Neumann BC not fulfilled? (dolfinx)
I had some indications that in one of my dolfinx-scripts the Neumann BC is not fulfilled, so I barely modified one of the tutorials from @dokken to create a MWE and was surprised to find the same indication there as well: The Neumann BC does not seem to be fulfilled.
MWE (see Setting multiple Dirichlet, Neumann, and Robin conditions — FEniCSx tutorial):
import pyvista
from dolfinx.fem import (Constant,  Function, FunctionSpace, assemble_scalar,
                         dirichletbc, form, locate_dofs_topological)
from dolfinx.mesh import create_unit_square, locate_entities, meshtags
from ufl import (FacetNormal, Measure, SpatialCoordinate, TestFunction, TrialFunction,
                 div, dot, dx, grad, inner, lhs, rhs)
u_ex = lambda x: 1 + x[0]**2 + 2*x[1]**2
x = SpatialCoordinate(mesh)
# Define physical parameters and boundary condtions
s = u_ex(x)
f = -div(grad(u_ex(x)))
g = -dot(n, grad(u_ex(x)))
# g = 0.0
kappa = Constant(mesh, ScalarType(1))
r = Constant(mesh, ScalarType(1000))
# Define function space and standard part of variational form
V = FunctionSpace(mesh, ("CG", 1))
F = kappa * inner(grad(u), grad(v)) * dx - inner(f, v) * dx
boundaries = [(1, lambda x: np.isclose(x[0], 0)),
              (2, lambda x: np.isclose(x[0], 1)),
              (3, lambda x: np.isclose(x[1], 0)),
              (4, lambda x: np.isclose(x[1], 1))]
fdim = mesh.topology.dim - 1
    facets = locate_entities(mesh, fdim, locator)
    facet_indices.append(facets)
facet_tag = meshtags(mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
with XDMFFile(mesh.comm, "output/facet_tags.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh)
    xdmf.write_meshtags(facet_tag)
ds = Measure("ds", domain=mesh, subdomain_data=facet_tag)
class BoundaryCondition():
    def __init__(self, type, marker, values):
        self._type = type
        if type == "Dirichlet":
            u_D = Function(V)
            u_D.interpolate(values)
            facets = facet_tag.find(marker)
            dofs = locate_dofs_topological(V, fdim, facets)
            self._bc = dirichletbc(u_D, dofs)
        elif type == "Neumann":
                self._bc = inner(values, v) * ds(marker)
        elif type == "Robin":
            self._bc = values[0] * inner(u-values[1], v)* ds(marker)
            raise TypeError("Unknown boundary condition: {0:s}".format(type))
    @property
    def bc(self):
        return self._bc
    @property
    def type(self):
        return self._type
# Define the Dirichlet condition
boundary_conditions = [BoundaryCondition("Dirichlet", 1, u_ex),
                       BoundaryCondition("Dirichlet", 2, u_ex),
                       BoundaryCondition("Robin", 3, (r, s)),
                       BoundaryCondition("Neumann", 4, g)]
bcs = []
for condition in boundary_conditions:
    if condition.type == "Dirichlet":
        bcs.append(condition.bc)
        F += condition.bc
# Solve linear variational problem
a = lhs(F)
L = rhs(F)
problem = LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
solution_trace_norm = assemble_scalar(form((dot(n, grad(uh))-g)**2*ds(4)))**0.5
print(f"Neumann BC trace: {solution_trace_norm}")
The output I receive should be close to zero, but is:
Neumann BC trace: 7.800058502092114
Even if I set the Neumann BC to g=0, the output is still too high with
Neumann BC trace: 1.366936098344996
I am using the version fenics-dolfinx 0.6.0 via conda-forge on Ubuntu via WSL2.
Is this expected behaviour?
Did I do any mistakes evaluating (last line of the code) the Neumann BC?
There is a sign mistake, your g is pointing inwards, not outwards.
As you can see from the following example, the trace goes closer and closer to the actual trace.
from dolfinx.fem import (Constant,  Function, functionspace, assemble_scalar,
for N in [10, 20, 40, 80, 100]:
    mesh = create_unit_square(MPI.COMM_WORLD, N, N)
    def u_ex(x): return 1 + x[0]**2 + 2*x[1]**2
    s = u_ex(x)
    # g = 0.0
    V = functionspace(mesh, ("Lagrange", 1))
            self._type = type
                u_D = Function(V)
                self._bc = values[0] * inner(u-values[1], v) * ds(marker)
                raise TypeError(
        @property
        def bc(self):
            return self._bc
        @property
        def type(self):
            return self._type
    bcs = []
            F += condition.bc
    a = lhs(F)
    L = rhs(F)
    problem = LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu", "pc_factor_mat_solver_type": "mumps"}
    print(
        f"Integral over boundary {assemble_scalar(form(dot(n, grad(uh))*ds(4)))},{assemble_scalar(form(-g*ds(4)))}")
        form((dot(n, grad(uh))+g)**2*ds(4)))**0.5
    print(f"L2 norm: {assemble_scalar(form(dot(uh-u_ex(x), uh-u_ex(x))*dx))}")
        xdmf.write_meshtags(facet_tag, mesh.geometry)
        xdmf.write_function(uh)
(here Im using the main branch of DOLFINx), so a slight change in syntax:
Integral over boundary 3.8000585020380435,4.0
Neumann BC trace: 0.19994150007125447
L2 norm: 2.3597310792740984e-05
Integral over boundary 3.900007213125378,4.000000000000002
Neumann BC trace: 0.09999278693537393
L2 norm: 1.4778471852531955e-06
Integral over boundary 3.9500008985183026,4.000000000000001
Neumann BC trace: 0.049999101483557185
L2 norm: 9.242779112544334e-08
Integral over boundary 3.9750001122171454,3.999999999999993
Neumann BC trace: 0.024999887782911453
L2 norm: 5.777939472233128e-09
Integral over boundary 3.9800000574491663,4.000000000000002
Neumann BC trace: 0.019999942550853547
L2 norm: 2.366711199034677e-09
