Hi! I am trying to use fenicsx in my computer with ubuntu 22.04. I followed the instalation on the webpage:
add-apt-repository ppa:fenics-packages/fenics
apt update
apt install fenicsx
Still, when I open python and try to import fenicsx or dolfinx, i get:
ModuleNotFoundError: No module named ‘dolfinx’
Any help is appreciated,
Sara
What is the output of apt install fenicsx
and what is the output of python3 -m pip list
This is my way of reproducing your commands:
- Run docker with:
docker run -ti --rm ubuntu:22.04 - call
apt-get update && apt-get install software-properties-common
apt update
apt install fenicsx
python3 -c "import dolfinx; print(dolfinx.__version__)"
which for me yields:
0.5.2
thanks!
I think finally my problem was that I was trying to import it in my venv, where I have installed my python.
Hi Sara!
Do you solve it? I’m struggling with a similar issue.
Thanks
Hi! In my case, I just ran my programs outside the venv. I still do not know how to “find” them when working in my environment…
Hope it helps,
Sara
Does anyone know how to make this work from inside a conda venv? I apt install’ed on Ubuntu like Sara and ran into the same import issue. It handles the imports when I exit from the venv but wants me to install other packages and I’d like to do that inside the venv (not system-wide). Here’s my error:
aaronm@srv:$ python3 demo_poisson.py
'pyvista' is required to visualise the solution
Install 'pyvista' with pip: 'python3 -m pip install pyvista'
I can install this package, but again, would not want to make it system-wide, since I’m trying to contain the environment.
Thanks!
If you are using a conda env, I would install both dolfinx and pyvista with conda as shown at https://fenicsproject.org/download/
Gotcha, that worked. Thanks!
