Support needed to setup thermoelastic analysis
Hello all,
Thanks in advance for considering my question. I am currently trying to set-up a basic thermo-elastic analysis with Dolphinx. As you might have understood, I am a real beginner, so I apologize in advance if my problem is trivial.
I am using the following code to simulate a holed plate submitted to a constant Temperature field with two boundaries clamped. I have built it from several examples.
import sys
from dolfinx.io.gmshio import model_to_mesh
import pyvista as pv
# Geometry and Mesh
gmsh.initialize(sys.argv)
gmsh.model.add("boolean")
model_rank = 0
mesh_comm = MPI.COMM_WORLD
gdim = 2
L = 100.
l = 25.
R = l/3./2.
plate = gmsh.model.occ.addRectangle(0, 0, 0, L, l)
hole = gmsh.model.occ.addDisk(L/2, l/2, 0, R, R)
holed_plate = gmsh.model.occ.cut([(2, plate)],[(2, hole)])
gmsh.model.occ.synchronize()
surf = gmsh.model.getEntities(2)
gmsh.model.addPhysicalGroup(surf[0][0], [surf[0][1]], 3)
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", 3)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 3)
if(False):
    gmsh.fltk.run()
domain, cell_markers, facet_markers = model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=gdim)
gmsh.finalize()
from dolfinx import fem, plot, default_scalar_type, mesh
#V = (domain, ("CG", 1, (domain.geometry.dim, )))
def clamped_boundary(x):
    return np.isclose(x[0], 0)
def imposed_disp_boundary(x):
    return np.isclose(x[0], L)
boundary_facets_I = mesh.locate_entities_boundary(domain, fdim, clamped_boundary)
boundary_facets_C = mesh.locate_entities_boundary(domain, fdim, imposed_disp_boundary)
u_C = np.array([0, 0], dtype=default_scalar_type)
u_I = np.array([0, 0], dtype=default_scalar_type)
bc_I = fem.dirichletbc(u_C, fem.locate_dofs_topological(V, fdim, boundary_facets_I), V)
bc_C = fem.dirichletbc(u_I, fem.locate_dofs_topological(V, fdim, boundary_facets_C), V)
E_young = 1000
nu = 0.3
lambda_lame = E_young * nu / ((1 + nu) * (1 - 2 *nu))
mu_lame = E_young /(2 * (1 + nu))
alpha = 1e-5
Temp = 100.
T = fem.Constant(domain, default_scalar_type((0, 0)))
    return ufl.sym(ufl.grad(u))  # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma(v, dT):
    eps_th = alpha * dT
    eps_el = epsilon(v) - eps_th * ufl.Identity(2)
    return lambda_lame * ufl.tr(eps_el) * ufl.Identity(2) + 2.0 * mu_lame * eps_el
u = ufl.TrialFunction(V)
f = fem.Constant(domain, default_scalar_type((0, 0)))
a = ufl.inner(sigma(u, Temp), epsilon(v)) * ufl.dx
Lin = ufl.dot(f, v) * ufl.dx + ufl.dot(T, v) * ds
problem = LinearProblem(a, Lin, bcs=[bc_C, bc_I], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
Uf = problem.solve()
I get the following error and I cannot figure what is going on… Can somebody help me?
ValueError                                Traceback (most recent call last)
Cell In[29], line 27
     24 a = ufl.inner(sigma(u, Temp), epsilon(v)) * ufl.dx
     25 Lin = ufl.dot(f, v) * ufl.dx + ufl.dot(T, v) * ds
---> 27 problem = LinearProblem(a, Lin, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
     28 Uf = problem.solve()
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/dolfinx/fem/petsc.py:782, in LinearProblem.__init__(self, a, L, bcs, u, petsc_options, form_compiler_options, jit_options)
    744 def __init__(
    745     self,
    746     a: ufl.Form,
    752     jit_options: typing.Optional[dict] = None,
    753 ):
    754     """Initialize solver for a linear variational problem.
