSpace,
                         locate_dofs_topological)
from ufl import (TrialFunction, TestFunction, Identity, inner, dot, nabla_div,
                 nabla_grad, dx)
slepc4py.init(sys.argv)
L, B, H = 5., 0.3, 0.6
mesh = create_box(
    MPI.COMM_WORLD,
    [np.array([0, 0, 0]), np.array([L, H, B])],
    [25, 3, 2],
    cell_type=CellType.tetrahedron)
E, nu = (2E11), (0.3)
rho = (7850)
mu = E/2./(1+nu)
lambda_ = E*nu/(1+nu)/(1-2*nu)
def sigma(u):
    return lambda_ * nabla_div(u) * Identity(u.geometric_dimension()) \
           + 2*mu*epsilon(u)
V = VectorFunctionSpace(mesh, ("CG", 2))
def clamped_boundary(x):
    return np.isclose(x[0], 0)
fdim = mesh.topology.dim - 1
boundary_facets = locate_entities_boundary(mesh, fdim, clamped_boundary)
u_D = Function(V)
with u_D.vector.localForm() as loc:
    loc.set(0)
bc = DirichletBC(u_D, locate_dofs_topological(V, fdim, boundary_facets))
T = Constant(mesh, (PETSc.ScalarType(0), PETSc.ScalarType(0),
                    PETSc.ScalarType(0)))
k_form = inner(sigma(u), epsilon(v))*dx
m_form = rho*dot(u, v)*dx
K = dolfinx.fem.assemble_matrix(k_form, bcs=[bc])
K.assemble()
M = dolfinx.fem.assemble_matrix(m_form, bcs=[bc])
M.assemble()
shift = SLEPc.ST().create(MPI.COMM_WORLD)
shift.setType('sinvert')  # spectral transform
shift.setShift(0.0)  # spectral shift
eigensolver = SLEPc.EPS().create(MPI.COMM_WORLD)
eigensolver.setDimensions(nev=50)
eigensolver.setProblemType(2)
eigensolver.setST(shift)
eigensolver.setType('krylovschur')  # Solver type
eigensolver.setWhichEigenpairs(7)  # Target Real
eigensolver.setConvergenceTest(2)
eigensolver.setOperators(K, M)
eps_type = eigensolver.getType()
print("Solution method: %s" % eps_type)
problem_type = eigensolver.getProblemType()
print("Problem type: %s" % problem_type)
which_eigenpairs = eigensolver.getWhichEigenpairs()
print("Eigenpairs type: %s" % which_eigenpairs)
eigensolver.solve()
evs = eigensolver.getConverged()
vr, vi = K.createVecs()
# Exact solution computation
def falpha(x):
    return np.cos(x) * np.cosh(x) + 1
def alpha(n):
    return root(falpha, (2*n + 1)*np.pi/2)['x'][0]
eig_v=[]
ef = 0
print("Number of converged eigenpairs %d" % evs)
if evs > 0:
    for i in range(evs):
        e_val = eigensolver.getEigenpair(i, vr, vi)
        if (~np.isclose(e_val.real, 1.0)):
            # Calculation of eigenfrequency from real part of eigenvalue
            freq_3D = np.sqrt(e_val.real)/2/np.pi
            # Beam eigenfrequency
            if ef % 2 == 0:
                # exact solution should correspond to weak axis bending
                I_bend = H*B**3/12.
                # exact solution should correspond to strong axis bending
                I_bend = B*H**3/12.
            freq_beam = alpha(ef/2)**2*np.sqrt(E*I_bend/(rho*B*H*L**4))/2/np.pi
            print(
                "Solid FE: {0:8.5f} [Hz] "
                "Beam theory: {1:8.5f} [Hz]".format(freq_3D, freq_beam))
            eig_v.append(vr)
            ef += 1
print(np.array(eig_v).T)
With this code getting this result
array([[ 7.87128161e-05,  7.87128161e-05,  7.87128161e-05, ...,
         7.87128161e-05,  7.87128161e-05,  7.87128161e-05],
       [-4.79422279e-05, -4.79422279e-05, -4.79422279e-05, ...,
        -4.79422279e-05, -4.79422279e-05, -4.79422279e-05],
       [ 2.09577501e-06,  2.09577501e-06,  2.09577501e-06, ...,
         2.09577501e-06,  2.09577501e-06,  2.09577501e-06],
       [-3.39323655e-03, -3.39323655e-03, -3.39323655e-03, ...,
        -3.39323655e-03, -3.39323655e-03, -3.39323655e-03],
       [-1.81604351e-02, -1.81604351e-02, -1.81604351e-02, ...,
        -1.81604351e-02, -1.81604351e-02, -1.81604351e-02],
       [-2.21205070e-03, -2.21205070e-03, -2.21205070e-03, ...,
        -2.21205070e-03, -2.21205070e-03, -2.21205070e-03]])
but the correct values from dolfin code for same problem statement is
Screenshot 2022-01-06 083818
Can you please help me in computing and writing eigen vectors in xdmf format
You have a mistake in the line
eig_v.append(vr)
Try changing it to
eig_v.append(vr.copy())
Note that dolfin and dolfinx handle Dirichlet β€˜rows’ differently. dolfinx will place β€˜1’ on the diagonal for Dirichlet rows. In dolfin the value depends on the number of connected cells.
Thanks a lot sir for the correction. I tried with this. But results are not matching with dolfin. This is the result that I a getting for dolfinx
