Dear all,
I have a diffusion problem that runs well with one process. For parallel execution, however, the obtained solution is clearly wrong as can be seen in this picture:
Obviously, the domain is partitioned as it should be but the process communication is wrong. I am using the dolfinx/dolfinx:stable docker image on a workstation running ubuntu. For running my script in parallel is use the command:
# mpirun -n 8 pyhton3 diffusion.py
This is the code that produces the error:
from dolfinx import io
from dolfinx.fem import FunctionSpace, Function, form
from dolfinx.fem.petsc import (create_vector, create_matrix, assemble_vector,
assemble_matrix, apply_lifting)
from dolfinx.io import gmshio
from ufl import (TestFunction, TrialFunction, jump, avg, CellDiameter,
FacetNormal, dx, dS, dot, lhs, rhs)
gdim = 2
gmsh_model_rank = 0
mesh_comm = MPI.COMM_WORLD
if mesh_comm.rank == gmsh_model_rank:
gmsh.model.occ.addDisk(0.5, 0.5, 0, 0.5, 0.5, tag=0)
gmsh.model.occ.synchronize()
gmsh.option.setNumber("Mesh.CharacteristicLengthMin",0.01)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax",0.01)
gmsh.model.addPhysicalGroup(gdim, [0], 1)
gmsh.model.setPhysicalName(gdim, 1, "rectangles")
domain, cell_markers, facet_markers = gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, gmsh_model_rank, gdim=gdim)
gmsh.finalize()
V = FunctionSpace(domain, ("DG", 0))
y = Function(V)
h = TrialFunction(V)
n = FacetNormal(domain)
d = CellDiameter(domain)
d_avg = (d('+') + d('-'))/2 # average cell diamerter
t = 0.0 # initial time
dt = 1e-5 # time increment
xdmf = io.XDMFFile(domain.comm, "concentration.xdmf", "w")
xdmf.write_mesh(domain)
# initial condition
y_n = Function(V)
y_n.interpolate(lambda x: 0.01 + 0.98*(((x[0]-0.15)**2+(x[1]-0.3)**2)**0.5 < 0.12)
+ 0.98*(((x[0]-0.45)**2+(x[1]-0.55)**2)**0.5 < 0.13)
+ 0.98*(((x[0]-0.7)**2+(x[1]-0.2)**2)**0.5 < 0.15)
+ 0.98*(((x[0]-0.2)**2+(x[1]-0.67)**2)**0.5 < 0.148)
+ 0.98*(((x[0]-0.7)**2+(x[1]-0.6)**2)**0.5 < 0.09)
+ 0.98*(((x[0]-0.65)**2+(x[1]-0.8)**2)**0.5 < 0.1))
xdmf.write_function(y_n, t)
# linear variational problem
F = (y_n-h)*v*dx - dt/d_avg*dot(jump(h , n), jump(v, n))*dS
a = form(lhs(F))
L = form(rhs(F))
A = create_matrix(a)
b = create_vector(L)
solver.setOperators(A)
solver.setType(PETSc.KSP.Type.BCGS)
solver.getPC().setType(PETSc.PC.Type.JACOBI)
for i in range(500):
# solve linear system
A.zeroEntries()
assemble_matrix(A, a, bcs=[])
with b.localForm() as loc:
loc.set(0)
assemble_vector(b, L)
apply_lifting(b, [a], [[]])
b.ghostUpdate()
solver.solve(b, y.vector)
y.x.scatter_forward()
# update solution
y_n.x.array[:] = y.x.array
# update time
# save solution
xdmf.write_function(y, t)
xdmf.close()