    755
    756     Args:
    780        "mumps"})
    781     """
--> 782     self._a = _create_form(
    783         a,
    784         dtype=PETSc.ScalarType,
    785         form_compiler_options=form_compiler_options,
    786         jit_options=jit_options,
    787     )
    788     self._A = create_matrix(self._a)
    789     self._L = _create_form(
    790         L,
    791         dtype=PETSc.ScalarType,
    792         form_compiler_options=form_compiler_options,
    793         jit_options=jit_options,
    794     )
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/dolfinx/fem/forms.py:337, in form(form, dtype, form_compiler_options, jit_options, entity_maps)
    334     else:
    335         return form
--> 337 return _create_form(form)
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/dolfinx/fem/forms.py:331, in form.<locals>._create_form(form)
    329         return None
    330     else:
--> 331         return _form(form)
    332 elif isinstance(form, collections.abc.Iterable):
    333     return list(map(lambda sub_form: _create_form(sub_form), form))
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/dolfinx/fem/forms.py:254, in form.<locals>._form(form)
    252 if mesh is None:
    253     raise RuntimeError("Expecting to find a Mesh in the form.")
--> 254 ufcx_form, module, code = jit.ffcx_jit(
    255     mesh.comm, form, form_compiler_options=form_compiler_options, jit_options=jit_options
    256 )
    258 # For each argument in form extract its function space
    259 V = [arg.ufl_function_space()._cpp_object for arg in form.arguments()]
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/dolfinx/jit.py:62, in mpi_jit_decorator.<locals>.mpi_jit(comm, *args, **kwargs)
     58 @functools.wraps(local_jit)
     59 def mpi_jit(comm, *args, **kwargs):
     60     # Just call JIT compiler when running in serial
     61     if comm.size == 1:
---> 62         return local_jit(*args, **kwargs)
     64     # Default status (0 == ok, 1 == fail)
     65     status = 0
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/dolfinx/jit.py:212, in ffcx_jit(ufl_object, form_compiler_options, jit_options)
    210 # Switch on type and compile, returning cffi object
    211 if isinstance(ufl_object, ufl.Form):
--> 212     r = ffcx.codegeneration.jit.compile_forms([ufl_object], options=p_ffcx, **p_jit)
    213 elif isinstance(ufl_object, ufl.Mesh):
    214     r = ffcx.codegeneration.jit.compile_coordinate_maps([ufl_object], options=p_ffcx, **p_jit)
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ffcx/codegeneration/jit.py:225, in compile_forms(forms, options, cache_dir, timeout, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    223     except Exception:
    224         pass
--> 225     raise e
    227 obj, module = _load_objects(cache_dir, module_name, form_names)
    228 return obj, module, (decl, impl)
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ffcx/codegeneration/jit.py:205, in compile_forms(forms, options, cache_dir, timeout, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    202     for name in form_names:
    203         decl += form_template.format(name=name)
--> 205     impl = _compile_objects(
    206         decl,
    207         forms,
    208         form_names,
    209         module_name,
    210         p,
    211         cache_dir,
    212         cffi_extra_compile_args,
    213         cffi_verbose,
    214         cffi_debug,
    215         cffi_libraries,
    216         visualise=visualise,
    217     )
    218 except Exception as e:
    219     try:
    220         # remove c file so that it will not timeout next time
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ffcx/codegeneration/jit.py:330, in _compile_objects(decl, ufl_objects, object_names, module_name, options, cache_dir, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    326 libraries = _libraries + cffi_libraries if cffi_libraries is not None else _libraries
    328 # JIT uses module_name as prefix, which is needed to make names of all struct/function
    329 # unique across modules
--> 330 _, code_body = ffcx.compiler.compile_ufl_objects(
    331     ufl_objects, prefix=module_name, options=options, visualise=visualise
    332 )
    334 # Raise error immediately prior to compilation if no support for C99
    335 # _Complex. Doing this here allows FFCx to be used for complex codegen on
    336 # Windows.
    337 if sys.platform.startswith("win32"):
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ffcx/compiler.py:108, in compile_ufl_objects(ufl_objects, options, object_names, prefix, visualise)
    106 # Stage 1: analysis
    107 cpu_time = time()
--> 108 analysis = analyze_ufl_objects(ufl_objects, options["scalar_type"])  # type: ignore
    109 _print_timing(1, time() - cpu_time)
    111 # Stage 2: intermediate representation
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ffcx/analysis.py:94, in analyze_ufl_objects(ufl_objects, scalar_type)
     91     else:
     92         raise TypeError("UFL objects not recognised.")
