I’m looking to do a modal analysis of a simple, flat circuit board with 3 dummy components placed on top. The board will have 4 mounting holes, one at each corner. The density and modulus of the board will be different than for the components.
I haven’t yet installed FENICSx, since I want to know if this is a type of problem that would be fairly easy for me to learn and implement with. I know there’s a modal analysis tutorial, so I will start there if it seems like my ultimate problem can also be tackled.
Can I make a 2D simulation of a plane PCB, designate regions as components w/ different material props, and solve for the mode shapes and frequencies? If yes, can anyone point me toward a similar example or worked analysis that I could study?
Thanks,
Adam
