Hello everyone, I am solving for the unconstrained thermal expansion displacements of six 2D circular shapes (all at 1000℃), but the results are quite strange: as shown in the figure, the displacement of the bottom-right circle is very large. I cannot determine whether the model as a whole has undergone translation/rotation, or if only the bottom-right circle has translated/rotated. If it’s the latter case, it implies that the relative positions between the bottom-right circle and the others have changed, which is obviously unreasonable. How can I solve this issue? I hope to get some help.
Below are my code and geo file:
from dolfinx.io import gmshio
from dolfinx import io
from ufl import (tr, inner, lhs, rhs, Identity, TestFunction, TrialFunction, dx, grad)
from dolfinx.fem import (functionspace)
mesh, cell_markers, facet_markers = gmshio.read_from_msh("test.msh", MPI.COMM_WORLD, gdim=2)
kappa = 2.8e-3
E = 2e5
nu = 0.26
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
alpha = 1e-5
T = 1000 #Temperature
def eps(v):
return 0.5 * (grad(v) + grad(v).T)
def sigma(v, dT):
return (lmbda * tr(eps(v)) - alpha * (3 * lmbda + 2 * mu) * dT) * Identity(2) + 2.0 * mu * eps(v)
VU = functionspace(mesh, ("CG", 1, (mesh.geometry.dim,)))
dU = TrialFunction(VU)
U_ = TestFunction(VU)
Wint = inner(sigma(dU, T), eps(U_)) * dx
aM = lhs(Wint)
LM = rhs(Wint)
problem = LinearProblem(aM, LM, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
Uf = problem.solve()
r1 = 7.06;
r2 = 7.875;
dh = 27.713;
fh = 16;
he = 1.5;
Circle(1) = {r2+he+dh*Sqrt(3)/2-fh, dh, 0, r1, 0, 2*Pi};
Circle(2) = {r2+he+fh, dh*1.5, 0, r1, 0, 2*Pi};
Circle(3) = {r2+he+fh, dh*0.5, 0, r1, 0, 2*Pi};
Circle(4) = {r2+he+dh*Sqrt(3)-fh, dh*1.5, 0, r1, 0, 2*Pi};
Circle(5) = {r2+he+dh*Sqrt(3)-fh, dh*0.5, 0, r1, 0, 2*Pi};
Circle(6) = {r2+he+dh*Sqrt(3)/2+fh, dh, 0, r1, 0, 2*Pi};
Curve Loop(1) = {1};
Plane Surface(1) = {1};
Curve Loop(2) = {2};
Plane Surface(2) = {2};
Curve Loop(3) = {3};
Plane Surface(3) = {3};
Curve Loop(4) = {4};
Plane Surface(4) = {4};
Curve Loop(5) = {5};
Plane Surface(5) = {5};
Curve Loop(6) = {6};
Plane Surface(6) = {6};
Physical Curve("1", 7) = {1};
Physical Curve("2", 8) = {2};
Physical Curve("3", 9) = {3};
Physical Curve("4", 10) = {4};
Physical Curve("5", 11) = {5};
Physical Curve("6", 12) = {6};
Physical Surface("1", 13) = {1};
Physical Surface("2", 14) = {2};
Physical Surface("3", 15) = {3};
Physical Surface("4", 16) = {4};
Physical Surface("5", 17) = {5};
Physical Surface("6", 18) = {6};
Mesh 2;
RecombineMesh;
Mesh.SubdivisionAlgorithm = 1;
