Dear Community,
I am inverting a blockmatrix (stemming from a transport problem) on a cuboidal mesh with periodic boundary conditions along the z-axis. The latter are enforced using the MPC package. Details:
- the domain is a box with the following measurements: (0.5,1)\times (0,0.5) \times (0,2)
- I use an anisotropic mesh, with a resolution of 150x150 elements in the x-y-plane, and 5 elements along the z-direction.
I use a direct solver, and a smooth RHS/initial value. The solution has strange features and wiggles, that are at the size of a single element, and which I would regard as nonphysical. Here is a screenshot:
Here is a minimal example code, that reproduces the problem (I ran it on dolfinx 0.9.0):
from dolfinx.fem import (Function, dirichletbc, form,
functionspace, locate_dofs_topological)
from dolfinx.mesh import *
from dolfinx.mesh import CellType
from ufl import dx, grad, inner
from ufl import as_vector
from dolfinx_mpc import (MultiPointConstraint,assemble_vector_nest,
create_vector_nest,assemble_matrix_nest,
create_matrix_nest)
# mesh
Nx = 150
Ny = 150
Nz = 5
Lx = 0.5
Lxx = 1.0
Ly = 0.5
Lz = 2
msh = create_box(MPI.COMM_WORLD,
[[Lx, 0.0, 0.0], [Lxx, Ly, Lz]],
[Nx,Ny,Nz],
cell_type=CellType.hexahedron)
Xp = functionspace(msh, ("Lagrange", 1))
Xu = functionspace(msh, ("Lagrange", 1))
offset = Xu.dofmap.index_map.size_local * Xu.dofmap.index_map_bs
u = ufl.TrialFunction(Xu)
p = ufl.TrialFunction(Xp)
w = ufl.TestFunction(Xu)
q = ufl.TestFunction(Xp)
u_func = Function(Xu, name="u_func")
p_func = Function(Xp, name="p_func")
# vector field
def vec_field(x,y,z):
eps = 0.4
vx = eps*ufl.sin(5*z)
vy = eps*ufl.cos(5*z)
vz = np.sqrt(1-eps**2)
return (vx,vy,vz)
vfield = as_vector(np.array(vec_field(x[0],x[1],x[2])))
# bc
boundary_dim = (msh).topology.dim - 1
facets = locate_entities_boundary(msh, dim=boundary_dim,
marker=lambda x: np.logical_or.reduce((
np.isclose(x[0], Lx),
np.isclose(x[0], Lxx),
np.isclose(x[1], 0.0),
np.isclose(x[1], Ly))))
dofs = locate_dofs_topological(V=Xp, entity_dim=boundary_dim, entities=facets)
BCs = [dirichletbc(0.0, dofs=dofs, V=Xp)]
def periodic_boundary(x):
return np.isclose(x[2], Lz)
def periodic_relation(x):
out_x = np.zeros_like(x)
out_x[0] = x[0]
out_x[1] = x[1]
out_x[2] = 0
return out_x
mpc_u = MultiPointConstraint(Xu)
mpc_u.create_periodic_constraint_geometrical(Xu, periodic_boundary, periodic_relation, BCs)
mpc_u.finalize()
mpc_p = MultiPointConstraint(Xp)
mpc_p.create_periodic_constraint_geometrical(Xp, periodic_boundary, periodic_relation, BCs)
mpc_p.finalize()
# ic
u_func.interpolate(lambda x: np.sin((0.5/Ly)*2*np.pi*x[1])\
* np.cos((1/Lz)*2*np.pi*x[2])\
+ np.sin((2/Ly)*2*np.pi*x[1])\
* np.cos((1/Lz)*2*np.pi*x[2]))
p_func.interpolate(lambda x: 0*x[0])
# weak form
M = 0.0005*inner(u,w)*dx
E = -1 * inner(inner(vfield,grad(p)), w)*dx
N = -1 * inner(grad(p),grad(q))*dx
F = -1 * inner(inner(vfield,grad(q)), u)*dx
a = form([[M, E],[F, N]])
l = form([0.0005*inner(u_func,w)*dx \
+1 * inner(inner(vfield,grad(p_func)), w)*dx,
-1 * inner(grad(p_func), grad(q))*dx \
+1 * inner(u_func,inner(vfield,grad(q)))*dx
# assembly
A = create_matrix_nest(a, [mpc_u, mpc_p])
assemble_matrix_nest(A, a, [mpc_u, mpc_p], BCs)
L = create_vector_nest(l,[mpc_u, mpc_p])
up_vec = L.copy()
assemble_vector_nest(L,l,[mpc_u, mpc_p])
# solve
solver = PETSc.KSP().create(msh.comm)
solver.setOperators(A)
solver.solve(L, up_vec)
# plot solution
from dolfinx import plot
import pyvista
u_func.x.array[:] = up_vec.array_r[:offset]
mpc_u.backsubstitution(u_func)
cells, types, x = plot.vtk_mesh(Xu)
grid = pyvista.UnstructuredGrid(cells, types, x)
grid.point_data["u"] = u_func.x.array.real
grid.set_active_scalars("u")
plotter = pyvista.Plotter()
plotter.show_axes()
plotter.show()
I noticed three things:
- The wiggles appear only on (or come from) the periodic boundary
- These wiggles only occur when i choose an anisotropic mesh (does MPC somehow fail to match the DOFs from the too ends of the domain, if the mesh is too anisotropic?)
- If i translate the domain along the x-axis towards the origin, i.e. instead of (0.5,1)\times (0,0.5) \times (0,2), i use
(0,0.5)\times (0,0.5) \times (0,2), the wiggles also do not appear anymore.
Any advice is highly appreciated