---> 94 form_data = tuple(_analyze_form(form, scalar_type) for form in forms)
     95 for data in form_data:
     96     elements += data.unique_sub_elements
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ffcx/analysis.py:94, in <genexpr>(.0)
     91     else:
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ffcx/analysis.py:180, in _analyze_form(form, scalar_type)
    177 complex_mode = np.issubdtype(scalar_type, np.complexfloating)
    179 # Compute form metadata
--> 180 form_data = ufl.algorithms.compute_form_data(
    181     form,
    182     do_apply_function_pullbacks=True,
    183     do_apply_integral_scaling=True,
    184     do_apply_geometry_lowering=True,
    185     preserve_geometry_types=(ufl.classes.Jacobian,),
    186     do_apply_restrictions=True,
    187     do_append_everywhere_integrals=False,  # do not add dx integrals to dx(i) in UFL
    188     complex_mode=complex_mode,
    189 )
    191 # Determine unique quadrature degree and quadrature scheme
    192 # per each integral data
    193 for id, integral_data in enumerate(form_data.integral_data):
    194     # Iterate through groups of integral data. There is one integral
    195     # data for all integrals with same domain, itype, subdomain_id
    199     # all integrals in this integral data group, i.e. must be the
    200     # same for for the same (domain, itype, subdomain_id)
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ufl/algorithms/compute_form_data.py:427, in compute_form_data(form, do_apply_function_pullbacks, do_apply_integral_scaling, do_apply_geometry_lowering, preserve_geometry_types, do_apply_default_restrictions, do_apply_restrictions, do_estimate_degrees, do_append_everywhere_integrals, complex_mode)
    424 preprocessed_form = reconstruct_form_from_integral_data(self.integral_data)
    426 # TODO: Test how fast this is
--> 427 check_form_arity(preprocessed_form, self.original_form.arguments(), complex_mode)
    429 # TODO: This member is used by unit tests, change the tests to
    430 # remove this!
    431 self.preprocessed_form = preprocessed_form
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ufl/algorithms/check_arities.py:213, in check_form_arity(form, arguments, complex_mode)
    211 """Check the arity of a form."""
    212 for itg in form.integrals():
--> 213     check_integrand_arity(itg.integrand(), arguments, complex_mode)
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ufl/algorithms/check_arities.py:194, in check_integrand_arity(expr, arguments, complex_mode)
    192 arguments = tuple(sorted(set(arguments), key=lambda x: (x.number(), x.part())))
    193 rules = ArityChecker(arguments)
--> 194 arg_tuples = map_expr_dag(rules, expr, compress=False)
    195 args = tuple(a[0] for a in arg_tuples)
    196 if args != arguments:
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ufl/corealg/map_dag.py:35, in map_expr_dag(function, expression, compress, vcache, rcache)
     15 def map_expr_dag(function, expression, compress=True, vcache=None, rcache=None):
     16     """Apply a function to each subexpression node in an expression DAG.
     17
     18     If the same function is called multiple times in a transformation
     33         The result of the final function call
     34     """
---> 35     (result,) = map_expr_dags(
     36         function, [expression], compress=compress, vcache=vcache, rcache=rcache
     37     )
     38     return result
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ufl/corealg/map_dag.py:103, in map_expr_dags(function, expressions, compress, vcache, rcache)
    101     r = handlers[v._ufl_typecode_](v)
    102 else:
--> 103     r = handlers[v._ufl_typecode_](v, *[vcache[u] for u in v.ufl_operands])
    105 # Optionally check if r is in rcache, a memory optimization
    106 # to be able to keep representation of result compact
    107 if compress:
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ufl/algorithms/check_arities.py:60, in ArityChecker.sum(self, o, a, b)
     57 """Apply to sum."""
     58 if a != b:
     59     raise ArityMismatch(
---> 60         f"Adding expressions with non-matching form arguments {_afmt(a)} vs {_afmt(b)}."
     61     )
     62 return a
File ~/miniconda3/envs/fenicsx_env/lib/python3.13/site-packages/ufl/algorithms/check_arities.py:20, in _afmt(atuple)
     18 def _afmt(atuple: Tuple[Argument, bool]) -> str:
     19     """Return a string representation of an arity tuple."""
---> 20     arg, conj = atuple
     21     return f"conj({arg})" if conj else str(arg)
ValueError: not enough values to unpack (expected 2, got 0)
since dT is a scalar,
a is not a bilinear form.
I would rather write this on residual form,
F= ufl.inner(sigma(u, Temp), epsilon(v)) * ufl.dx- ufl.dot(f, v) * ufl.dx + ufl.dot(T, v) * ds
and then use a, Lin = ufl.system(F)
It works! Thank you very much for your prompt and efficient answer :smiley:
I am posting the corrected part if it can help somebody else in the future.
E_young = 1000
nu = 0.3
alpha = 1e-5
Temp = 100.
def sigma(v, dT):
    eps_th = alpha * dT
