I am trying to implement a moving Neumann boundary condition. I created a cantilever beam MWE example here, where I manually update the node of the load through a custom function. The code runs, but in the result nothing happens. The output of my expression out contains non-zero values, but when I interpolate this to my BC (load_func) it is all zeros.
1: Is manually finding the nodes to apply a load to a good way to achieve a moving load, or is there a simpler method?
2: Why is my interpolated load empty?
Thank you!
from dolfinx import mesh, fem
print(f"dolfinx version: {dolfinx.__version__}")
# Create a uniform 2D rectangular mesh
mesh_domain = mesh.create_rectangle(MPI.COMM_WORLD, ((0.0, 0.0), (1.0, .2)), (40, 5), mesh.CellType.triangle)
tdim = mesh_domain.topology.dim - 1
V = fem.functionspace(mesh_domain, ("P", 1, (2,)))
u = ufl.TrialFunction(V)
# Define material properties
E = 210e9
nu = 0.3
lambda_ = E * nu / ((1 + nu) * (1 - 2 * nu))
mu = E / (2 * (1 + nu))
# Strain and stress
return ufl.sym(ufl.grad(u))
def sigma(u):
return lambda_ * ufl.div(u) * ufl.Identity(len(u)) + 2 * mu * epsilon(u)
# Dirichlet BC (0 displacement on left boundary)
def boundary_points(x): # return left boundary points
return np.isclose(x[0], min(x[0]))
boundary_dofs = fem.locate_dofs_geometrical(V, boundary_points)
uD = fem.Function(V)
uD.interpolate(lambda x: np.zeros((2, x.shape[1]))) # zero values
bc = fem.dirichletbc(value=uD, dofs=boundary_dofs)
# Neumann BC (moving load)
class MovingLoad:
Load moves over top nodes, from ~0.5x to x.
It uses the closest nodes.
def __init__(self):
self.t = 0
def eval(self, x):
out = np.zeros((2, x.shape[1])) # initialize output
top_nodes = np.where(np.isclose(x[1], max(x[1]))) # get all top nodes
x_coord = np.argmin(np.abs(x[0, top_nodes] - (0.5 + self.t / 20))) # get node closest to 0.5+t/20
out[1, top_nodes[0][x_coord]] = 10 # set constant load value for that specific node
print(f"load pure {np.nonzero(out)}")
# Out does contain nodes with the loading
return out
load = MovingLoad()
V_load = fem.functionspace(mesh_domain, ("P", 1, (2,)))
load_func = fem.Function(V_load, name="load")
load_func.interpolate(load.eval)
# load_func is empty when interpolated
print(f"load interpolated {np.nonzero(load_func.x.array)}")
# Solving and plotting for steps
# weak form
L = -ufl.inner(load_func, v) * ufl.ds
problem = dolfinx.fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
with XDMFFile(mesh_domain.comm, "MWE_results.xdmf", "w") as write_file:
write_file.write_mesh(mesh_domain)
for step in range(1, 11):
load.t = step # update load position
uh = problem.solve() # solve problem
write_file.write_function(uh, step) # write solution to file
write_file.write_function(load_func, step)
